Question about dorel asia Recliner: Alex Club Chair Recliner with Nailhead
Bottom round base cracked - dorel asia Recliner: Alex Club Chair Recliner with Nailhead
How do I repair the plastic base on the bottom side of the projector? Plastic base cracked?
In many cases you can contact the projector manufacturer for replacement parts, The plastic (also known as the chassis) can sometimes be purchased separate. Although a crack should no effect the projectors operation unless it was dropped hard enough to cause a crack.
Nov 29, 2014 | Office Equipment & Supplies
Leaking Neo-Round shower stall???
Check really close to make sure there is not a small crack in the base. Many times they can barely be seen and when you stand in the shower they open up larger allowing water to leak out. You may have to have someone else stand inside while you look for the crack.
Nov 08, 2012 | Maax Acrylic Base for Shower - 102623
Maax neo round stall leaks where base meets wall
Many times there are small cracks in the panel or the base. It may not be able to be seen until someone is standing in the shower.
Nov 04, 2012 | Plumbing
Water leaking out of bottom of machine overnight. Stills brews but leaking water from reseviour in back
Suspect the 'pump' tube that runs from the reservoir bottom up to the grounds basket. It may be cracked or the end clamp on the tube is weak, broken, or misplaced on the tube. Check the reservoir for a cracked base or fitting. Remove the bottom plate to get to this. (unplug the cord).
Aug 23, 2009 | KitchenAid KCM400 Coffee Maker
Im trying to dtach my eddies bauer base to convert into a booster seat
There's a round metal bar that runs thru the bottom of the car seat. Remove this bar and the base immediately comes off.
Apr 01, 2009 | Eddie Bauer Deluxe 3-in-1 Convertible
My 7142 leaks
There are a few hose connections inside the unit related to the heater element. Water flows from the reservoir down into the unit, takes a turn into a tube with the heater element wrapped around it, then turns back up into the mister area. Any of the four connections (base to first elbow, elbow to heater tube, heater tube to second elbow or second elbow to base) could be leaking.
The white ring around the mister disk cracked on my unit, letting water leak out the bottom as you describe... Take a close look at that.
It's also possible the base itself is cracked somewhere... Look closely at the mister and reservoir areas of the base for cracks.
Dec 16, 2008 | Air-O-Swiss U7142 Humidifier
I can't figure out how to get the round ball on the base put together. I received no instructions
You have to push the cradle on very hard. It WILL snap onto the base. DO NOT DO THIS WITH YOUR GPS ATTACHED TO THE CRADLE OR YOU WILL CRACK YOUR LCD DISPLAY.
- Jim
Nov 21, 2008 | Garmin GPS
On Off switch problem
Look under the kettle at the round circular connector in the bottom. Inside there is a small button that is depressed when the kettle is put on the base. If this is not pushed in far enough it will have problems.
The cause is that after some use the connector in the base plate collapses into the base by 1-2 mm This means the switch is not pushed in far enough.
My kettle had similar issues... I pulled the base plate apart (3 screws I think) and cut a round disk of plastic to lift the connector up by about 1-2mm and then reassembled the base.. No more issues
Jul 08, 2008 | Russell Hobbs RHOK3123 Cordless Electric...
Cracked
I'm afraid that you will have to replace the base unit, part #62577, would sell for around $25. Once it cracks, then it is weak and will affect the brush roll and belt.
Dec 30, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Switches off before full boil
Nov 23, 2007 | Russell Hobbs RHOK3123 Cordless Electric...
dorel asia Recliner: Alex Club Chair Recliner with Nailhead Logo
51 people viewed this question
Top dorel asia Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a dorel asia Furniture Expert? Answer questions, earn points and help others
