Question about Husqvarna Designer I
Bobbin rewind broke off, on my designer one, how can I replace it
The plastic broke into and some parts are inside machin
    Novelist:
  • 268 Answers
Take it to a repair shop for replacement. Ought to be a warranty repair, I believe.
Posted on May 22, 2014
JeremySew
  • 65 Answers
SOURCE: Designer II
Hi Beckham363,
I'm not completely familiar with that particular model but can offer some general advice. In the middle of your crank wheel on the top right of the machine, there should be a smaller wheel inside that. You need to turn that towards you until it doesn't come any further. The know you turned is going to feel lose, that's good! Now if you look on the top of your machine on the right, there should be a small shaft coming up about and inch high. You need to then put your bobbin on the shaft and push it to the right. What that does is connect the bobbin winder tire inside your machine to your hand wheel which is connected to the motor via your belt. Now just thread your bobbin case and push your foot control! If you have any more questions just let me know and I'll be glad to take pictures if needed. Also you can purchase a side bobbin winder pretty cheap on my website here:
<br />
<br /><a href="http://sewingpartsonline.com/wright-s-bobbin-side-winder.aspx">http://sewingpartsonline.com/wright-s-bobbin-side-winder.aspx</a>
<br /><br />
Let me know how it turned out! <br /><br /><br />
- Jeremy<br />
<a href="http://sewingpartsonline.com">http://sewingpartsonline.com</a>
Posted on Dec 04, 2008
  • 76 Answers
SOURCE: Husqvarna Viking C-10. Bobbin Case broke, dealer
check this site out, I find a lot of good stuff on it
www.cutsewservice.com
Posted on Aug 28, 2009
  • 371 Answers
SOURCE: The stitch bunches on the bobbin side. The Viking
Parts are still available. Make sure you are using an authorized Husqvarna Viking dealer. Check the Husqvarna Viking website for dealers in your area - http://www.husqvarnaviking.com/us If the dealer is unable to fix or get parts, have them send the machine to Husqvarna Viking Service Technician headquarters in Tennessee. They can repair or rebuild parts no longer available. Also parts may be available from third party = http://www.pd60.net. Good luck.
Posted on Sep 25, 2009
  • 152 Answers
SOURCE: bobbin winder plastic part came off, now it won't
You must put that black ring back on the sewing machine. It will not work without it. There is a groove in the black plastic part that lines up with the black metal "fin" that is in the middle of the bobbin winder. Put the "fin" in the 12 O'clock position and line the groove up at 12 O'clock as well and push it onto the spindle. It will "click" when you have it on all the way.
The reason it got pulled off is because the thread has too much tension on it as the machine was winding the bobbin and it crushed the center of the bobbin onto the spindle and the black piece that pulled off the machine. If you are winding the bobbin through the needle you must go under the presser foot, (always have the foot in the up position)and the foot must be a metal one and you DO NOT put the thread over the silver button like guide on the right side of the machine to wind the bobbin. That guide is a tension device that is used to put tension on the thread when you use the guides on the rear of the machine instead of the regular path through the needle. If you use the normal thread path through the needle and that button like tension device, it creates too much tension on the thread and wraps it too tightly on the bobbin, some it even breaks in half. You can also have bad stitching even if you get the bobbin off the machine because it can distort the shape of the bobbin which can cause it not to spool properly so you sewing tension of the bobbin is compromised.
Posted on Oct 12, 2009
  • 201 Answers
SOURCE: I have a designer 1
It sounds as though maybe the bobbin thread is not "clicked" into the tension slot correctly. You need to be sure it goes into the slot and you can hear/feel it seat itself in there. As a last resort, you can tighten the bobbin tension. Take the bobbin case out. On the side there is a recessed screw. If you think of it as a clock, turn the screw in no greater than 5 minute increments - to the right to tighten, to the left to loosen.
Is your machine sewing regular stitching (i.e. not embroidery, hoop off) okay or is the bobbin thread not right for that either? Next time you have your machine serviced, be sure to take in your embroidery unit too so the technician can set it up to be good for both ordinary sewing and for embroidery. I actually have a second bobbin case that I adjust if necessary for whatever project I'm working on that needs anything other than "default" setting for the bobbin. Thay way, I'm not messing about with the bobbin that has been set correctly by the technician but you can easily adjust your bobbin if it needs it. Just remember to put it back to "normal" when you are done.
Posted on Dec 05, 2010
My machine inside hand wheel will not turn back after I ran a new bobbin. Help please
-Did you unlock the Inside wheel when you rewind new bobbin ?
If so then lock it back on.
Good luck
Mai
Nov 01, 2017 | Sewing Machines
Bobbin winder screw broken, how to replace?
Until you can get your bobbin winder repaired, I'd suggest picking up a bobbin winder at your local fabric store. The last time I noticed, they cost about $30. Many sewists prefer to use this little accessory inside of wearing out the bobbin winder on their sewing machine. Also, if you more than one thread cone, you can rewind bobbins without unthreading your sewing machine.
Jun 19, 2014 | White Sewing 1418 Mechanical Sewing...
The black plastic piece the bobbin fit in is broken.
You may have a timing problem or bent needle. You will need to replace the bobbin basket if it is damaged.
Jan 28, 2014 | Singer 7466 Mechanical Sewing Machine
Bobbin rewinder won't work
it's possible that there is a part inside the machine that could be broken, it would be a good idea to have the machine checked.
Jun 23, 2013 | Kenmore Sewing Machines
Bobbin winder won't work
it needs to be taken to a repair shop to be readjusted
May 20, 2012 | Singer Sewing Machines
Want pick up my bobbin
re-thread the top thread
when putting in the bobbin, make sure you put it in right,
hold the bobbin between you thumb and first finger of your right hand when you pull the thread with left hand it should rotate the bobbin counter clockwise.
If you run your machine all day you need to clean under the bobbin case,
Take the cover plate off, take out the bobbin case and clean under, i take a q-tip with machine oil and rub around the inside of the metal case and around the bobbin case,
replace the plastic bobbin case making sure it's in right, turn the hand wheel by hand, the case should stay still and the inside will move, the needle should not hit anything
put all back together and try again
if the bobbin turns clockwise you are going to have problems
if this helps please rate it
thanks,
good luck
moni
May 09, 2009 | White Sewing White 4400 Computerized...
Designer II
Hi Beckham363,
<br />
<br /><br />
- Jeremy<br />
Dec 02, 2008 | Husqvarna Designer I
Bobbin won't wind
The bobbin rewind unit needs to be inspected. In order to do that the covers have to be removed. It could be the wiring to the board may be disconnected or the rewind unit is just broken and needs to be replaced. You might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jul 25, 2008 | Husqvarna Designer I
Rewinding bobbin
many old machines have problems with worn out parts check the link attached , perhaps it is a good alterative https://www.walmart.com/search/?query=bobbin%20winder&typeahead=bobbin
Mar 30, 2017 | Sewing Machines
Sewing Machines Logo
32 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
