Question about HP Computers & Internet
Hp 700 not printing word files or pdf files
Im using a Sony Vaio touchscreen laptop. Ive cleared all print history and reset the printer many times but its not responding and it will make copys and print, just not my word files or pdf's. any advice?
  • HP Master
  • 3,320 Answers
I would uninstall then reinstall the printer software and drivers.
Posted on Mar 06, 2014
pkbytes
  • 45 Answers
SOURCE: printer will default to "save as" screen when que to print
In administrator login the default printer is "Microsoft XPS Document Writer", make sure that the default printer is the HP Printer.
OR
You have to change in the Print dialog box, select the HP Printer instead of "Microsoft XPS Document Writer"
Cheers - Parveen
Posted on Feb 08, 2008
SOURCE: BIOS Password For Sony Vaio
I Want to clear my bios password.
Posted on Jul 28, 2008
mwalker02
  • 41 Answers
SOURCE: Printer prints more copies than indicated. Driver reinstalled multiple times.
I don't know if this will help but I have had similar problems. I would notice that one or two particular programs would print more than one copy and others were just fine. Try checking the preferences on the actual programs. Some programs retain their last qty request and don't change unless you change it. For instance, you request a program to give you two copies of a particular document and everything works fine. Then a day later you are in the same program and need only one copy of a document and you get two instead. This is because there is something set in the program or the preferences of your printing device that causes it to retain the last requested quantity for printing. Next time you print check the print dialog box and see how many copies it is showing will be printed. Hope this helps.
Posted on Jun 01, 2009
  • 6 Answers
SOURCE: Having a problem getting my Sony Vaio PCG-3E2L laptop to auto play my photo DVD slide show. Using Windows Vista Home Premium OS.Also, where can I find a PDF Sony User Manaul for my laptop?
A quick short cut is to open a browser if you use Internet Explorer and select tools menu, then select Internet options. When the box opens then select the advanced tab and scroll down until you see a check box under security and check allow active content from CD to run on my computer.
Also here is the link for your manual: http://esupport.sony.com/US/perl/index.pl
Posted on Jun 02, 2009
benwabnick
  • 2404 Answers
SOURCE: Sony Vaio VGNNR330E laptop wont start up right even after recover
I think you may have bad sectors on the hard drive which is why it loads the software but then when it comes time for the system to read it, it just hangs cause it can't read into the sectors on the hard drive.
Best way to determine this, try another known good working hard drive and if it goes thru all the way and loads then you know the original hard drive is bad.
Posted on Jun 17, 2009
Printer has stopped printing .pdf files
Check your list of printers and make sure the default printer is the correct one.
Mar 18, 2017 | HP OfficeJet 6210 All-In-One InkJet...
I am using A Iogear gpsu21 with a Kodak esp5 printer. I am able to print with no problem from a Acer AS1410 laptop running win 7 32 bit.I am using a Sony Vaio E series laptop with a win 7 64 bit system i...
First, make sure that the Kodak printer driver is properly installed in your Sony Vaio. Make sure that you can print while the Kodak is directly connected to Sony Vaio.
If you can print directly connected to it, try to reinstall the GPSU21 Utility.
Apr 13, 2010 | IOGear GPSU21 Print Server
Wireless Printer Issue.
As I understand your issue, the HP Laserjet 1020 is a USB printer. You have it attached to a desktop PC. If that PC is rebooted, you can print for a short while.
The problem is probably not your network, but your desktop.
I would do the routine maintenance on it. Clear all the temp files, check hard drive free space and defrag the drive.
Then get online and download Malwarebytes.org spyware malware scanner tool. Scan the desktop PC for malware and clear out anything that may be occupying the resources of this PC.
Apr 06, 2010 | Nortel 2332 802.11a/b/g Wireless Access...
Printing Problem
my laptop sony vaio vgn-n130g it is do not work LCD back light in press (Fn and F5- F6+)
Mar 25, 2008 | Sony VAIO VGN-N130G/W Notebook
Does not print pdf files
It sounds like it is a printer memory issue. That printer comes with just 64MB of memory and PDF files are complicated for most printers. Try printing a few pages at a time for that PDF file and see if that works. If so than it is a memory issue.
Jan 23, 2008 | HP Officejet Pro L7680 All-In-One Printer
My Sony Vaio won't print using my printer HP C6180
Is the ink of your printer there?? Or finished. Check this n then try to print again
Jul 15, 2017 | HP Photosmart C6180 All-In-One InkJet...
Hp1020 won't print pdf files
The 1020 Has Known issues printing PDF files. The HP LJ 1020 is a HOST printer with NO SUPPORT for PS (post script) or PLC commands. Most users end up printing the PDFs as images. That was not a solution for us and we trashed our 1020 and went with another brand. Good luck.
http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1153974
Jan 03, 2008 | HP LaserJet 1020 Printer
Pale print on PDF files
It sounds like a driver problem. Try replacing the driver for this printer on the printers folder, using the HP LaserJet Series II. With this driver, try again the PDF file and see if it prints correctly.
Jul 25, 2007 | HP LaserJet 4345mfp Printer
Computers & Internet Logo
21 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
