Question about Refrigerators
Water dispenser not working
My water dispenser doesn't work. Ice maker will dispense ice, I don't know if it will fill/make ice. I hear a click when I depress the dispensing button and it clicks when I let go. I hear an humming/buzzing sound as if it were trying to dispense water, but nothing comes out. I have checked my water line and there is water coming out with good pressure. If I let it sit for a few hours and try the water again, I get a very small amount of water out of it at a low pressure, then the water stops. Thanks
    Prodigy:
    An expert who has answered 500 questions.
  • Refrigerators Expert
  • 650 Answers
Have you changed the water filter? they can plug up over time. The water tube can freeze in the door. To test this there usually is a disconnect under the freezer door side of the grill you can disconnect this and hit the water dispenser lever. If the door is getting water then it is frozen in the door. If not the water valve could be your problem there are two sides to the water valve one for the water dispenser and one for the icemaker. A last possibility is there is a water tank or tubing loop in the refrigerator behind the crisper this could have frozen.
Posted on Feb 14, 2014
huuum
  • 750 Answers
SOURCE: water does not come out of the refrigerator door, but the ice works
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, When the water dispenser is pushed you can hear it try to work (a humming or pumping sound) but nothing comes out.
Below is a list of reasons that the water may not be working that are easily checked and remedyed by you! Is there a water shut off on your fridge?If so the dispensor will still make noise as if it is trying, even if it is locked!!!!!!!!!!!!!!!!!!!!!!!
1. When did you change the internal water filter last?
You can remove the water filter and still use the water dispenser to check if the filter may be the problem!If nothing changes reinsert the water filter.
2.Flushing the water system after replacing filter
Use a sturdy container to depress the water dispenser bar until
the water begins to flow. Flush the water system by dispensing
and discarding 2 to 3 gal. (8 to 12 L) of water. Cleaning the
system will take approximately 6 to 7 minutes and will help clear
air from the line. Additional flushing may be required in some
households.
NOTE: As air is cleared from the system, water may spurt out of
the dispenser.
3.***Read this:
The dispenser lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
accidental dispensing by small children and pets. To turn off the
dispenser, press the LOCK button. The indicator will appear
above the LOCK button and the ice and water dispensers will not
work. To unlock the dispenser, press the UNLOCK button until
the indicator appears. Then continue to dispense ice or water as
usual.
NOTE:********** The lock feature does not shut off power to the product,
to the ice maker, or to the dispenser light. It simply deactivates
the dispenser levers.
4.The water dispenser will not operate properly
 Has the water system not filled? The water system needs
to be filled the first time it is used. Use a sturdy container to
depress the water dispenser bar until the water begins to
flow. Flush the water system by dispensing and discarding
2 to 3 gal. (8 to 12 L) of water. Cleaning the system will take
approximately 6 to 7 minutes and will help clear air from the
line. Additional flushing may be required in some households.
See the “Water and Ice Dispensers” section.
 Is the water shutoff valve not turned on or the water line
connected at the source? Make sure the water shutoff valve
is turned on and the water source is connected to the
refrigerator. See the “Water Supply Connection” section.
 Is the water shutoff valve clogged or incorrectly installed?
See the “Water Supply Connection” section. If clogging or
installation is not a problem, call for service or contact a
plumber.
 Is there a kink in the home water source line? If you find or
suspect a kink in the water line, call for service.
 Is there a water filter installed on the refrigerator? The
filter may be clogged or incorrectly installed. First, check the
filter installation instructions to ensure that the filter was
installed correctly and is not clogged. If installation or
clogging is not a problem, call for service.
Please remember to leave a rating before you go!
Thank you,
Huuum
Posted on Sep 29, 2008
  • 489 Answers
SOURCE: water dispenser not working
2 possible problems.
#1 water valve for the water side is stuck in the closed position.  Only way to tell is to pull the bottom kick panel out and look for the water line disconnect.  Separate the line, close the door and try to draw water through the dispenser.  If the water comes out of the disconnected line, then the water valve is good.
#2  if water is coming out of disconnected line, then the problem is in the freezer door.  There is a heater that keeps the water line from freezing inside the freezer door.  It is not repairable!!  The freezer door has to be replaced.
Posted on Apr 27, 2008
RescueTech
  • 145 Answers
SOURCE: GE Fridge Not Dispensing water
First place to start is in the fridge. Look behind the crisper drawers for the water tank. It may have frozen at the outlet line. Try thawing it out with a hair dryer or a heat gun, being careful of course not to melt anything.
Posted on Dec 13, 2008
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
aasc
  • 1606 Answers
SOURCE: no water is being dispensed from the water
Start by : at the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . Ge also has a dispensor heater , pt # WR49X10173 , with instructions , to keep this freezing from happening again , if this is the problem .
Posted on Jan 20, 2010
Testimonial: "excellent and easy to follow advise"
I have a clear view ice maker and it fills fine and makes ice but it don't empty
Its issue with icemaker auger or dispenser assembly.Ice maker assembly has to be replaced.If any auger or auger motor is faulty.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
FRIGIDAIRE FRS26ZSG - WATER DISPENSER
Is there an overflow module that connects the icemaker to the water dispenser? If you are still getting ice, it is probably just extra water.
Jun 03, 2008 | Frigidaire FRS26ZSG
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
I recently replaced my water filter on my Kitchenaid side-by-side refrigerator, model KSCS251, and since then my icemaker no longer makes ice, nor do I hear any water flow into it. The water, however, does...
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips
Jun 16, 2011 | KitchenAid KSCS25FKSS Side by Side...
Water is not working
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem.
If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Jul 12, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
Our icemaker does not fill with water
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I just replaced ice maker assembly because of broken plastic which holds drive gear. Now the new ice maker will not fill up with water. Water dispenser works fine.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Sep 02, 2009 | Refrigerators
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
No water from the dispenser
You need to replace the dual solenoid one side is for the water the other is for the ice.
Jan 18, 2009 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
171 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
