Question about LG Computers & Internet
The DVD Writer will not read the disc. It just keeps popping the disc out that I want to burn images on.
    Sergeant:
  • 376 Answers
The only thing I can suggest is to first clean the lenses then try a different brand of media.
Posted on Jul 06, 2014
Kidyubyub
  • 143 Answers
SOURCE: Dvd player has trouble reading the discs this dvd writer burns
Hey Andy, Sometimes when you burn DVD's or CD's with newer burners, you will undoubtedly burn them set to the highest burning speed. Your DVD player may not be able to read them because of this. Try burning a new DVD set to a lower speed. I have to do this when burning DVD's for my sister. Her DVD player is older and when I burn at a slower speed, she is able to read the DVD with no problem.
Posted on Aug 12, 2006
SOURCE: Samsung DVD writer SH-S182 problem
try a different power connector from psu,do not share same as HD!!should work!!
Posted on Dec 10, 2007
NitrusInc
  • 326 Answers
SOURCE: HELP!!!!! : "Not found CD/DVD Writer driver"
This could be due to a common issue. I would suggest you try this method first.
The following is a link to the Microsoft documented solution for issues with DVD/CD drives, explaining a step-by-step procedure. In the event that the first process, which is automated labeled "Fix It" does not solve your problem, please continue to the end of the document.
http://support.microsoft.com/kb/314060
After completing this procedure, please let us know if you are still experiencing any issues by posting a comment. If this information was helpful, please take a moment to rate the solution. Thank you
Posted on May 17, 2009
Testimonial: "thanx"
  • 355 Answers
SOURCE: the LG 18x dvd writer does not read all dvds but
if it is comes under warrenty
Posted on Oct 03, 2009
  • 1481 Answers
SOURCE: LG GH22 LS50 (Sata Dvd Writer) Will not write dvd discs
What software do u use to write DVDs on both PCs...
if they are different then that may be the issue....
dont spoil the DVDs....
try DVD RW disks...that way you can erase them later...
i too have the same DVD writer, not had any issue in either XP or Win7....i have dual boot and have made many movie DVDs using both OS...i use Nero and Power2Go of LG(the install disk that came with the LG DVD writer has this great software...."LG Power tool")
try this tool...it should work...
the inbuilt DVD creator in Win7 has some issues with DVD creation....due to non compatibility of graphics card and display drivers (WDDM)....+ you may not have the correct codec required to burn DVDs.....
get the FFDSHOW codec from google.... and install it...shutdown and restart and then try...
let me have a feedback pls...
reg
Posted on May 04, 2010
A freind let me borrow their hp dvd 1040e external 20x multiformat dvd writer. i can burn the music on cds fine with itunes, but i cant figure out how to use the litescribe to burn images on the tops....
You will need Nero burning software. It will after the normal burn show you a screen where you place the image you want to burn for lightscribe. Another failing with lightscribe is that you must have lightscribe discs!
Jul 09, 2011 | HP DVD1040i 20x Super Multiformat Dvd...
When attempting to burn project in MY DVD8 an error appears 800402007 while encoding. I am therefor unable to burn disc
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
      Tip: Either of the above options are a great way to not only back up your projects, but make multiple copies to reduce encoding time!
Mar 03, 2008 | Televison & Video
I have 32 bit windows 7- I try to burn the back up dvd's and everytime it either says to please insert media ( its inserted) or it says media needs formatted? I have tried like 50 times and no go every...
are you sure that it is a dvd writer >??? and not a cd writer ..dvd combo?? in this case you can not burn but a cd..and play the dvd ...Im saying this cause most of them are equipped like that it plays dvd-es but burn only cd-es..another thing try to install a bunner like nero ..or iso hunt ...if it doesnt want to ..maybe is all in right with the os...in both cases try to burn an image on the hdd ...like in a game that came iso...just choose burn image ..or change the device into the image burner ...and will burn a image with the recovery dvd you want to ...this one export it to another computer on a memory stick ..and burn it to a disk..
Mar 29, 2010 | HP Compaq Presario C700T
Dvd writer will not burn disc images, it will burn all other types ie music cds, data dvds, file backups, cant find name of dvd writer to get firmware update
Usually, you need software to read an 'ISO' disk-image file, and to decode the file, and to burn to a CD/DVD,
e.g., "AShampoo Burning Edition 6" is a free download from http://www.MajorGeeks.com that will do the task.
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Select and expand the CD/DVD branch of the tree.
Double-click the CD/DVD drive.
Click Details to dislay the name/model of the device.
Nov 14, 2009 | HP G70-250us Notebook
My lite-on DVD writer is not reading any dvd's as well not writing any DVD's while it is good for CD's..... What is the problem?? How can i correct my DVD writer
Hi Please try and use a different brand of DVD discs. DVD disc quality is sometimes an issue with lite-on drives Also check that you have updated drivers and your media burning software is installed correctly. Again if your using NERO this can be a problem. Try using any other burning software One other thing to try when recording DVDs set the recording speed to lowest Many Thanks Andy
Apr 27, 2009 | Computers & Internet
Drive does read audio cd but not dvd.writer also can't burn any.
If you have Roxio or Sonic installed, sometimes the configuration will get corrupt.
Uninstall all application software that relates to any CD/DVD burning, and try the following:
Download the following FREE burner....it is the best burning software I have ever used and it is FREE!
ALWAYS set the burn speed very LOW....4X for CD's and 2X for DVDS and you will never go back to the other burners again!
The BEST options for using InfraRecorder is to burn data discs, burn Disc images and to create Disc images.
I trashed Roxio and Sonic because they are too memory dependent and they contradict each other's configuration...
Tall Tiger
35 years experience....
Feb 17, 2009 | HP Computers & Internet
Cannot backup files to a cd/dvd
we may need more details but you can try this for now
1. are you sure you have a cd writer or a dvd writer (writer = burner)--- check the front edge of your cd/dvd unit and look for words like "writer" "burner" or writeable next to the word dvd or compact disc... keep in mind not all cd/dvd writer can write (burn) cd or dvds, some may burn cd but not dvds.
2. is your cd/dvd unit compatible with the media (cd or dvd blank disk) you are trying to use.. depending your cd/dvd especifications your dvd/cd drive is compatible with certain types of cd or dvds that are writeable.
3. is the cd/dvd a writeable cd/dvd and is compatible with your cd/dvd drive? for instance.. if you are using a blank dvd and your cd/dvd drive only burn cd/s and read dvd and cd you won't be able to write to the blank dvd.
4. are you trying to burn a dvd in a corporate computer.?? as a user (not an administrator) of your corporate computer you may not have priviledges that will allow them to burn dvd/cd's even you your drive and your media are compatible.
please post
the error that you get
the brand and model of the computer you're using
the type of media you're using
Oct 02, 2008 | Computers & Internet
Registry problems with my dvd rewriter
please check have you install any burning application?
example nero...........
and sometimes it sensitive to some cd/dvd
what disc have you try to put it? cd or dvd?
please make sure your disc writer support dvd burning.........
does it able to read any disc?
Aug 24, 2008 | Computers & Internet
LG DVD writer problem
You should be using the software "NERO" to burn discs.Goto>start>all program>Nero>Data>NeroExpress
Here you clearly see the two types to burn disc "data cd" and "Data dvd".
Need More help?.if yu are using another software whats that?
Mar 07, 2008 | Computers & Internet
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Computers & Internet Logo
    50 people viewed this question
    Top LG Computers & Internet Experts
    Michael Vincent Cruz
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
