How to delete projects from beatmaker 2 on ipad 2
How do I open the deleted browsing history on my iPad?
You need to recover the deleted browsing history from your iPad. Restoring your device from iTunes or iCloud will replace the existed data, so you can use an iPad date recovery to get back the deleted history only. How to Recover Deleted History on iPad
Jul 20, 2015 | Apple iPad 2 Wifi 16GB
Tip
How to Remove Songs from iPad in 3 Ways
Part 1. Delete Individual Songs from iPad
Step 1. Launch the Music app on your iPad.
Step 2. Tap "Songs" on the bottom to see all of the music on the device. Choose the individual track you want to delete and slide your finger to the left across the songs.
Step 3. Tap on the red "Delete" button to remove music from your iPad.
Part 2. Delete All Songs from iPad
Step 1. Go to the iPad's homepage and tap on "Settings" icon.
Step 2. Tap "General" > Select "Usage" > Choose "Music." The iPad will display how much space is taken up by music on your device.
Step 3. Tap "Edit" button on the top-right > Tap the red icon next to All Music > Tap on "Delete" to remove all songs from iPad.
Part 3. Delete Selected Songs from iPad with AnyTrans
AnyTrans is an all-around iOS files manager that made to transfer and manage all your iPhone, iPad, and iPod content, such as, music, videos, photos, contacts, notes, messages, apps, etc. You can freely add or delete songs from your iPad with AnyTrans.
Step 1. Download and install AnyTrans on your computer. Run it, and connect your iPad to computer.
Step 2. On the homepage of AnyTrans > Click "Audio" > Select "Music".
Step 3. Highlight the songs you want to delete and click the trash icon on the top-right of this window to delete the unwanted songs.
Resource from: How to Delete Music from iPad
How to Delete Music from iPad in Three Ways
on Feb 11, 2015 | Apple iPad Tablets & eReaders
How do I delete all the contacts
read your instruction manual .
Mar 14, 2015 | Apple iPad 2
How to delete music files from ipad?
You should try iPhone Data Eraser. It's designed to erase data completely from iPhone/iPad/iPod. Here are steps about How to Delete Music from iPad.
Step 1.Install iPhone Data Eraser on the computer and connect iPad with computer.
Step 2.Choose "Erase All Data on Device" on the list.
Step 3.Delete music on iPad. "Medium" level is the most common choice. Click "Start" to erase.
It's so convenient. You can not miss it!
Jul 30, 2014 | Apple iTunes
How do you permanently delete pictures from an iPad 2 that have previously been deleted?
normally with a full restart of an iPad the cache/trash is cleared.
- but to be more safe I recommend to do a restore and connect the iPad to a computer with iTunes. Through iTunes you can do a factory reset of the device.
just be sure not to sync the photos on iTunes.
-iPad restart is done by pressing the sleep button for 5 secs.
then a slider appears where you can turn it off:
permanently-delete-pictures-from-ipad-2-idhgrcvb3gwnj1x0htsxmiux-3-5.jpg permanently-delete-pictures-from-ipad-2-idhgrcvb3gwnj1x0htsxmiux-3-9.jpg permanently-delete-pictures-from-ipad-2-idhgrcvb3gwnj1x0htsxmiux-3-14.jpg
Jun 23, 2014 | Apple iPad 2 Wifi 16GB
I need to delete 4000 emails from my ipad
. Your ipad does not store those emails on your ipad so if you are having a storage problem, that won't fix it. To delete all the emails though, you have to go to the email account itself and delete them from there.
Mar 28, 2014 | Apple iPad 2 tablet 16GB 3G
Remove baidu from iPad
Have you installed a Baidu app on your iPad and wanna remove it?
Well, the first method recommended for you is to directly delete apps from Home screen on your iPad.
1. You only need to keep touching the icon of the app until it wiggles with an X at the upper left corner.
2. Then tap the X and choose "Delete" in the pop-up dialog. You will get the apps deleted with no efforts.
Sometimes you cannot see the X and don't know how to delete apps on iPad directly, you can check the Settings at this moment. Then you can try to delete the apps on your iPad again.
1. Check the "Settings", then scroll down a bit and tap on the "General" option.
2. Tap on "Usage" (older version of iOS) or tap on the "Storage & iCloud Usage" (newer version of iOS).
3. You need to tap on "Manage Storage" and you'll see a list of all app installed on your iPad. Simply select the app and tap on "Delete" to delete that app.
There are also some other methods to help you remove unwanted apps from your iOS device. Click the following link to know more.
How to Delete Apps from iPad
Dec 09, 2013 | Tablets & eReaders
Delete photos from my apple ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to remove the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to remove from the iPad under the Sync Photos from heading.
5.If you want to remove all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
More detailed guide about how to delete photos from iPad.
www.iphone-mac.com/how-to-delete-photos-from-ipad-camera-roll.html
Nov 04, 2012 | Apple iPad 2 lack Tablet PC
How to delete photos from the Ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to delete the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
4.Uncheck all of the albums or folders that you want to delete from the iPad under the Sync Photos from heading.
5.If you want to delete all of the photos - uncheck the Sync Photos From heading
Done.
If it can't work, you can refer to the article about Delete photos from iPad.
Good Luck!
Jun 25, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Deleted video on iPad 2 by accident
Do you live in the United States? If you do then you can download them again for free - as long as the movies are available for free downloads. Apple has not forged agreements with every movie studio yet so you just have to check.
Launch iTunes, and tap on the purchased tab. In the upper left corner you will see a "View" button. Tap that in order to toggle among music, TV Shows and Movies. Select Movies and then see if the movies appear. If they do, tap the Movie icon and then tap the cloud icon next to the icon in order to begin the download.
You have to use the same Apple ID that you used to purchase them.
If you do not live in the U.S. then you will have to purchase them again.
Besides, I do like to share you another tutorial recovery deleted video from iPad 2, hope it can help you.
Apr 11, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
