Question about Ovens
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works, broiler works, but on the bake or conv bake/roast the oven doesn't want to heat up. After an hour plus will get to maybe 300.
  • Jane Middlesworth
    Jane Middlesworth Feb 12, 2014
    The oven is a Frigidaire wall unit. PLEB30S8CCA
  • Jane Middlesworth
    Already replaced bake element. Still didn't fix problem. Just removed control panel and sent it off to CoreCentric. Hoping that is the fix!
    Scholar:
    New Friend:
  • 111 Answers
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Posted on Feb 12, 2014
hotuna
  • 288 Answers
SOURCE: Oven not working in Bake setting
Visually inspect the element for any kind of rupture on the shield covering the element. If it looks good the next step is the wire connections at the back of the element. Most likely is has a burnt wire.You will have to pull the back cover off to check this.
Posted on Nov 04, 2007
SOURCE: Top burners work, but no broiler or bake operating
HAVING SAME PROBLEM. NO FIX YET.
Posted on Dec 28, 2008
hbsurfdawg
  • 95 Answers
SOURCE: heating element will not heat
With all that you said, I would suspect an open or faulty element. It is pretty much the most obvious solution.
If you have any electronically ability and you are going to open the oven, use an ohm or resistance meter, check the amount of ohms and use the upper element as a reference for the correct reading.
The element will either read open or good. You can use a light tester also and if the light lights between the two connectors of the elements, then it is ok and look elsewhere.
E
Posted on Mar 02, 2009
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Thermadore SMW272YP
The next thing that I would try would be the Thermal sensor...
Here is the thermal sensor kit...
http://www.appliancepartspros.com/part_details.aspx?part_id=2831584
heatman101
Posted on Jan 14, 2011
Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
if it is not coming on then you may have the same problem again with the ignitor.
May 04, 2014 | Ovens
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire PLEB30S8CCA baking element not working
Good Morning Jane, thank you for your post!
From what you have described, it sounds like you possibly have problem with a faulty thermal fuse, power supply board, user interface board or a communication error with the EOC (Electronic Oven Control). This is not a typical do it yourself job. Please reach out to an expert technician to ensure the appropriate replacement part(s) is ordered and is installed correctly to prevent future issues.
Best regards!
Feb 10, 2014 | Frigidaire 30 in. Electric Gallery Series...
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
Broiler element not working at all. checked element--it's OK. Called a serviceman-- he thought it was an oven sensor--replaced sensor ---no change Electronic clock some times shows a code "F2 ...
you do not say it is electric oven. if so broil element requires 240 vac. may be controlled by relay. Is bake element working? also controls for broil may be different setting if digital panel is in this design. I think same sensor may be used for bake or broil.
you do not say if gas oven, electric oven, single or double oven or if digital panel control, a little more information would help.
if you have digial voltmeter, FULLY disconnect electric power and measure element on terminals. probably less than 15-20 ohms for a good element.
Dec 28, 2010 | Ovens
Oven baking element failed, broiler element worked fine. I replaced the heating element and for 1 meal it worked fine. Now neither element works and the light on the panel does not go on. The stove works...
IF you have the correct amount of 220 volts power at the terminal block.then the only thing left is the main control board has failed and needs to be replaced.
Dec 02, 2010 | Tappan Ovens
After putting my 10 yr. old Whirlpool Model RBD276PD double ovens thru the self cleaning cycle the bake and broiler elements in the bottom unit stopped heating. All the controls on the panel work and the...
This sounds like it blew the thermostat on the back of the lower oven. They are inexpensive and easy to replace. You will need to uninstall the unit and remove the back panel to acess. Check it for continuity if none replace. This is a fairly common failure due to the heat of the self cleaning. Here is a link to your part and diagrams are also available there AP3055316
Sep 28, 2010 | Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
Ovens Logo
236 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
