Question about Sony PlayStation 2 (PS2) Console
God of War 2 walkthrough in english, THE TEMPLE OF EURYDALE,
There's a section where I Place a dead body on a stone platform on the ground in main chamber, it opens the gate halfway. There's a side hall just off main chamber I step on another stone platform which opens gate I have to get through. I cannot get to gate before it closes. " How do I accomplish task? "
    Problem Solver:
  • 10 Answers
The Temple of Euryale
Down the stairs, smash the petrified Legionnaires to shatter them, releasing red orbs. Continue on to the right and quickly shatter the petrified enemies before they break free. You can use Golden Fleece to reflect the Legionnaires attacks back at them. Prepare to reflect when their weapon begins to glow blue and they leap up into the air. Start climbing down the ladder at the end of the hall. Down below, some petrified enemies break free and a hulking Minotaur appears.
Quickly shatter the Legionnaires that have yet to break free and then immediately turn your attention to the other enemies. The Minotaur is surprisingly easy to kill if you have a full magic meter. By using Typhon's Bane you should be able to bring the Minotaur down to its takedown stage. When the Circle appears over the Minotaur's head, approach it and press the Circle button to start the takedown. Press the two buttons that appear on screen then finally rotate the Left Analog Stick as shown to finish the beast off.
Unfortunately, once you have killed enough enemies, another Minotaur appears, but at least if you kill off the first quickly, you won't have to face two of them at the same time. For the Legionnaires use Plume of Prometheus (Square, Square, Triangle) and most importantly, use Golden Fleece to reflect their leap attack. If done successfully, you can damage the surrounding Legionnaires with the reflection as well.
After the battle, head through the doorway to the right of the ladder. This hallway leads to a lift. Grab hold of the handle and rotate the Left Analog Stick to lower the lift down to the level below.
PHOENIX FEATHER (12/30): When the lift has reached the bottom, jump up and attack the snakehead on the wall to reveal an unmarked chest that contains a Phoenix Feather.
The two lifts in this room influence the height of each other. Since the soldier removed the handle from the lift on the other end of the room, you must use the lift that still has a handle to raise the lift that does not have one. Raise the lift that you used to reach this room as high up as you possibly can while still allowing you to drop down from the lift to the room below. This raises the broken lift up to that same height, allowing you to then climb up onto the raised lift and scale the wall using the ridges along the wall
Posted on Mar 04, 2014
4 Suggested Answers
RescueTechLA
  • 2653 Answers
SOURCE: how to beat the forgotten temple in god of war 2
All of your questions and more are answered here:
SOLUTION
Don't forge to rate my solution FIXYA
Thanks!
Posted on Feb 28, 2009
Jmizpah777
  • 290 Answers
SOURCE: God of War 1 and 2(Unable to read disc)!
Check your cd if it can play in different ps2 consoles. if it can, then theres nothing wrong with the cd.
probably your game console has problems on disk reading.
FIX Those Ps2 disk errors.
You're going to be surprised when you find out how easy this is. Read the instructions all the way through before you attempt the repair just so you'll be familiar with the entire process. First take off the outer cover of you PS2. If you haven't done this before, you will have to remove all the screw covers from the bottom of the unit, both plastic and rubber, these will be the only screws you will have to remove in order to take off the outer cover.
To remove the outer cover, lift up from the rear of the unit and pull towards the front in order to clear the controller jacks and the eject/close buttons. As you remove the outer cover you will notice a small metallic ribbon cable inside the machine leading to the eject/close and reset buttons on the front of the unit, this cable is usually taped to the top of the disc tray. This cable is not a sensitive as it appears; just remove the tape holding the ribbon cable. Once the outer cover is off you need to remove the cover to the disc tray, this will require a rather small phillips screwdriver (I've seen a few that use a standard slotted screw). Now that the tray cover is off, the first thing to do is to clean the laser eye. All you will need is a Q-Tip dipped in alcohol. Just swab the eye a few times and allow it to dry on its own, making sure that no lint was left behind from the Q-Tip.
After the cover is off of the disk tray and the laser has been cleaned you will need to plug the unit back in, (The unit needs to be hooked up to a TV as well to test it while you have it open. You should have a DVD, a game disk with a silver or gold back and one with a purple back in order to fine tune the system to play all three.) It will be necessary to have the unit powered up to perform the repair. Press the eject button so that the tray slides forward exposing the undercarriage. At the back of the unit you should see a small white, geared wheel about the size of a quarter. This little bastard is the cause of all your problems.
This wheel changes the angle in which the disk is held. You will notice that there is a small metal tab that holds the wheel in place. Take a felt-tip marker and mark the point on the wheel that meets the tab. That way you will always know the original position that the wheel was in. Now that the orig. position has been marked, feel free to spin the wheel for a few full rotations in order to see how it changes the angle. It will only alter the angle a few degrees before it goes back to zero, after it reaches the maximum angle it will go back to flat after each full rotation. Once you've toyed with it to see how it works, put the wheel back to the original position that you have marked. Then advance the wheel about 1/8 of a turn and place the disk tray cover back on top of the disk tray. (You will not need to screw the tray cover back down in order to test the machine; you will only need to hold down the cover with your fingers while trying to load/test a disk) Now place a DVD in the tray and press the eject/close button in order to close the tray and load the DVD (hold down the cover as explained above). Wait to see if the DVD loads, you may have to use the browser in order to load each disk you test. If the DVD loads, eject it and load a silver backed disk, if that loads try a purple backed disk. If all three loaded successfully, congratulations you're finished. If not, remove the tray cover, eject the disk and advance the wheel another 1/8 turn and repeat the process. It just a matter of finding an angle that will facilitate the operation of all three types of disks. Once you've found the proper angle and the system is operating to its full potential, close it up and let'er rip. I also do not recommend placing the PS2 on its side once you have fixed it. Although Sony says they recommend it in the owner manual, I have since seen internal Sony documents retracting the statement and attributing many malfunctions to storing and operating the unit on its side. Keep it flat at all times.
well. i hope this works.
pm me if problems continue.
Posted on Aug 08, 2009
Dajuliehubby
  • 203 Answers
SOURCE: play staion 2 reads all games but wont read god of war 1 and 2
Best bet is to try a laser lens cleaner and seeing if that helps. I know it sounds silly that it might be dust on the lens when only THOSE games don't work, but stranger things have happened.
Posted on Jul 30, 2010
Divinity 2 walkthrough
This looks like a complete walkthrough of the section you want:
http://www.gamebanshee.com/divinityii/walkthrough/bvdmaxostemple.php
If you prefer videos (the comments don't seem very nice but it might be worth a look):
https://www.youtube.com/watch?v=7Nc4CgYvHFE
Mar 19, 2014 | Computers & Internet
How do I get through the 2 buttons for the top and bottom closing gate when I only have one body to lay on one of them. In god of war 2 on ps2
Dear Scottyboy276,
I found what you need, it is the game walkthrough/ cheat. It is the only way I can help you, but hey this is not a bad thing to have access to all of the manuals and cheats for nearly all games you can think of, and yes I will share a walkthrough with you.
http://uk.guides.ign.com/guides/811719/
Go to the above link and you will find your game guide.
I hope this has been a walkthrough for you and look forward to hearing how you progress in the game, and with any other game for that matter.
Yours sincerely
Ouszen
Feb 07, 2012 | Video Game Consoles & Games
How to cheat the level on godswar 2011
An excellent resource for discovering Walkthroughs, FAQs (Frequestly Asked Questions) and cheat codes for God Of War III is here :
http://www.gamefaqs.com/search/index.html?game=God+ofg+War+III&platform=0&s=s
First:
Select you gaming platform (Xbox, PS3 Wii PC etc)
The FAQ section will contains complete Walthroughs:
For exmaple Here: http://www.gamefaqs.com/ps3/943928-god-of-war-iii/faqs/59367
Good Luck !
May 07, 2011 | God of War III
My problem is you don`t give cheats in god of war
Theres no standard cheats codes by the looks of it, just walkthroughs and codes for the Action replacy cheat add on device - you may find out more here:
http://vgstrategies.about.com/od/toppicks/tp/godofwarps2.htm
Mar 19, 2009 | Sony God of War 2
How to beat the forgotten temple in god of war 2
SOLUTION
Thanks!
Feb 28, 2009 | Sony PlayStation 2 Slimline Console
God of war II
Try this youtube walkthrough :)
Feb 17, 2009 | Datel Ultimate Codes: God of War II
God of war 2
You need to Cut his head
thanks
Aug 24, 2008 | Sony God of War 2
God of war 2
with refrence to your problem I get the idea where you are roaming.In order to escape from that room put the body on centrepiece for half of the gate to open,then move the lever completey with analog stick then rushed towards the gate and observe there a gas coming out from the holes.Make a triple jump on holes and the help of wings you will be able to escape from that circular room.
Jun 06, 2008 | Datel Ultimate Codes: God of War II
Game
hey i dont know how to pass through a stage in god of war 2 pls help me that stage is after getting a big hammer
Sep 26, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
