Question about Riso Office Equipment & Supplies
Risograph ra 4300 only prints two sheets
Hi I have a riso ra 4300 that was stopped for a few years. Today I turn on and all seems well, but there are 1 big problem: only print 2 sheets. If I put 20 sheets to print on menu the riso only prints 2 copies and stops and show 18 on the screen, I press start again and print another two copies and the screen show number 16, and so forth .. the riso stop every one or two prints... today the it show me the T11 error, but I do allreset and the erro does not appear anymore. What I can do? I cleaned machine the best I can do. thank you in aadvance for any help. regards, Joao
sandrew
  • 2961 Answers
SOURCE: HP PSP 2355
the only thing that can be done is to go to your printers and faxes folder and looking for your HP printer icon, right click on it and select uninstal, switch off and remove printer from the usb port Next go to add/remove programmes and look for any HP printer software listing and uninstall it and restart the pc. If you have the installation cd that came with the printer reinstall the driver and when prompted reconnect the printer to a usb port preferebly a different one than before if you have spare and continue. reset the HP printer to the default printer if not already been prompted to do so by the software and try again printing, if the result is the same the printer itself is faulty and requires servicing or replacing
Posted on Jun 24, 2007
SOURCE: HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Posted on Apr 19, 2008
SOURCE: Print stops after 2 pages !
Hi my tally printer 6218 giving Ribbon motion fault, what could be done to remedy this error message ?
Posted on Aug 21, 2008
fer_nan_14
  • 76 Answers
SOURCE: Error code 03130031-2F13
03130031-2F13 A/D Converter external trigger output stopped
and the problem is main controler
Posted on Dec 08, 2008
SOURCE: Riso 3770 Error Code T11
This is a presure motor lock eror . you will have to unplug the potentiomotor on the back of your IO board
Posted on Sep 03, 2009
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
My rp 3700 keeps jamming. It is accepting too many pieces of paper. not sure what to do
Risographs being high speed printers have the separation rollers which if dirty will pull more papers in. Clean the rollers well . Isopropyl helps.
Nov 20, 2014 | RISOGRAPH RP3700/3790 - 2-HI DENSITY BLACK...
How to find a riso 220ui on network or what is the ip address associated with a riso or how can the address be determined?
go to driver downloads at riso.com and download the riso admin tool. much easier than the web interface. test mode/print 95 if you need a config sheet with ip, for example if your subnet mask still isnt letting you see it.
Jan 08, 2012 | Riso RZ220 Duplicator
My risograph CR1610ui won't work. E03 is appearing in the display. i don't have service manual for this.
Where is the near service station for Risograph CR1610 in North East India please give me add and Pnone. no. plis
Feb 15, 2010 | Riso Office Equipment & Supplies
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
Rp 3100 Drum Problem
You can clean it, thats a good idea but,,(and this is messy) roll back the master.. take out the ink cartridge, use a rod to squeeze some ink onto the area, and smooth it out into the screen with a plastic scraper.. Lay the master back over. Keep scrap paper around and print a big black square and run a couple hundred sheets through.. This will work. Messy but will work. If you don't want to manually put some ink on the area.. Print a large black square and run a couple hundred sheets.. see what that does.
Sep 10, 2008 | Riso RZ220 Duplicator
Risograph TR1510
lol.. there's no thermal head on a Riso..lol..
Ok..Print a big black square and run the machine maybe 300 prints until it starts pushing ink through, set the machine on darkest setting.. The ink in the screens is just old and sticky.. If you go through a case of paper (5000 sheets) and it still isn't getting better then take off the master and use some varsol and a lint free cloth (LINT FREE!) to dab and clean the whole screen to loosen up the clogged ink.. If that's not working then you really have to take the screen off and clean it first with varsol,, then some soap and water.. You have to be really clean about this because lint or any thing will cause white dots on your print. (hey this happened to me) If you've cleaned it really well you should take a clean scraper and prime the screen area with some fresh ink.. this is messy.. but it will get you going for good..
Jun 30, 2008 | Sweet Beginnings Cabana Stripes Crib
Lexmark 4039 10r
I'm pretty sure this is a printer not a copier.
Take out the cartridge and turn it upside down, you will see a (Usually) green cylinder, does it have a ring of toner, or does it appear to have been scrathed ?
Take the copy and put it next to the drum, does the lines match? Then replace cartridge.
If not open back and take out fuser ( two screws for cover and two screws for fuser, are the rollers o.k? replace fuser.
Oct 02, 2007 | Riso RZ310 Duplicator
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
