Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Assa1875@sbcglobal.net Help! I am at work and need your help. We have a Panasonic Panafax PX-150 and the error message that is showing on the read out screen is 458....on the problem solving sheet that came with the fax machine...there is no 458....but 459 says "communication error occurred while receiving" Check with the other party....how can you check with the other party when no # shows? Can you help? Please use my e-mail address to answer. Thanks! Mary
    Scholar:
  • 159 Answers
The error is a communication error. Either the tel line is noisy or the signal too weak. The problem lies outside the machine, and the machine can only identify the global problem not the root cause. You may want to call your Panasonic Tech to check the line condition and tweak the line settings, but other than that, you are at the mercy of your sending party or the tel line company.
Posted on Feb 11, 2008
ERROR CODE 041 ON PANAFAX
There is a fix for this. But only a Panasonic tech has access to the parts for the fix. The toner sensor underneath must be moved closer to the cartridge, you are not low on toner.
Jun 15, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
Error Message Reads: Check Scanner Unit E01-31
try checking the scanner cable . look through the glass back right . you will see a usb cable.. check both ends.. if there connected properly and you still get the error.. you need to replace the whole scanner unit
Oct 14, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
We have a Panasonic Panafax UF-790
It could be a refilled Kyocera KM-F650 cartridge in a Panasonic UG-5510 box.
They look identical, but are configured differently.
You need to try another cartridge as it appears it is not a machine problem.
Dec 30, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Leading edge
Yes,
it's whacking the metal guide plate on the bottom below the white reference strip., I have had to gently "reform" the guide by opening up the space with a large screwdriver..
Oct 03, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Panafax UF-7100 showing install developer
Unplug power / plug back in.... NoGo? try this:
Function
7
press monitor key slowly 4 times
6 (RAM INITIALIZE)
scroll down to CLEAR FLASH MEMORY
set (wait for reboot)
If that doesn't work, scroll down to ALL JOB CLEAR and set.
Last resort....
scroll down to SHIPMENT SET
set
2 for no
Did the developer problem go away?
Sep 08, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Every time i try to find the panafax px-150 it goes on panafax uf-595, so it must be the same way to program the date and time..
- FUNCTION key + " 7 "
- " 1 "
- " SET "
- Enter new date and time : ex: 03............Month
26............date
2008............year
1900............time
If you make a mistake just use the arrow to move the cursor to the incorrect number, then overwrite it.
- " SET " key
- " STOP " key
Hope it help you!!!!
Mar 26, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panafax px-150
Hi, Error (004) as displayed in your printer refers to the option setting (output tray) that you set in your printer properties in your PC. (Assuming you are running WinXP) Start. Printers & Faxes, Right click on PX 150 and click pproperties, Printing Preferences. Set output tray. More details are availbale from http://panasonic.co.jp/pcc/products/en/mfp/download/dp-c322/ps/opc3psen.pdf Hope this works out for you. Godd luck
Apr 22, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
175 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
