Question about Video Game Consoles & Games
Access vioalation at adress - Video Game Consoles & Games
Hi! I tried to access to my Zyxel p660hw d1 with the common 192.168.1.1. ip adress in internet explorer, but it doesn't seem to find the router log in page... Ho can i access to it then?
Be sure that your router adress is 192.168.1.1 you can use winipcfg in windows (the gateway address is what you are looking for) to see if its the good adress.
http://support.microsoft.com/kb/141698
If its not working use another browser, simply restart the router or Hard Reset the router with a paper clip.
Mar 14, 2011 | Zyxel P660HW-D1 Router
I want the ip to access my router so i can change the default name n put security
You can locate your router's adress with this easy trip:
Hit start - run - cmd. At the new black window that will appear type "ipconfig" without the quotes and hit enter. The system will reply with the the details for IP Adress, Subnet Mask and Default Gateway. The ip adress for Default Getaway is your router's ip adress. This photo may help you:
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 01, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Accessing router interface
Press the windows key on your keyboard and keep it pressed. press the R key. release all keys. type cmd and click ok
in the black window type the following command:
ipconfig
press enter
look at the Default gateway adress. note this adress.
go to your webbrowser and in the adress bar type the adress you notes above.
Apr 08, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D-Link 2100 AP is working in Wireless Client mode. It is connected to home network with cat5 cable. The remote ADSL modem is 192.168.1.1 and DHCP on. The first computer in the network obtains IP and...
Check in your router to see if your router is set up to be a DHCP Server. If your router and adsl are both set up to be DHCP servers, sometimes they will fight with each other and some computers seem to have problems getting adresses from this kind of setup. Make sure that only one is set up to give out adresses, then check on your second computer to make sure that it is set to obtain adress automaticaly. If someone has set a manual adress in that computer that is not on the same subnet as the router, they will not comunicate. If this does not solve your problem, try putting in manual adresses into both computers: IE 192.168.1.2, subnet mask 255.255.255.0, Default gateway 192.168.1.1 in the first, and 192.168.1.3 in the second with the same subnet and default gateway,
Nov 24, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
I cannot send new emails or bring up contact list. Can you help
Probably you have some empty files into your adress book that blocks the access. Open your adress book from the dock or applications directory (you can find it by spotlight too) and erase the empty files (no names or no email adress)
Jan 21, 2009 | Apple Mac 10.5.1 Desktop
EMPIRE DVBS PLUS
access violation at adress 0049451D in module 'DVBS.exe' read of adress 00000000
May 11, 2008 | KWorld DVB-S 100 (DVBS100) Video Capture
DI 514 and Skyway
if A is the skyway modem with the adress 192.168.1.1
if B is the DI 514 WAN port with the adress 192.168.1.2 and 192.168.1.1 set as gatway
and if C is your computer with the adress 192.168.2.2 and 192.168.2.1 set as gatway
and if D is the di 514 LAN port with the adress 192.168.2.1
than it works
"When I route it through the DI 514 I can access the internet but not the modem" u dont route it, u NAT it. so if u cant acces it with the right setings then try to xpoze yor computer host in DMZ seting
Nov 02, 2007 | D-Link DI 514 Wireless Router (DI-514)
Video Game Consoles & Games Logo
66 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
