Question about GE Security Simon Xt Wireless Control Panel 40 Zones
Simon XT "system low battery"
"System low battery" regularly sounds. I unplug and replug the unit back in after 30 seconds. Then it says "system ok". Then a short time later it's back to system low battery. I pulled the battery and it tests out at 6.55v. Perfect! Reinstalled and all was well. Now it's back to "system low battery". The security company wants charge $75+ to replace a $15 battery that tests fine. Ant ideas?
  • GE Master
  • 15,633 Answers
IT might be testing ok, but you need to load test it. It could be the charging circuit but in most cases the battery will show a surface charge that is ok for a short period of time.
Posted on Feb 10, 2014
4 Suggested Answers
  • 5 Answers
SOURCE: System Low Battery
Response 1 is correct. If you plugged the transformer into an outlet before connecting the battery the system wont see the battery and give you that error. Should be a simple fix however. Unplug the battery and then the transformer, then reverse the process. Plug in the battery and your Simon should power up, then plug in the transformer. If this doesn't help then you should replace the battery. Did you buy the system from a dealer and have it professionally installed or did you do-it-yourself? If it was professionally installed have your technician come back out to diagnose/replace the battery if needed. Good Luck.
Posted on May 19, 2008
  • 3 Answers
SOURCE: Simon 3 "System Low Battery" after 3 years use
I install these panels.  For the low battery message to clear you need to power the system down completely.  To do this you need to unplug the battery and also unplug the transformer plugged into an electrical outlet.  When you power the system back up, you need to first plug in the battery leads.  Then the transformer.
Posted on Apr 21, 2009
SOURCE: Westinghouse Security System chirping
Those of you having problems with the beeping on the Westinghouse systems when the doors/windows open. The solution on the XL4600 is #6 this should slience that!
Posted on Oct 22, 2009
System says low battery ... how do I open it to replace batteries...very confusing!
There are two tabs (and possibly a screw) on the top of the Simon XT panel. Remove srew (if installed) and press the two tabs, pulling forward. Front part of panel is hinged and will rock forward. Battery is located behind front half. It is a 6 volt 1.2 Amp Hour lead acid battery.
You must completely downpower the Simon XT (wall plug in and battery) then replace with new battery first, then reconnect wall power. Close the front panel and snap it closedand replace the screw (if it was installed).You will need to set the time on the panel, following the instructions in the users manual.
Jan 05, 2011 | GE Security Simon Xt Wireless Control...
I have a GE Simon XT. I arm the system. When I return several hours later, the front door doesn't beep when I open it. I have to close/open it again to register. Front door is Sensor 1, Group 10. What...
Can I assume it is a wireless contact we are talking about?
1.) Low battery in tansmitter. Does your keypad display a low battery trouble? If so, ensure you put system in test before replacing battery as not to generate a tamper alarm when opening contact.
2.) Relay in transmitter is sticking. Replace wireless contact.
Stewart
May 26, 2010 | GE Security Simon 3 Wireless Home Security...
How do I change the battery in the GE Simon XT panel?
If your system is monitored call the central station first and tell them you are working on it. Then push down on release tab in top center to fold down the front face. Nest step is to use a small flat blade screw driver to push in and release the tab again in the top center and the unit will fold down towards you, hold on to it and you will see the battery compartment. Follow the red and black wires to the battery. Some units have a plastic lid over the battery that requires you to remove to small phillips screws to remove battery.
Feb 21, 2010 | GE Security Simon 3 Wireless Home Security...
I replaced back-up battery in my GE simon 3 ( 4 hrs ago), however when I perform a system status check I still get the msg "low battery".
You must unplug the transformer to the system before installing the new battery so the system recognizes that the battery is in place. Once you have installed the battery it is safe to plug the transformer back in.
Jul 25, 2009 | GE Security Simon 3 Wireless Home Security...
Simon XT panel does not want to learn motion sensor
try learming the sensor in by removing the back and actavation the tamper switch of the unit. also make sure that the unit is not already learned into the unit and if all else falil default the panel and start over.
mj
Jun 25, 2009 | GE Security Simon 3 Wireless Home Security...
How do I replace the battery in my Simon XT security system
Here is a very easy to follow video tutorial that may help you.
You can get a replacement battery from here
Simon XT GE Security Security Alarm Battery 6V 1 2AH
Mar 08, 2009 | GE Home Security
Jun 15, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon Xt Wireless Control Panel 40 Zones Logo
278 people viewed this question
Top GE Home Security Experts
Sean
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
