Question about Sport & Outdoor - Others
Hammer wont grab bbs
When my gas blow back slide goes back it wont go far enough to grab the bb. i have to slide back by hand everytime. also there is a hesitation on the hammer i can pull the trigger an only someyimes it fires. i have took apart the grip and fix it but seems to mess right back up like 2or 3 clips later starts to do it again.... how do i fix these problems?
cammedic
  • 667 Answers
SOURCE: Mamiya RB67 ProS wont trigger or advance
Start by making sure the dark slide is removed, the camera will not fire with it in place. The next step is to check the rotating back to make sure it is locked in either the vertical or horizontal position. Without film in the magazine, the multi-exp lever on the back must be set to show the red dot under the advance lever. You can check the camera without the back by removing the rotating back using the latch on the bottom of the camera
Posted on Dec 23, 2007
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Front shifter problems
take the grips off and wrap some friction tape around the handlebars about half to three quarters the length of the grip from the end of the bars. then put the grips back on. shouldn't need more than 3 layers of tape
Posted on Jul 31, 2009
SOURCE: my mower is getting fire and gas but all it will
sounds like the fly wheel key is sheared making the engine out of time. Check and make sure you dont have a bent blade too, When the blade hits something the key will shear off so it doesnt damage other things but the blade may be bent as well
Posted on Aug 11, 2009
  • 20 Answers
SOURCE: Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
Posted on Aug 17, 2009
SOURCE: crosman c11 clip problem
What i did was i get a screwdriver and inserted where the bbs go then push a little down so the metal would expand a little.Hope its helpful
Posted on Jun 05, 2010
Loaded w/bbs fresh gas cylinderwill not fire or does notshoot BB?
it sounds like you have a bb jammed in it
Oct 24, 2013 | Toys
How do you load a Marksman .177 BB pistol & does it require a co2 cartridge and if so where does it attach to the pistol?
most dont i have one but pull down the barrel and put a bb in it then pull it back up take saftey off then u should be able to shoot
Nov 26, 2012 | Marksman 177 Cal, 5.1 Grains, BB...
Benjamin Franklin BB Gun, Model 310 BBs appear to be too big to fit the hole in the bolt. Safety is missing.
insert bb in front of bolt,,, i think the little hole on side is for air to flow behind bb. i thought the same thing about mine but thats the only thing i can figure.... as far as the safety being gone its not a big deal unless you are trying to sell or something
Mar 19, 2011 | Garden
How to change the back brakes
Center stand the bike, remove the rear drive axle nut and bolt , take out the spacer, spin the nut off the brake cable , and unbolt the long brake panel stopper bar at the brake panel . Now you should be able to slide the panel out of the wheel and remove it. If there is not enough room to remove the panel , push it back in to the wheel and grab the whole wheel sliding it off the final drive spline. Now roll the wheel back far enough to pull the brake panel out of the wheel and replace the shoes . Be sure to regrease the final drive spline with MOLY60 grease available at the Honda dealer before sliding the wheel back on.
Aug 17, 2010 | 1984 Honda VF 750 S
I work the lever to load one BB. then pump 6 or 7 times. BB will not shoot out. When I pull the trigger, it sounds like it is shooting, but no BB comes out. this is for a crosman 760 pumpmaster. it...
Can you see through the barrel? Or run a rod down the bore? It sounds like the BB is either falling out the end of the barrel or the BBs are getting jammed up in there. Do not hold your hand in front of the barrel to see if any air comes out. You might get stung with 10 BBs. Hope this helps.
May 22, 2010 | Crosman ® Quest cal. Air Rifle with 4x32...
I have a Daisy CO2 200 pistol and it won't fire the bb's. Wasn't there some process for moving the bb's around to be fired? Also, the slide on the left side of the pistol doesn't do anything, what was it...
After loading BBs in the rear of the gun (by moving the slide cover and inserting BBs one at a time), push the slide upward with your thumb while pointing the muzzle of the pistol in the air and rotate pistol--this should charge the magazine.
Also, change the CO2 cartridge. They will leak out depending on the seals condition. Remove the left grip and turn the lanyard screw down to access the cartridge. While the grip is open, add a drop or two of 3-in-1 oil into the oil well on the bottom of the receiver.
Nov 01, 2009 | Sport & Outdoor - Others
Battery
Several suggestions:
Put 7130 on table face down.
Grab sides of BB with thumb and middle finger of one hand at the bottom of the cover where it has the larger part.
with other hand, use index finder to push down the locking button while shifting with the first hand.
Or:
attach a four inch lenth of scotch tape on the battery cover with the loose end hanging off the bottom to use as a pull tab.
Then use a finger nail to depress the release button just a slight amount. It's important to press down on the top edge of the button. Also it is very important not to press to hard because the amount of downward movement to release it is very small. If you press it down too far it binds and prevents the latch from releasing.
The key is to use the pull tab you made from tape to slide the cover off once you have released the latch.
or:
1. Take a letter opener or a flat head screw driver and push down on the top portion of the tab. The tab is located on the back side of the phone at the bottom.
2. Don't push down to hard
3. While pushing down use your free hands thumb to push down and slide the cover off the bottom of the phone.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | RIM Blackberry 7130e Smartphone
Crosman c11 clip problem
Mar 29, 2009 | Crosman (4032)
Sport & Outdoor - Others Logo
142 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
