Question about Taylor Precision Products 55934012 Body Fat & Water Scale
Taylor Precision 55934012 not storing data - Taylor Precision Products 55934012 Body Fat & Water Scale
Taylor precision digital diet scale model 1250-49 displays "88888",theno "UNSt" , even when level and solid platform
The display or internal electronics might be broken. Firstly, try removing and replace the batteries and cleaning the scale. If that doesn't work you may want to contact the manufactuters.
Nov 04, 2016 | Taylor Health & Beauty
Taylor electronic precision scale model 1250-49 reads "88888", then "UNSt"
it means that it can't get a 0 point because it is unstable put it on a flat table or something and push re-zero (softly)
Nov 03, 2016 | Taylor Health & Beauty
#307GB serial # 20030527357
according to Taylor data base that number doesn't exist, please double check and go to taylor serial number lookup website.
Sep 13, 2014 | Taylor Big Baby Acoustic Electric Guitar...
When you get onto the scale (Taylor Lithium 7506), the numbers just keep cycling and never stop. We tried changing the battery, even though the scale is less than three months old, but it still does the...
Turn it over - take out battery and check with multimeter to ensure it is still workable - let sit for 10 to 15 seconds - replace battery - set it on level surface and step on and back off. Step on it again and it should now work.
Sep 16, 2011 | Taylor 7506 Precision Tech Lithium Battery...
I just need to get a copy of the instructions for the 5758BL Biggest Loser Scales.
Taylor has a number of scales available in The Biggest Loser series for which they make available a link to the Instruction Manuals. See here:
http://www.taylorusa.com/catalogsearch/result/?q=biggest+loser&x=0&y=0
Here are two examples:
The Biggest Loser 7334 Weight Management Electronic Scale with Goal Tracking
http://www.taylorusa.com/media/IBs/7334_ib.pdf
Taylor The Biggest Loser 73343 Lithium Electronic Scale
http://www.taylorusa.com/the-biggest-loser-lithium-electronic-scale.html
Unfortunately after browsing their site I found nothing close to the model number you provided. If you see a model that is similar in looks and features suggest you see if the instructions for that model are of use to you. You may also find there FAQs to be of assistance:
http://www.taylorusa.com/faq-scales
Alernatively send an inquiry direct to Taylor Precision Products:
http://www.taylorusa.com/taylor-support
Apr 23, 2011 | Vacuums
Hello: my digital food scale (taylor digital biggest loser brand) goes on but it does not weigh anything. its stays at zero. i've had it a year but only used it once or twice, so its almost never been...
Hello, Maclay55 -
I hope you checked the owner's manual first, the troubleshooting / problem solving section.
It wouldn't hurt to put new batteries in the scale (2 AAA batteries).
Note: From the instructions for the scales:
6. Do not store scale where you store cleaning chemicals. The vapors from some household products may affect the electronic components of your scale. Do not store scale on its side.
7. This scale is an extremely sensitive weighing device. In order to prevent run down of the battery, do not store anything on the scale.
8. Do not dispose of batteries in fire. Batteries may explode or leak. Do not mix old and new batteries. Do not mix Alkaline, carbon-zinc (standard) or Nickel-Cadmium (rechargeable) batteries. Remove the batteries if the scale will not be used for a long period of time.
Source:
1037BL The Biggest Loser by Taylor Stainless Steel Platform Scale Instruction Manual, pages 4-5
http://taylor-enviro.com/media/IBs/1037BL_ib.pdf
If installing fresh batteries does not work, then I suggest you call the Taylor USA Consumer Help & Support department. This is the link to the web page with the US and Canadian telephone numbers:
http://taylor-enviro.com/taylor-support/
Best wishes.
Feb 11, 2018 | Taylor Precision Products Taylor Precision...
Digital readout not readable
Try a new one. If it works, the scale is broken.
Jun 30, 2010 | Taylor Precision Products Taylor Precision...
ERROR message
This link allows you to troubleshoot directly with the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Jan 02, 2009 | Taylor 7506 Precision Tech Lithium Battery...
Taylor Precision Products 55934012 Body Fat & Water Scale Logo
29 people viewed this question
Top Taylor Measuring Tools & Sensors Experts
deton8 von Splosion
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
