Question about Hitachi TravelStar DK23EB Series DK23EB-40 40 GB Hard Drive
Hitachi DK23EB-40 HDD
I have a Dell Inspiron 8500 laptop that is 5 years old and out-of-warranty now. The hard drive that came with the system (Hitachi DK23EB-40) says "Primary Hard disk drive failure" now each time I start the computer up. The drive is probably toast, but I am not having any luck at all deciphering what the proper replacement would be in this laptop. I don't necessarily need a Hitachi brand, and I have all of the specs regarding the drive- but can I just merely purchase any 2.5" hard drive on today's market, or is the 2.5 setup different than the typical 3.5" that I am used to.
I figured out how to remove the drive from the laptop and disassemble from the bracket and all...I simply would like someone that is able to steer me in the correct direction as far as replacing the faulty drive. Any suggestions or thoughts regarding specific hard drive I should purchase to replace this one?
    Brigadier General:
  • 6,966 Answers
Basically what you have posted covers all that you need to know and do. The only issue would be the capacity in Gb of the new HD. Most currently available are far too big for your laptop. What you need to get is any 2.5" HD that is identical in size or just slightly bigger than what you used to have. Three reasons for this: 1) your motherboard may not recognize the newer/bigger HDs and therefore you would probably encounter problems even at the BIOS/CMOS stage; 2) the power requirement of the newer HDs may not be compatible with what your laptop can supply; and 3) the heat generated by newer HDs is considerably higher but your laptop was designed to accommodate older models only.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Oct 27, 2007
Hitachi Hard drive DK23EB not readable -please help
Have you put the hdd from the laptop into slave mode, its on the back of the hdd, there might be a "jumper" that you need to reposition, failing that only insert the 1 hdd from the laptop and make it the only hdd, it should have an operating system on to run as normal. You can see the <jumper> on the right of this picture, you will need to connect both teminals (slave) with a little plastic jumper.
Apr 03, 2014 | Hitachi TravelStar DK23EB Series DK23EB-40...
Al querer instalar wxp-sp2 me aparece el mensaje que no encuentra ning&#250;n HDD, pienso que es porque no reconoce los drivers. La m&#225;quina es una Laptop Dell Latitude c840 y el HDD es un...
Creo que ese laptop no supporta SATA para XP, y se puede tratar hacer lo con un cambio en BIOS.
Prende el laptop, y empuja "F2" inmediatamente cuando aparece el Dell logo. En el setup menu en BIOS empuja "SATA native mode" para tenerlo apagado.
Inserta el Windows XP CD en el CD ROM drive, y apagar y apagar el lapto.
Jan 14, 2018 | Hitachi TravelStar DK23EB Series DK23EB-40...
I need to download drivers for my dell latitude to install my 2nd hard drive - module bay Hitachi dk23eb-40
dlb6d
Depending on the operating system that you are running on your computer you should not need to install drivers for the second hard drive. However you may just need to assign a drive letter to the second drive. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 30, 2010 | Hitachi TravelStar DK23EB Series DK23EB-40...
My hard drive which is model dk23eb-40 is not being recognized by my computer at all. not in the bios or nothing. is there something else i can do or is it gone completely
If you can try it in another computer, as the _only_ device connected to the "data" ribbon-cable, and it still fails to be detected, then it's gone, gone, gone.
Jan 16, 2010 | Hitachi TravelStar DK23EB Series DK23EB-40...
Dell Inspiron 8500 started boot error message ?primary hard disk drive 0 failure, no boot device available?strike F1 to retry reboot, F2 for setup. Ran express diagnostics and it shows two errors: Error...
Call Dell if under warranty. Start shopping for a replacement hdd if outside of warranty. You'll need
your OS disks that came with computer (hopefully). If you don't have OS/recovery disks, you can get
them from Dell or even using somebody elses (match version with sticker on your laptop).
Check the hdd connection underneath laptop - make sure cable is not loose, etc.
Probably safe to say your data is gone unless you're willing to spend $$.
Jul 12, 2009 | Dell Inspiron 8500, Latitude D800...
Erased hard drive, now nothing will load
Check to make sure that your Inspiron is set to boot from the CD-ROM drive.
It sounds like your laptop is trying to boot from the (now erased) hard drive first, finds that it can't, then stops without ever checking the CD-ROM drive for boot media.
At startup, hit F2 to go into the BIOS settings. Look for the "Boot Order" section. Make sure that your CD drive is listed first, then your hard drive.
Save your changes, and reboot with the WinXP installation CD in your drive. Now your laptop should boot from the CD and begin installation.
Good Luck!
*If you find the solution helpful, please rate it!*
Jun 04, 2008 | Hitachi TravelStar DK23EB Series DK23EB-40...
Laptop won't boot..
try new hard drive 1st ok
Jan 30, 2008 | Dell Inspiron 8500 Notebook
Hitachi TravelStar DK23EB Series DK23EB-40 40 GB Hard Drive Logo
385 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
