Condensation on outside of chest freezer
Water on floor every day
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Is it cooling well if not it needs gas
Posted on Feb 10, 2014
Condensation on outside of chest freezer.water on floor
if someone repaired it before they eliminated the hot pipes responsible of such issue, if not is it cooling well if not it needs gas there is a leak caused from the pipes
Feb 10, 2014 | Washing Machines
Water condenses on outside bottom of freezer and drips on floor
I would not remove the bottom and replace the insulation. Where is the unit located in your home?
Nov 02, 2012 | Refrigerators
Water is leaking out onto the floor from freezer
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Ads by Google' + // // '' + // '' + // makeBoldAdWords(google_ads[0].line1) + '' + // // '' + // makeBoldAdWords(google_ads[0].line2) + ' ' + // makeBoldAdWords(google_ads[0].line3) + // '
' + // google_ads[0].visible_url + ' ' + // '
' + // ''; // } // else if (google_ads.length > 1) if (google_ads.length > 0) { s += 'Ads by Google'; /* * For text ads, append each ad to the string. */ for(i = 0; i ' + makeBoldAdWords(google_ads[i].line1) + '' + '' + '' + google_ads[i].visible_url + ' ' + makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + '
' + ''; // '' + // makeBoldAdWords(google_ads[i].line2) + ' ' + // makeBoldAdWords(google_ads[i].line3) + // '
' + // google_ads[i].visible_url + ' ' + // '
' + // ''; } } } document.write(s); G_GGL_SKIP += Math.min(google_ads.length,G_MAX_ADS_AT); return; } var G_MAX_ADS_AT = 4; //var G_MAX_ADS_AT = 3; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "4447185069+3033438690"; google_ad_output = 'js'; google_max_num_ads = '4'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // -->
Aug 22, 2011 | Admiral 26 cu. ft. Side-By-Side...
Hi there, I have a MAYTAG MSD2758DR Refrigerator and every night water is leaking from front left and floor is getting wet. The amount of leaked water is nearly a cup of water.
If your chest freezer is showing signs of age, it may begin leaking. There are a few methods for troubleshooting faulty chest freezers but knowing some of the obvious signs of why it might leak can be very useful if you need to fix it yourself. Leaking is not limited to older models so be aware that certain maintenance procedures can help prevent leaks in newer models.
Understanding Changeable Parts Prior to Troubleshooting There are not that many serviceable or changeable parts inside a chest freezer. A chest freezer works on a very simple basis. It contains evaporator coils, condenser coils, a compressor, a compressor overload, a relay and a thermostat. These are the basic moving parts of a chest freezer but some of them are not serviceable.
The condenser coils condense the water and the evaporator coils disperse excess water caused by the freezing process. The compressor is a heating component which compresses excess water and recycles it through the system.
Defrosting Remove the contents of your chest freezer and place them in an alternative area to keep them frozen. Unplug and defrost your chest freezer before you do any troubleshooting or maintenance. Wipe and clean the inside of the freezer so that when you plug it back in it, will free of any grime or loose bits of debris. A clean freezer will also help to promote visibility when it comes to fixing leaks.
Where is the Leak? Once you have defrosted your freezer, you need to establish which part of the freezer the leak is coming from. It could be coming from the inside of the freezer and this would indicate a thermostat issue. Alternatively, it could be coming from the freezing unit at the back of the freezer. Water always finds a way to escape so your leak could be restricted to one place but the actual cause could be elsewhere. Locate the drain tube which is normally found at the back of the freezer. You will probably have to unscrew or unclip the backing panel.
Check the Drain Hole If the drain hole on your chest freezer has become blocked for any reason, you will need to clear it thoroughly to continue getting the best performance from your chest freezer. The drain hole is a component within the lower works of the freezer through which excess water runs to be recycled.
Compressor Issues Your chest freezer contains a compressor which evaporates the excess water from the freezer. The freezer will defrost excess ice and the water flows down the drain tube to a pan where the heat of the compressor evaporates the water. If your compressor has failed, the leak will be caused by the water failing to evaporate. Have a repair contractor replace your compressor or, if this is not cost-effective, you may need to buy a new freezer.
Thermostat If your freezer is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your freezer is cycling correctly prior to making changes or altering the thermostat. Only if the freezer is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your freezer and you still cannot locate the leak, calling in a service technician might be the best answer. Take care in solving the problem....
Aug 18, 2011 | Maytag MSD2559XE Side by Side Refrigerator
Water freezes in bottom freezer and then leeks onto floor
Defrosting
Where is the Leak?
Compressor Issues
Thermostat
If your freezer is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your freezer is cycling correctly prior to making changes or altering the thermostat. Only if the freezer is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your freezer and you still cannot locate the leak, calling in a service technician might be the best answer if you can not handle it yourself..
Do take care in solving the problem....
Jun 28, 2011 | Amana Refrigerators
Hi we have recently moved to a house an we have inherited a fairly new whirlpool chest freezer which works very well but there is a lot of condensation on the outside which results in small pools of water...
The insulation between the inside and the outside of the freezer haas become water logged, This can be twmporarilly remedied by switching off the freezer and letting the insulation dry out for a few weeks, less in hot dry climates, but the solution is temporary and the problem will reoccur. To have the foam replaced means a complete strip down of the freezer and is seldom worth the cost. I am sorry, but you will probably have to get used to living with the problem. Incidently, it does make inroads into your electricity bills.
Jan 16, 2011 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
The sides of the freezer feels very warm. Is this ok?
Good day,
That is normal, and by design. The condenser tubing runs inside the outside walls on that machine.
Thank you for using FixYa
Dec 15, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Dec 26, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Condensation on Outside of Freezer
hi thanks for the question .yes you will have to live with it warm & humid climate especially in the garage .A fan close by could help thanks the appliance doc
Sep 28, 2008 | Kenmore 5 cu. ft. / 142 liter Chest...
Freezer is freezing but the outer wall are extremly hot
This is a normal condition.  The condensor coils are in the cabinet and their job is to remove heat which is why it is hot.  You will want to make sure the freezer isn't in a tight spot where air from the room can't flow across it.  Without good air flow it will become too hot and not cool properly and lead to the compressor failing too soon.
Oct 13, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
