Question about Jabra COMMUNICATIONS BT160 Bluetooth Headset Headset
Motorola oasis calling last number
Calling last number with touching phone
How do I program my phone for speed dial ?
  1. From the Home screen, touch Apps > Phone .
  2. Touch the first digit of the speed dial number.
  3. Touch and hold the last digit to start the call.
  4. For example, if you want to call speed dial number 25, touch 2, and then touch and hold 5.
Mar 23, 2016 | Lands Phones
How to blacklist a caller on motorola andriod 3 phone
I think you can block up to 5 numbers from calling/texting when you manage your VZW account online. It will block the numbers for 90 days only, though, at which time you have to reblock it. If you subscribe to Usage Controls, you can permanently block up to 20 numbers.
Memo
Motorola Support
Jul 26, 2014 | Motorola Mobility Verizon Droid 3 3g Touch...
Why does Motorola H19txt continuously recall last number dialed ?
You can try by reseting the Bluetooth Headset this will help.
You can find the steps for the reset on this link.
How do reset the H19txt to factory default
Jun 27, 2014 | Motorola Mobility H19txt Universal...
How do i operate speed dial on razr
The user manual for the Moto Razr V3 is at: "V3 GSM Motomanual" Motorola http://www.motorola.com/mdirect/manuals/V3c_9496A74O.pdf
Pages 68-69 of the manual (which correspond to pages 70-71 of the PDF file) state: "Calling With 1-Touch Dial To call phonebook entries 1 through 9, press and hold the single-digit speed dial number for one second. You can set 1-touch dial to call the entries in your phone memory phonebook or the SIM card phonebook: Find the Feature M> Settings > Initial Setup > 1-Touch Dial Press To 1 S scroll to the location you want 2 SELECT (+) select the location" Page 8 (page 10 of the PDF file) indicates that the symbols (represented by "M>", "S", and "SELECT (+)") mean the menu key, 4-way navigation key, and SELECT. Page 51 (pages 53 of the PDF file) explains how to store phone numbers in the phonebook -- which you can then call with 1-touch dial.
Aug 24, 2011 | Motorola Mobility RAZR V3
Once I unlock the LG Touch phone and press the phone button. it automatically calls the last call displayed. It has returned calls unintentionally by dilaing on its own once the the first dial button is...
Try resetting the settings and see if it helps.
Steps to Reset Settings
Restoring default settings will reset Sound, Display, Phone and Call Settings to factory default specifications.
  1. From the main screen, touch Menu.
  2. Touch Settings & Tools.
  3. Select Phone Settings.
  4. Touch Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Touch Reset Default.
  7. Touch OK.
Mar 14, 2011 | LG enV Touch VX11000 Cell Phone
How do I find the pin number on a motorola sb5101n
  1. Enter the last four digits of your phone number on your cell phone PIN screen. When setting up a cell phone PIN, the default number assigned is the last four digits of your cell phone number for most cell phones.
  2. Enter 9999, and if that doesn't work try 1111. The number sequence 9999 and 1111 are other standard numbers assigned when choosing a cell phone PIN.
  3. Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number under the battery. Reinsert the battery and power on the phone. Enter the last four digits of the IMEI number on the PIN entry screen. The last four digits on your IMEI number can occasionally be the service provider's preset PIN for the cell phone.
  4. Call your service provider and request the PIN. You will have to prove you are a customer by stating your cell phone number, address and Social Security number.
  5. Turn off your phone. Hold the keys "3," "*" and "Call" and switch the phone on. Hold the three buttons down until the word "Formatting..." appears on the screen. This should reset the phone lock code.
  6. Go to one of the links in the Resources section and have your IMEI number ready. These websites will ask for your phone model and IMEI number and then charge you a set fee for the unlocking PIN.
Mar 13, 2011 | Motorola Computers & Internet
I changed my lock code last night and forgot it
well try calling *228 from ur phone cause when i did that to update my phone it reset my lock code back to the last 4 digits of my mobile number.
Oct 22, 2009 | Motorola Mobility Hint QA30 Cell Phone
Unlocking i455 cell phone
Try 9999, 0000, or 1111.
If those don't work, try the last four of your phone number.
If that doesn't work, call Motorola.
Aug 22, 2009 | Motorola Mobility i455 Cellular Phone
Sprint motorola v3
you need to change the flexcable on the phone and also have the keypad flex reflash as well.
Jun 02, 2008 | Motorola Mobility RAZR V3
Possesed phone
Sounds like some sort of short in you keypad, possibly some water or liquid has come in contact with your phone?
You should seek service IMO.
Apr 25, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Jabra COMMUNICATIONS BT160 Bluetooth Headset Headset Logo
20 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
