Question about HP LaserJet 3330 All-In-One Printer
220 volts put into 110
Little blast & simeled . not wakup on on 110 volts
  • HP Master
  • 783 Answers
Sir/Madam
HP LaserJet 3330 Scanner Unit Disassembly Procedure
This is not an Hewlett Packard document, the author does not work for Hewlett Packard and is not responsible for any damage you do to your printer. This procedure is for skilled repair technicians and is not recommended without some knowledge of equipment repair. Proceed at your own risk.
1. Open the document feeder and pull up on the two black tabs on the left and right.
2. Pull up on the right part of the doc feeder then the left, remove doc feeder, set aside.
3. Open front door and rear fuser door.
4. Remove screws closest to teal colored fuser release levers. side cover screws
5. Pull right cover out from back while releasing clip on bottom of cover, pull cover towards the back and remove.
6. Push on indentation at back of left cover and pull out at back, this cover is hinged.
7. Remove four screws now visible at base of scanner assy., two on left two on right.
8. Slide covers towards back and remove.
9. Remove two screws in the back just above the fuser and just below the scanner assy. base. Remove two screws in the front, visible now after removing the scanner assy. base covers on the right and left the left one is just behind the hinged cover near the top hinge.
10. Remove flat ribbon cable on left side at either connection point to disconnect scanner assy. from print engine.
11. Entire scanner assembly can now be slid forward and removed.
12. Close the front, rear and left side doors on the print engine portion and set it aside.
13. Grab front panel face plate at top and pull forward and remove.or pry gently at top of face plate)
14. At top of exposed front panel you will see four slots in the scanner assy. At the third one from the left there is a latch dark grey plastic. Push down on the latch with a screwdriver and slide the whole panel assy. to the right. Lift up and out making sure to disconnect the cable.
15. Remove the three screws in the now exposed dark grey front panel cradle and cover, remove the two cables connecting the cover to the main board, pry gently at the top outer corners of the cover and pull it forward and down, remove the cover.
16. Now remove the four scanner assy. screws one and the center front, center back, center right, center left all are facing down under the assy. (Or just flip it upside down and remove the four visible screws.
17. Turn the unit back upright and remove the four screws at the back/top two of them are down inside where the doc feeder normally goes. Remove the top scanner cover.
18. DANGER your about to work on the scanner carriage itself there is a really good chance that you could break it or the mirrors or bulb so proceed at your own risk.
19. At the top and bottom left side of the black cover enclosing the mirrors are two slots, if you put a small screwdriver in the slots and push gently to the right and lift that side of the cover it should come loose. Then open it to the right and remove it from the right slots.
20. Remove the black screw at the front of the assy., Disconnect the white wires from the CCD board and out of the harness, lift the clear plastic bulb holder out with the bulb then remove it from the rear. it's s a tight fit at the front.)
21. The top mirror is held in by some really tight clips they have to be removed from the bottom right clean the mirrors without this step if possible. NOTE: optical mirrors are not like a bathroom mirror, there is no glass covering the reflective surface. The back side of the mirror has glass covering it so if you get it in backwards it wont work. The way to tell which side you have is touch your screwdriver to the mirror and if its the right side the screwdriver will appear to touch the reflection of the screwdriver, if it's the wrong side the screwdriver will not touch the reflection of the screwdriver because of the glass covering the reflective surface.
22. Now clean the remaining mirrors and lens very thoroughly with alcohol. Make sure they are very clean. You can put the top mirror back and clean it in place to make cleaning it easier.
23. When reassembling the top cover check to make sure the white strip on the right side is clean.
24. Reverse procedure for re-assembly.
In case You still having HP Printer Problem Thn Visit Official HP Printer website For HP Printer Problem Below Link URL:
http://h30499.www3.hp.com/t5/Printers-LaserJet/Hp3330-laserjet-printer-problems/m-p/1131090#M182378
Or
If You Still Having HP Printer Error Then follow Us On:
HP Printer Support
Posted on Feb 12, 2014
What spect of voltage conventer transfer to convent the Voltage 110 to the 220-240 V printer??
110 volt to 220 power converter 220 volt to 110 voltage ...
www.dvdoverseas.com/voltage_converters.htm
110-220 volt voltage converter power transformer 220 volt voltage converters 240 ...run on 120 volt 60 cycles (60hz) and most of the worlds run on 220/240 volt ...
Oct 07, 2015 | Canon F151300 LBP 3100 Mono Laser Printer...
Is this a 110 or 220 v dryer
It is EXTREMELY difficult to extract this answer for you without a make, model, and year.
BUT a 220 volt plug is seriously larger than a 110 volt plug, the 220 volt has 4 prongs, the 110 has three.
May 01, 2011 | Dryers
What will the size wire will i need to wire up to consumer unit
It depends on if you are running a 220 or 110 volt supply. Assuming that your supply is 110 volt and your microwave draws about 2000 watts, that would mean that you need a wire with a cross section of about 2.5 sq, mm to allow a safety margin. If your mains are 220 volts you can use 2 sq mm or a little less - say 1.5 sq mm to be on the safe side. (On 220 volts a microwave draws aprox. 2 amps for every 200 wats output and 1 sq mm wire can carry 10 amps - as a rule of thumb. At 110 volts these figures are roughly double).
Feb 13, 2011 | Microwave Ovens
Will it be okay to connect a 110 volt laptop to a 220 volt LCD projector?
What voltage is your mains supply?
The laptop's adapter should be a multi-voltage type 110 to 240 volts input.
If your mains is 110 volts AC then the 220 volt AC LCD projector won't work unless you connect it to a step up transformer (110 to 220 volt transformer).
If your mains supply is 220 or 240 volts then both the laptop and the LCD projector will work without any problems.
Aug 24, 2010 | Computers & Internet
Change from 110 to 220 volts transformer
It sounds like the replacement 220 volt transformer is putting out too much power, as replacing a 110 volt transformer with a 220 volt one should have no effect on other components, as the output voltage and amperage should be the same as the original one.
Apr 05, 2010 | Bose Lifestyle SA-3 2-Channel Amplifier
Dryer will not start door is closed
Carefully check your 220 outlet. You can check a 220 buy a volt meter. Make sure your volt meter is set over 220 range and put the red lead into the slot and black lead into the L shape. It could be you are not getting 220 power out of your outlet. We all know on a 220 outlet both legs have 110 on each side. A dryer takes 110 for the motor, and takes 110 for elements.
Dec 03, 2009 | Estate TEDX640JQ Electric Dryer
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Using an European (220 volt) DS Lite Console in America (110 volt)
Yes this can be charged using a 110 volt with no problems. However you do need the outlet conversion plug in order for you to be able to plug it in to your wall. These can be bought at any major electronics store in your area.
Feb 14, 2008 | Nintendo DS Lite Console
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
HP LaserJet 3330 All-In-One Printer Logo
44 people viewed this question
Seeker5211
Seeker5211
