Question about HUMMINBIRD PiranhaMAX 160
I have Pirahniamax 160 portable fish finder . I have problem with transom transducer, shows all the time not conected . What you recomended to do ? John
5 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: TRANSDUCERS
You have to order this from the manufacture.
Jerry G.
Posted on Jul 26, 2008
  • 11 Answers
SOURCE: Insructions for piranah fish finder at home,
Go to this webpage and click on the link of the manual of you finder and it will open up your manual.
http://www.humminbird.com/support/FAQ.aspx?faqid=72
Posted on Dec 30, 2008
  • 74 Answers
SOURCE: I need a instruction manaul for a Hummingbird LCR
All Humminbird manuals can be found here.
Posted on Jul 08, 2009
  • 693 Answers
SOURCE: Need to locate and print
print users manual for Humminbird Pironha Max 160 Fish go to this link http://store.humminbird.com/media/document/PiranhaMAX_150-160-170-180-190c.pdf
Posted on Aug 13, 2011
I need to connect a Garmin 160 transducer to a garmin 120 fish finder
If I may inquire, how many pins on the transducer and on the fishfinder.
Hope to hear from you and pls post back the requested information.
Good luck and kind regards. Thank you for using FixYa.
Sep 17, 2008 | Garmin GPSMAP 188 Fish Finder/GPS Receiver
My hummingbird rf15 smartcast fish finder has stopped scanning.it still provides the water temperature but it no longer displays the depth and does not scan the bottom.
The Smartcast system uses the wireless version of a simple transducer and thermometer to locate fish, show structure and water temperature. From your description, it sounds like the transducer portion of the Smartcast device has stopped working.
Transducers are both simple and complex, sturdy and delicate. Here is a Science Minute: A fish finder electrical signal is sent to the transducer. The electrical signal to energize the transducer crystal is generated by an amplifier. The energized crystal reverberates at a particular frequency, to convert the electrical signal into mechanical acoustic or sound energy. The acoustic energy or sound waves causes oscillation of the water molecules through which the sound travels. The sound is pulsed out in a defined beam. These do not travel out in a straight line but in a wave pattern. The acoustic pulse travels through the water at a rate of approximately 4800 ft (1500m) per second in saltwater and 4920 ft/sec in fresh water.
The problem is that the crystal in all transducers (permanent mount, thru-hull mount and castable) is delicate. It is a crystal. Unfortunately the warranty on most of these is six months, and unless yours is newer than that, you may need to buy a replacement castable. The handheld unit should still work. While I think the idea of knowing what is "over there" is a good one for shore fishing, I haven't bought these systems because I could never get over the idea that repetitive casting of a crystal, no matter how well-housed, was a good idea. Good luck.
Sep 27, 2011 | Humminbird Smartcast Rf35
I just bought a used boat with a Humminbird 160 fish finder on it but, the only thing that shows up on the screen is the temperature, NO DEPTH and NO FISH, is there a setting i need to set as i am clueless...
Check to make sure the transducer is hooked up correctly, and check the actual transducer for signs of damage. Transducers are fragile, and a good whack can break the crystal inside. For more troubleshooting, here is a helpful link with the Owners Manual for your Humminbird.
Aug 29, 2011 | Boating
Need to locate and print users manual for Humminbird Pironha Max 160 Fish finder
Aug 13, 2011 | Humminbird GPS
When we are deep water (500 ft or deeper) the fish finder will display 3.5-10 ft. and won't show the fish or shows tons of fish. Are we able to set the depth that we would like to see eg: if we are...
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
May 22, 2011 | Standard Horizon Standard Ff520 Fish...
Hi. Just wondering how should the transducer for my humminbird 525 fish finder/sounder be installed correctly? Thanks
You can take a picture of the transom of your boat and email it to Humminbird and they will email it back to you where the transducer should be mounted at. Our email address is service@humminbird.com.
Joby @ Humminbird
Dec 27, 2010 | Sport & Outdoor - Others
My furuno depth finder gives me crazy depth readings after i go over 10knots..whats the problem?
Turbulence on the transducer is almost certain. If transom mounted, **** it slightly deeper aft and ensure that the leading edge is not exposed. If through hull, call me 847-746-0100
Nov 03, 2009 | Furuno 1850WF Gps Fish Finder Combo...
CAN I POWER MY FISH FINDER GOING DIRECTLY TO THE
Yes you can. Basically the red wire goes to the fuse box connection. The fuse box should then be wired into the positive battery terminal. The black wire is the negative ground wire and needs to go directly back to your negative battery terminal or to a common negative buss bar.
Jun 15, 2009 | Humminbird Fishfinder 565 With Transom...
Navman 4500 fish finder w/transom mount transducer
I finally got an email reply from Navman. If the unit is less than two years old (mine is not) they will repair it. If it is over two years old, or if you can't prove that it is less than two years old, you can ship it to them and they will repair it for the low, low price of 355 US dollars.
Pretty nice of them since it appears these units are highly problematic isn't it? I am wondering if they guarantee their fix, or just have you on the hook for another 355 dollars later.
Good Luck Everyone,
Walt
Sep 20, 2008 | Navman F4100SX Fishfinder - W/ Transom...
HUMMINBIRD PiranhaMAX 160 Logo
60 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
