Question about Polaroid 1720-7 Remote Control
POLAROID P40LED13 vga
When i plug my VGA cable in it turns the tv screen red, i have brought a ne VGA lead its not the lead, i've tried turning the contrast down still doesn't work
robjac
  • 109 Answers
SOURCE: Polaroid flm-3232 locked or in sleep mode? Is that...
Try to read your product manual caferfully all information are cited in the manual in order to have a smooth operation of your unit.
Posted on Oct 19, 2008
Elvellon
SOURCE: Polaroid flm-3232 locked or in sleep mode? Is that possible
Hi there!
I work in an electronics store and I've come across this problem before. The only solution that has ever worked for the people who call in or come to see us is pretty simple. You need to unplug your PC from the TV (if you haven't already done so), turn the TV on by using the "channel +" button. Some TV's when turned off at the wall will not turn back on again unless you press the channel + button. Give it a go and see what happens. Let me know if you need more help.
Also, it sounds like your laptop may not have been supported due to the wrong resolution being outputted through your VGA connection. When you get your TV turned on again I'll see if I can help you get them to work together,
Cheers and good luck!
Abby.
  • 187 Answers
SOURCE: VGA shut down
call Polariod
replace 'box'
(their description, not mine)
Posted on May 19, 2009
  • 44 Answers
SOURCE: When we turned on the tv it says no signal vga
This might sound like a silly question but is the VGA input the one you wish to use?
If you are trying to use the VGA input what do you have it connected too?
A) Laptop 2nd VGA output.
B) Desktop VGA output.
NOTE: If you trying to connect it to a laptop you may have to engage your 2nd VGA output by depressing the 'Function Key' and either F4 or Some times it's the F8 key at the same time.
Blessings,
A/V Media Tech Guy
Posted on Nov 24, 2009
gjsmitty634
  • 13 Answers
SOURCE: I plugged in a computer and changed the input to VGA and the TV went blank
It sounds like your tv is in sleep mode.
What are the settings for the computer? Make sure it is set for the vga output. If it is a laptop, this is usually done with a function (FN) key. On your settings screen you can set the resolution and which monitor you are using.
Posted on Sep 29, 2012
VGA CONNECTION TO A SAMSUNG TV NO SIGNAL
have you tryed re,tuneing your tv to see if it finds your vga cable.
or try going into your av menu on your tv and it should give you a list of ext1 or ext2 and so on.or try hdmi 1.hdmi 2,and so on.
May 23, 2014 | Samsung N Computers & Internet
Sep 29, 2012 | Polaroid 2611-TLXB TV
Trying to connect our element flx2210 to a computer through a VGA cord. When plugged in and on the vga input the tv screen says not support. would the computer be too old for the tv?
Sorry that I can't give you an actual solution, but I've been checking up on this TV all night. 90% of the upset people are that way because they either didn't turn off everthing before messing with plugs, or used an incompatible VGA cable (even though I've never heard of one of those. Be careful back there, Element charges $250 for repairs before they even know what the problem is....
Aug 18, 2011 | Element Electronics FLX-2210 22 in. LCD...
I am trying to connect an acer one notebook to a beko 32" flatscreen and everytime i plug the vga lead in the laptop screen goes black an the tv says no signal,,what am i doing wrong??
It could be a no. of things:
- Wrong input selected via the TV
- The VGA input on the TV is turned off
- Problem with the VGA cord
- Problem with either VGA port
there the basics, if there all great and it's still no working, try setting your Computer display to EXTEND rather then projector only, then play around with your graphic output settings.
UPDATE all your Drivers and check all your cables. PLUG IN YOUR LAPTOP, yes it will make a difference to the way the graphics card operates.
Hope this helps.
Mar 05, 2011 | Acer Aspire One PC Notebook
We connected the computer to polaroid lcd screen and it doesnt want to turn on can any one help me
l;kl
  1. Use a D-SUB cable to connect the PC’s D-SUB output jack to the LCD TV’s VGA input jack. Use an audio cable to connect the PC’s audio output jacks to LCD TV’s.
  2. Connect all AC power sources, before turning on the power switch of the LCD TV or other connected equipment.
  3. Press the button on the remote to turn on the LCD TV.
  4. Press the Input button on the remote to select COMPUTER.
Sep 11, 2009 | Polaroid 3211TLXB 32 in. LCD Television
POLAROID TLA 04641C AFTER VGA PLUG TV WON'T WORK
i am having the same problem.. did u ever got it fixed?
May 10, 2009 | Panasonic Televison & Video
VGA shut down
call Polariod
replace 'box'
May 07, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
Oct 19, 2008 | Polaroid FLM-3232 Television
Hi there!
Abby.
Televison & Video Logo
42 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
