Question about Syscan DocketPORT 465 Scanner
Scanning touch-activated display screen not active
Qualcomm mcp200
How do I disable power save mode
Press the Power key > Activate power saving. To deactivate power saving mode, press the Power key > Deactivate power saving.
When activated, the power saving mode turns off some functions automatically. Radio configuration in power saving mode include the cellular radio (it is set to 2G/GSM only mode), the Bluetooth radio (it is turned off) and the Wi-Fi/WLAN radio (scanning for new networks in turned off but existing networks keep functioning). The power saving mode also reduces display power consumption by minimizingscreen brightness and by turning off touch screen feedback and theme effects. In addition the vibra alerts are turned off in a power saving mode. Hope that helps Anomy.
Mar 16, 2015 | Nokia N8
Tip
HTC Touch Soft Reset Soft Reset Occasionally, you may need to reset your...
Soft Reset
Occasionally, you may need to reset your device. A soft (or normal) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
To perform a soft reset
Use the stylus to press the RESET button found at the bottom of your device. Your device restarts and displays the Today screen.
I hope that helps.
____________________
Download the HTC Touch Manual.
HTC Touch Clear Storage.
HTC Touch Hard Reset.
on Apr 18, 2010 | HTC Touch Cellular Phone
Unfortunately om.sec.android.app.sansungapps has stopped
Mine has done the same on my android phone. I just ignore it, press ok, and carry on using it. Ive tried a factory reset but still no luck. Regards, Graham
Oct 19, 2014 | Samsung Galaxy TabPRO SM-T320 32 GB Tablet...
Qualcomm mcp200 keeps shutting off and restarting but will not fully boot up
What you are experiencing is called rebooting, in this case what has happened is that the computer is encountering a problem crashes the operating system, so it shuts down and reboots. Since it cannot boot into Windows, it is called a "reboot loop" because it does this spontaneously and repeatedly. You have to find out what is conflicting with your OS (operating system).
There are a variety of ways to approach this, but I need more information, especially your version of Windows.
I am a mod at (free) www.suggest-a-fix.com and can more easily help you there. This forum is just not set up for easy active replies and picture uploads for difficult problems. By the way, sometimes someone suggests reformatting and reinstalling Windows, and most of the time that is not necessary. But without more information I cannot help you further.
One thing that you can try is a system restore, both XP, Vista and 7 have this feature. I suggest you Google for information on your version of Windows there, or post in at my forum.
Jul 15, 2014 | Computers & Internet
Restore software for ipod 16GB touch
i would be checking the usb lead before doing anything or even replacing it with a new one make sure iis securely connected
the cable near the iTunes symbol represents a problem with the cable
and the cd will not not be able to activate without a connection
Connect one end of the USB sync cable to one of your computer's unused USB ports, and connect the other end to the bottom of the iPhone or iPod Touch.
If iTunes does not start on its own, run it using the desktop or Start menu shortcut.
When iTunes starts, you should see an icon for the iPhone or iPod Touch on the left side of the window.
Click "Summary" in the right pane of the window if it is not already active.
Click the "Restore" button to begin the device restoration process.
ITunes displays a message asking if you want to save the contents of the device to your computer before restoring it.
If you have not backed up the device already, click the "Back Up" button.
If you have already done this, click "Don't Back Up."
Click "Restore." ITunes clears the data from your iPhone or iPod Touch and reinstalls the device's original firmware.
The screen of your iPhone or iPod Touch may shut off while iTunes works.
Do not remove the USB sync cable.
When iTunes is done restoring the device, it displays a message letting you know that the device is about to restart.
Click "OK" to restart the device. If you are restoring an iPhone or iPod touch, wait for the "iPhone / iPod touch is activated" message to appear on the screen of the device before you disconnect it from the computer.
You may now restore your backup of the device or remove it from the computer.
hope this helps
Sep 15, 2012 | Apple iPod touch
Screen flicker
I personally would reinstall the video driver to see if its the culprit. Also see if there is any drivers for the display as well. I also realize you said it goes away when you run an AVG scan, this is because when AVG does a scan it activates files, so essentially if your video or monitor driver is no active, then when activated it would stop the problem.
Apr 14, 2010 | Compaq Presario Notebook
No Touch Screen Display
Try pressing "Clock" and then "Start"
Mar 16, 2009 | KitchenAid KHHS179L Convection/Microwave...
I am trying to reset my T Touch watch from Tissot and can not find book. need to reset time and also how to convert from metric to US standards, like ferinhit and from meters to feet.
SET TIME:
1. Activate Crystal
2. Tap center of screen until digital time comes up
3. Press and hold top button (+) until watch beeps, display will be flashing
4. Use + and – key to adjust time. If several hours off, hold appropriate key and
after first hour passes, only the hour hand will move.
5. Make sure the digital display shows A or P for AM or PM
6. When finished, touch center of screen again.
SET DATE:
1. Activate Crystal
2. Tap center of screen until date appears
3. Press and hold top + button until watch beeps and display flashes.
4. Use + and – buttons to change date to correct one.
5. Make sure to set time first, if you set date first, you run the risk of the date
changing at noon rather than midnight.
Nov 26, 2008 | Tissot PRS 516 T91142651 Wrist Watch
How do i activate scan to email on xerox 7132
The Scan to E-mail feature provides the ability to scan and send a document as an e-mail attachment.
NOTE: The Scan to E-mail Kit is required to enable the Scan to E-mail feature. The kit contains a License Agreement, installation instructions, and a password.
You must be a System Administrator to perform this solution.
To enable the Scan to E-mail feature:
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm]. The System Administrator Menu screen will be displayed.
  5. Select [System Settings] twice. The System Settings screen will be displayed.
  6. Select [Common Settings]. The Common Settings screen will be displayed.
  7. Select [Maintenance / Diagnostics]. The Maintenance / Diagnostics screen will be displayed.
  8. Select [Software Options].
  9. Select [Keyboard].
  10. Enter the password contained in the Scan to E-mail Kit using the keyboard on the Touch Screen, and then select [Save].
  11. Select [Reboot]. The machine will automatically power OFF, and then power ON.
  12. Enable the Scan to E-mail port settings. See the Related Items below. After the port settings have been enabled, the E-mail option will be displayed on the Touch Screen.
Jul 30, 2008 | Xerox Office Equipment & Supplies
Syscan DocketPORT 465 Scanner Logo
37 people viewed this question
Top Syscan Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Syscan Office Equipment and Supply Expert? Answer questions, earn points and help others
