Astec AA23080 I have Astec AA23080 How to put on this psu without motherboard?
    Genius:
  • 1,552 Answers
You have to "short" two of the sockets.
Get the CORRECT two, or else you could kill yourself, or "fry" the power-supply.
Details: http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm about the "pin-out" arrangement.
It would be easier/safer to connect the sockets to a motherboard, and connect a power-switch to the ON/OFF pins on the motherboard, and then use that power-switch.
Posted on Apr 06, 2014
Rs psu 450 ac1n pinout
The three I have inspected, all of them failed due to the vent. It breaks down and makes the power supply to stop.
Nov 05, 2013 | Astec 450-Watt Power Supply
I just bought my new GIGABYTE RADEON HD6850 Overclocked Edition graphics card, i connected it in my motherboard (ASUS P5N-E SLI) and it seems working, the fans and stuff, but i get a black screen. I tried...
Hi, The recommended PSU for your card is 550W.
After you connect it to your motherboard you have to connect a (6pin) PCIE power connector
to the card. Without it the video card will not display anything.
Feb 10, 2011 | Gigabyte GV-R685D5-1GD RADEON HD 6850, (1...
I have a rosewell 530 watt psu and when i turn on the system it just turns on and off also i dont have the atx 12v 2x4 connected because dont know what plug to put dont have a 2x4 do i need to change my...
turn your PC on with another PSU.
maybe it is half-burned (it means that the device works but not correctly and without error)
so check it out and you couldn't make it do this:
intercept all of cables of your PC case and even power cable of your monitor.
evolve battery of bios then wait for 25 minutes then connect all of cables and try turning on your PC:
1- with battery of bios
2- without battery of bios
it should work.
(this works cause the motherboard reset it's bios and start correctly again).
Caution: "almost all of Gigabyte and Foxconn got this problem"
Jan 10, 2011 | Gigabyte GAP55USB3 Motherboard
My Acer Aspire One model D250 cannot power on even if i already put the power adapter.Is it the battery pack problem or the motherboard?
Firstly insert the battery. When you plug the PSU into the machine does a charging light turn on? If not then check the fuse in the mains plug as it may have blown. If the fuse is OK then you may have a defective PSU, although the motherboard could also be defective. Try a new PSU to determine if which component is faulty.
Now remove the battery and insert the PSU. Will the machine turn on or do any power lights illuminate? If power lights illuminate and the machine will not turn on then I would suggest the motherboard is at fault. If the machine turns on briefly the turns off before displaying the splash screen then I would suggest the RAM, CPU or motherboard is at fault.
If the unit works without the battery installed then it is probably a battery problem, although it is possible the charging circuit n the motherboard is fried.
Hope this helps,
www.PuterCare.com
Jul 03, 2010 | Computers & Internet
Got a astec sa302-3505 power supply . . . need to know how do you add a switch to turn it on if its not connected to the motherboard
Simple, Just connect a switch to Green wire and one of black wire.
When the green wire got connected with negative (Black wires are negative) the SMPS Fan starts which is also a visual feedback to you that SMPS starts.
----------------------O /
Grean /
-----------------------O
Black
So simple..
Jan 26, 2010 | Astec 300w AT Power supply 190170-01...
I need an ASTEC power supply model SA147-3506 for IBM P-2 computer, Can anybody help me??!!
145 Watt power supply with the old style AT motherboard power cable connectors. (2 Each)
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
I just put Astec SA147-3506 in my browser search bar, and came up with a number of search hits. Prices ranged from $50 to $170!
And it's a 145 Watt power supply! Astec is a cheap quality power supply manufacturer, to boot!
You know, there is a way to use a newer reliable power supply, and the AT power supply motherboard connectors, off of the power supply you have.
It's not for the squeamish, but can be done.
The power wires are removed from the ATX power supply motherboard cable connector, of the new power supply, and inserted into the AT power supply connectors.
(ATX 12V power supply is the newer one. AT power wires removed from the P8, and P9 connectors of your old power supply)
Interested?
Jan 20, 2010 | Computers & Internet
I am looking for a manual and troubleshooting manual for a astec 73-180-0029 POWER SUPPLY
Look it up on the internet you should be able to find one. Try the www.astec.com website first.
Nov 19, 2009 | Astec Computers & Internet
Comp not firing up
Something may be shorting out the board. Try taking the motherboard out and turning it on without the case. Just put the motherboard and power supply on a non-static surface. A box works well. Then use a flathead screw driver to temporary "jump" the 2 power switch pins for the front panel connection (as you wont be turning it on while inside the case).
If that doesnt work, then replace power supply. You could also take one out of another working computer just to test.
Jun 18, 2008 | EliteGroup K7VMM Motherboard
Computers & Internet Logo
228 people viewed this question
David Payne
David Payne
