Question about Pioneer CDJ-1000 CD Player
Motor ejects slow - Pioneer CDJ-1000 CD Player
Sony CDP-CX400 Mega Storage CD player having issues ejecting disk. Can Load Error be cause by worn and "out of tension" belts? Table turns a bit slow and when I hit disk eject
Either a loose loading belt, or a weak loading motor can cause this fault. Check it. A weak loading motor can cause more faults. If the pulling power of this motor is low, the fault will occur. Replace this motor and the loading belt first. Check whether there is any gear wheels having broken teeth.
Feb 23, 2016 | Sony Audio Players & Recorders
Sony handycam ccd-trv59e C32 10
The camera's firmware has sensed a jam or too slow rotation in the cassette's take-up roller. Really difficult to overcome. The tape may already be snarled round a roller, but is certainly in the "loaded" tape path. I've had this and had to disassemble the whole tape transport mechanism - which is really difficult - after trying unsuccessfully to drive the unload motor from an external 6v power supply. Sometimes a really hard sideways bang on the camera can free up the roller enough to let it rotate a bit, satisfy the motion sensor and allow an eject.
Jul 07, 2014 | Sony Handycam DCR-TRV520 Digital Camcorder
Stylemaster 909278: The spin cycle is slow and the clothes are sopping wet after the cycle is finished. Didn't see any obstructions. No unusual noise coming from the machine. It ejects water fine after...
Is it a new or old machine?
If old, could be a loose drive belt or the tub overloaded. Is there a heavy load or lite load in it?
A loose belt is usually easy to tighten,...but hard to get access to the motor.
Jul 18, 2011 | Washing Machines
Half an hour ago the player was still working fine. Now it's impossible to eject cd's and the player itself gets confused cause the cue goes on and off by itself and playback skips. HELP
The CD drive in your CDJ is hunting for the disc, i.e it has become difficult for the player to read the disc. Keep your ears next to the loading slot after inserting a CD, you will hear a motor spin up then slow down then spin up again and if this continues the system will lock out the eject function. Or else the disc will come flying out!!. Either you need lens cleaning ( try a cleaning kit ) or replacement ( If the player has crossed over 500 hours of use )
Mar 09, 2011 | Pioneer CDJ-100S CD Player
It makes a humming sound but does not pump water. the pump gets very hot there is no debre in the outflow
The motor is binding that's the humming noise. Check to see what **** the thing sucked up. Then try to clean it out. I dont know what happened
Dec 25, 2010 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
JVC won't eject my CD!
Turn radio off Push and hold the eject button Turn radio on while holding the eject button.
This is the force eject sequence
Apr 05, 2010 | JVC AM FM CD DET FACE CAR STEREO
Won't eject
When you hit eject, do you hear the motor attempting to eject the disc? If no sound at all, it could be a bad eject button. If you hear the motor of the drive attempting to eject the disc, then there is a problem somewhere inside of the Wii's drive. The following website sells the DVD drive mechanisms and does repairs on the Wii as well:
http://store.richspsxparts.com/wiiredvddr.html
Oct 23, 2009 | Nintendo Wii Console
Toyota camry 1997
Your motor mounts are worn out. Replace the "dog-bone" looking mount at the passenger side of the engine, and then replace the hydraulic mount right between the engine and the radiator.
Aug 19, 2008 | 1998 Toyota Camry
Help! having similar problem with my camcorder?
Sounds like something is jammed in the tape carriage
Call canon and send it in for sevice.There is no tip or trick for carriage jamming issues
Jul 10, 2008 | Canon ZR500 Mini DV Digital Camcorder
Pioneer CDJ-1000 CD Player Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
