Question about Car Audio & Video
Cooling fan is not working?
KD 1208 PTS,DC 12 V
2 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: I require an instruction booklet to install &
http://resources.jvc.com/Resources/00/00/91/GET0433-001A.pdf
user manual
http://resources.jvc.com/Resources/00/00/91/GET0433-002A.pdf
install manual
If you need help installing an amp to this unit being vehicle specific. Post a comment with vehicle year make and model, as well as the amplifier make and model and I can walk you thru it. Hope this helps
Posted on Jun 24, 2009
Fan wont come on
Make sure that the fan is 12 DC Volts.. If that is 12 DC volts?... you can connect that fan to power supply of your desktop wired color (+)yellow and ( -)black. If its doesnt work... that fan is defective.
Aug 16, 2014 | Computers & Internet
Fan comes on when switch ignition on instead of when hot Tazz
If the fan not turning on when car engine getting hot,then car will notice overheating.Click this link below for troubleshooting:---http://technoanswers.blogspot.in/2012/02/car-running-hot.html--------To know how engine cooling system works ,click the link below :----Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works? http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
------------How to Replace Engine cooling Fan:-- http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-engine-cooling-fan-on.html
-----------Replace Fan Relay but still Radiator cooling fans not working? http://schematicsdiagram.blogspot.com/2011/12/replace-fan-relay-but-still-radiator.html
----------DIC says "COOLING FAN FAULT"? http://schematicsdiagram.blogspot.com/2011/12/dic-says-cooling-fan-fault.html
---------Where Is Radiator Fan relay and Fuse Located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radiator-fan-relay-and-fuse.html
This will help.
Thanks.
Feb 09, 2012 | Cars & Trucks
My Panasonic is Model# SA-ht650. The fan does not come on to cool the unit down. I took the fan out and tested it and it does work with 12 Volts DC @ 1.5 amps. Any suggestions.
For others, the fan on this model only runs with the volume turned way up, to test it unhook the speakers and play something like the radio with the volume set to 0dB, the fan should run.
Dec 23, 2010 | Panasonic SC-HT650 System
I need a 2x2 brushless fan model # rdm5015s dc 12 volt. where do i find one please?
Perhaps try Google's Product Search?
It appears to be a fairly standard 50x50x15mm fan with a two pin type 2 connector. Try looking for a two pin 50mm fan with a thickness of less than or equal to 15mm.
A quick search I've done can be found here.
May 10, 2010 | Sanyo /San Ace DC 12v Brushless FAN Assy
Fridge is not cool enough 12 degrees C. Freezer is -3 degrees
The cooling air outlet is clogged or blocked. Cool air is not entering the fridge section as indicated by the low temperature in the freezer section. It shows that the compressor is working fine and the system is good. If your unit has a brushless DC fan motor that circulates air to the fridge section, it may not be working properly or not working at all. You have to replace it.
Nov 08, 2009 | Refrigerators
Dc fan with this part number12-87366-02
Fans are interchangeable parts in computers.
alright bust out your ruler and measure the diameter across.
typical sizes are 60mm, 80mm and 120mm
you can buy all of them and awesome light up ones here
http://www.frozencpu.com/cat/l1/g36/Fans.html?id=iW3bmbvy
Jun 29, 2009 | Sunon (16-02-006) Fan Kit
How to remove the cover
If this is a rackmount style... there are 2 or more torx style screws on the bottom side (I'm looking at a 3C16671A) which you will need to remove. If there is an expansion board which slides into a backside slot, then this board will likely need to be removed first too. Also on the backside may be a couple of plastic hooks which help to clip the top on.
Once all retention screws are removed the cover can be lifted backside up some first, then slide towards front some, then clear off. Don't force anything...
I think the cooling fan is the same size as often used on the old 486, Pentium, Pentium II, and some Pentium III heatsink assemblies.
Jan 07, 2008 | 3Com 3C16592A HUB 12-PT 10/100BTX SS2...
Need a new DC brushless fan
www.farnell.com is available in UK.
Dec 31, 2007 | LG RH177 DVD Recorder/HDD Recorder
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
