PAPER JAMS FROM BYPASS
SOURCE: Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
SOURCE: how do you take a
hold down the STOP key for ten seconds and record the reading appearing on the display
SOURCE: cs1820 driver for windows 7 copystar download
Go to www.copystar.com
Choose download
under download, select legacy black and white copiers multi functions
then choose your model 1820
under sub category choose print drivers
it will gives you all drivers version.
let me know if you still need any help.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
