Question about Canon imageCLASS MF6550 All-In-One Laser Printer
Processing data light is on nothing comes out
Processing data but nothing processing
in the printer properties on the pc , check for the list of items to be printed as there may be a confusion there that is not allowing the pc to send the data to the printer
Dec 18, 2015 | Canon MF8350Cdn AllInOne Laser Printer
What does "100 %" stacked mean?
it means that the printing order for the memory for the printer is full
go to control panel , go to printers and hardware , click on printer right click and it will show a section see what is printing
high light each line and delete that takes away the priority of the stack until there is nothing left to print and the printer should again print at the next selection you make
How the program works is this
there is a small memory in the printer and a large one in the pc
when you have data that is to be printed, the pc sends the data until the printer memory is full at which stage the printer starts to print. new data is sent as memory space becomes available until the document is printed
when different data is requested to be printed or there is a hiccup in the process the pc looses the priority in the print list ( page number or new document)and so backs up that memory and becomes blocked
by going into the pc in the printer hard ware and deleting the printing waiting to be processed your are unblocking the process and allowing the pc to again move data to be printed
Nov 08, 2015 | Brother Office Equipment & Supplies
Drive unable to initiate start-up process. Have power and can hear drive "clicking" but nothing beyond this. Green power light is on but red processing light is not coming on. This drive used to...
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Nov 25, 2010 | Beyond Micro Mobile / 80GB / 5400 / 2MB /...
When does the lamp kick in right when it start or when the lamp light comes on
This varies by manufacturer and projector model. Without knowing the make and model of your projector it's hard to give you an accurate answer.
Lamps in Hitachi data projectors tend to come on almost immediately after starting the machine. Lamps on the older InFocus projectors took a bit longer before you'd see light coming through the lens.
If there is a short delay between the time you start your projector and when you first see light, I would not be concerned. Data projectors have to cycle on the same way they cycle off, meaning it's a process and sometimes seems like it is running slowly.
Mar 12, 2010 | Hitachi CP-S240 Multimedia Projector
Dell Dimension 5150 will not start!
This is related to Hardware.
There might be a lose Ram of data cable connection on Motherboard.
This type of issue is also seen when the there is dust accumulation on Process Fan and CPU fan resulting in over heating.
This might also be due to malfunction of a motherboard.
The third reason could be that SMPS his not working.
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Green horseshoe light is continually lit
If it is solid on, it means the printer is ready to print; no action is required. If it's flashing, it means the printer is processing data and should print soon.
If you are printing from your computer and nothing comes out, with the "Horseshoe" light staying solid, I suggest checking the connection between your computer and the printer, or at least the printer configuration. Most of the time, unplugging, then plugging cables back in does the trick.
Jul 06, 2009 | HP Color LaserJet 2550n printer + HP Color...
Sandisk cruzer micro 4GB
Check on another system, if still no response then data cannot be recovered. How ever you can use software RxStudio to check
Jan 27, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Fluctuating display when processing data in my PC
Does it mean that text, or any data found in your monitor has a shadow? There is nothing wrong which kind of system your using (xp, linux) it is on the monitor. It is on the mixing of color, the repair man/technician knows how to adjust those things.
Thanks
Nov 19, 2008 | LG Studioworks 700S 17" CRT Monitor
Canon imageCLASS MF6550 All-In-One Laser Printer Logo
old marine
old marine
