Question about Tappan TMT104E1 Microwave Oven
Does Tappan Over the Range Microwave have fuses?
3 Suggested Answers
SOURCE: I am looking for a new door on my Tappan over the
I have one!!
Posted on Apr 28, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: tappan over the range microwave tmv151fs. keypad
"SE" means you have a shorted membrane keypad.
There are three ways to fix this:
The cheapest but most difficult is to remove and replace the membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
Here are the part numbers, which you can order from the Pros here (our favorite supplier) or via the Sears Parts Direct Web site.
MEMBRANE KEYPAD
5304456071 (black)
5304456071 (white)
You can replace the control panel frame, which comes with a new keypad already installed.
This costs is a little more, but is much easier.
CONTROL FRAME WITH KEYPAD
5304456078 (black)
5304456079 (white)
The simplest way of all is to replace the whole control box.
ENTIRE CONTROL BOX
5304456080 (black)
5304456081 (white)
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays may have a lock:
Posted on Oct 18, 2011
Where is the fuse in the Tappan Microwave (undercabinet) mounted
Quite often on an over the range model, the line fuse is located behind the grille or behind the controller, or sometimes in between the door switches.
There is a video available showing how to remove a typical over the range control panel assembly in under 5 minutes here.
You _should_ be able to find links to helpful exploded view diagrams and order parts here.
But if the oven is dead, first check the outlet under load (a toaster or heair dryer work best), then you can suspect the fuse, the magnetron thermostat (or TCO), the oven cavity TCO, or the controller.
Let us know if you need further help.
Jun 06, 2013 | Microwave Ovens
NEED A OPERATION MANUEL FOR A TAPPAN GAS RANGE MODEL#TGF328GSF
The manaul for the Tappan gas range, TGF328GSF, is available from the Frigidaire site: http://www.frigidaire.com/manuals ; then enter your model number. The direct link to the manual is http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316417139en.pdf . Tappan, Electrolux and Frigidaire are all lines within one company now.
I hope this helps.
Jun 14, 2011 | Microwave Ovens
Tappan over the range microwave - exhaust fan problems
most microwaves do not blow air out the bottom.They pull air from the bottom and blow it out the top.
Aug 31, 2009 | Frigidaire Over-the-Range Microwave
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
My tappan microwave come on but does not heat up food
hi,
              When your oven doesnt heat up please do the following,
  1. Check timer and clock settings
  2. Reseat the element
  3. Test the element
  4. Test the element connectors
  5. Test the oven temperature control
  6. Test the oven selector control
For more details refer to http://www.acmehowto.com/howto/appliance/range/erange.php
May 07, 2009 | Tappan TMS062E1 Microwave Oven
User manual for a Tappan mod TMV151FS
You can download your owner's manual here.
Jan 01, 2009 | Tappan Microwave Ovens
Aunt bought a "display model" Tappan Over the Range Microwave Oven from Lowes. Did NOT come with the metal "MOUNTING PLATE". Where can I get a MOUNTING PLATE?
I bought a display model from lowes tappan over the range microwave oven, and do not have the mounting plate, How can I get one?
Aug 28, 2008 | Tappan Microwave Ovens
Spacemaker microwave
What I did was get a shorter cabinet and put it in most suppliers have the same models unless handmade.
Jan 14, 2008 | Tappan TMT104E1 Microwave Oven
Microwave Ovens Logo
Top Tappan Microwave Ovens Experts
William Miller
William Miller
Mark Gough
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
