Question about Furniture
Harvard layball baseball game part
Need to find replacement baseballs
marked
  • 6487 Answers
SOURCE: backyard baseball 2009 mouse problems
So you're saying that mouse is not working with this game only?? If that's the case you can adjust some settings on this game set all to low because sometimes even when your computer meet the minimum requirements you wont be able to use the mouse properly....
Hope that helps.........
Posted on Jul 28, 2008
SOURCE: Backboard is broken and need it replaced.
I had a steel plate made, to go behind the plexiglass and bolted that plus the plexiglass that was broke back in place, it works fine now, drawing attached, I had it made of 16 ga. S.S.
Posted on Jan 28, 2009
SOURCE: I need written instructions for EA Sports MVP Baseball for Gamecu
hope these are the right ones
MVP Baseball 2005
BATTING
Z Button Z + A Button = Square to Bunt (release to pull back)
A Button Swing
BASERUNNING
Control Pad Steal / Choose base destination (press toward base you are trying to steal)
Slide Refer to EA SPORTS Big Play Control in Gameplay below.
C Stick Left/Right = Increase/decrease leadoff.
X Button Control runner at 1st
B Button Control runner at 3rd
Y Button Control runner at 2nd
L Button Advance/stop all runners
Z Button Advance/stop all runners
R Button Retreat runner
PITCHING
Control Stick Choose pitch location.
A Button Throw a pitch
X Button Throw a pitch
B Button Throw a pitch
Y Button Throw a pitch
White Button (press and hold) + Directional Pad Up/Down (Left/Right to toggle between bullpens and dugouts) = View Bullpen/Dugout menu
R Button Throw a pitch
L Button + X, B or Y = Pickoff attempt. L + A = Pitchout. L + Control Pad Down = Intentionally hit the batter. L + Control Pad Up = Intentionally walk a batter.
Z Button (Hold) + Control Pad Up/Down = Choose infield/outfield alignment (before pitch). Left/Right to choose a category. Z Button (hold) + C Stick Left/Right = View pitch history, to toggle at bats. Z Button + Control Pad Up/Down = View Bullpen/Dugout menu (Left/Right to toggle between bullpens and dugouts).
FIELDING
Control Stick Move fielder
C Stick EA SPORTS Big Play Control
A Button Throw to home (press and hold to power up, release to throw)
X Button Throw to 1st (press and hold to power up, release to throw)
B Button Throw to 3rd (press and hold to power up, release to throw)
Y Button Throw to 2nd (press and hold to power up, release to throw)
R Button Throw to the cut-off man
GamePlay:
EA SPORTS PURE SWING SYSTEM:
The Strike zone is divided into nine colored squares. Red squares mark the batter's hot zones. Blue squares are the batter's cold zones. Clear squares are neutral for the batter.
Take unprecedented control at the plate by moving the Control Stick during your swing.
-The results of your swing depend on your timing, the location of the pitch, and the direction you move the Control Stick.
-For the best results, move the Control Stick towards the location of the pitch.
-To hit the ball in the air, move the Control Stick Diagonal Up-Left / Up / Diagonal Up-Right while swinging. This increases the chances of hitting a fly ball, but also increases your chances of missing the ball if the pitch isn't up in the zone.
-To hit the ball on the ground, move the Control Stick Diagonal Left-Down / Down / Diagonal Right-Down while swinging. Keep in mind that high pitches are very difficult to hit on the ground.
-To hit the ball to the left, move the Control Stick Diagonal Left- Down / Left / Diagonal Up-Left while swinging. For the best results, use this when the pitch is coming in on the left side of the plate.
-To hit the ball to the right, move the Control Stick Diagonal Right-Down / Right / Diagonal Up-Right while swinging. For the best results, use this when the pitch is coming in on the right side of the plate.
TO THROW A PITCH:
1. Press and hold the button that corresponds to the pitch you want to throw. The bar inside the pitch meter begins moving.
2. Release the pitch button when the bar reaches the end of the pitch meter. The closer your release point is to the end of the meter, the more effective the pitch is.
3. Press the pitch button again when the bar is within the green accuracy zone near the beginning of the pitch cycle to determine the pitch's accuracy.
-The effect of a bad pitch depends on the type of pitch. For example, ineffective fastballs are slower than normal, and less effective breaking pitches are flatter.
-If a pitcher misses the green accuracy zone by a considerable amount, an indicator (red for hot zone, blue for cold zone, yellow for ball, white for neutral) appears to tip off the batter to the location of the pitch.
PITCH SELECTION
Your pitcher's pitch selection appears on-screen. Not all pitchers have the same arsenal of pitches. A pitcher's four-seam fastball is always assigned to A Button. The remaining pitches are assigned to X, B, Y and R Button (though not all pitchers have five pitches).
FIELDING
-If you power up the throw into the red zone, you throw harder, but less accurately, which could result in an error.
-If you select to throw to either a base or the cut-off man before the ball arrives, the fielder begins his throw immediately upon receiving the ball.
NOTE: The CPU automatically adjusts your defensive alignment based on the situation. However, you can override this by choosing the infield and outfield alignments yourself.
EA SPORTS BIG PLAY CONTROL:
Using the all-new EA SPORTS Big Play Control, you can climb the fence to rob home runs, make spectacular diving catches, slide around tags, and more.
FIELDING:
- To dive or stretch for a ball just out of your reach, move the C Stick Left/Right toward the ball.
-To climb the wall to snag a would-be home run or jump for a ball over your head, move the C Stick Up.
-To make a sliding catch, move the C Stick Down as the ball approaches.
BASERUNNING
Timing is the key to a perfect slide. Use EA SPORTS Big Play Control to create havoc on the base paths.
C Stick:
Up = Head-first slide
Diagonal Up-Left/Up-Right = Head-first slide to the left/right side of the bag
Down = Pop-up slide
Diagonal Down-Right/Down-Left = Hook slide to the right/left side of the bag
Up = Dislodge ball from catcher.
Posted on May 19, 2009
  • 285 Answers
SOURCE: Picture too big
It seems as if your tv is in "crop", "Zoom", or "full" mode. Select letterbox, normal, or full-screen mode. Look in the manual for exact instructions.
Posted on Jul 15, 2009
  • 82 Answers
SOURCE: installation code mvp baseball 2005
noone here can help you with the registration/license code. you need to contact the developer.
Posted on Jul 30, 2010
Can anyone give me some tips regarding baseball?
If you are a baseball player then these tips are useful for you:-
1. Dedicate yourself to the baseball.
2. Practice every day.
3. Talk with your coach or trainer to strengthen you in baseball.
4. Play up to your level.
If you want to know more guidelines regarding baseball, then you go this youtube channel https://www.youtube.com/user/airplouffe86 where you can get all tips and guidelines regarding baseball.
Sep 27, 2017 | Baseball & Softball
Tip
Using the right Baseball Glove.
Never use a baseball glove until it is properly naturally conditioned. New stiff gloves hurt a players game more than any other factor. (Errors Galore) Go to Glove Whisperer.com and learn amazing facts on baseball glove buying and conditioning and the importance of using a proper glove.
on Sep 01, 2014 | Baseball & Softball
I've stated playing baseball a few months ago. Normal running shoes are not comfortable. Looking for a good shoe - any thoughts guys?
If you are going to play baseball, regular shoes won't suffice. Baseball cleats are specially made for baseball and are required on most levels of league play. Here are some instuctions on how to choose the best shoe for you:
1.Find out what type of cleats are allowed in your baseball leagues.
2.Locate a store in your area that specializes in baseball apparel. Use your phone book and look under the baseball listing to find specialty baseball stores.
3.Try on the baseball cleats at a local store. Baseball cleats are different than other types of shoes, and the sizes might not correspond exactly to your regular shoe size.
4.Shop around for prices once you have found the right pair of cleats for you. You can look in different shoe stores to locate the lowest price, as well as look at online baseball apparel shops.
Oct 27, 2010 | Clothing Accessories
Backyard baseball won't fill entire screen on laptop pc
Go the game settings and select "Full screen" or change the game resolution.
If you need further assistance please post.
Thank you
Mar 04, 2010 | Humongous Entertainment Backyard Baseball...
UPS MGE problem
  1. old school hollywood baseball old school hollywood baseball old school hollywood baseball
  2. old school hollywood baseball old school hollywood baseball
  3. old school hollywood baseball old school hollywood baseball
  4. v
Feb 05, 2009 | Computers & Internet
How do i power my passbook(we)
old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Feb 03, 2009 | Computers & Internet
Flip down monitor
Feb 01, 2009 | Nesa Vision NESA NSCM-1040 Overhead Flip...
идуфсйж гуй н ифдуг идфу бх
old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Jan 31, 2009 | MGE Galaxy 3000 UPS System
Furniture Logo
89 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
