Question about Pioneer AVIC-D3 Car DVD Player
How to conect a pioneer touch screen to after market honda adapter
Nextbook problems
Hi you could:
*check you have enough space
*check your internet conection
*update your app market
*run a ccleaner/history eraser
*use a task manager to see what else is running
*ask someone more inteligent than me
Hope this helps :)
Feb 15, 2014 | Nextbook NEXT2 Touch Screen Android Tablet
Power but no sound
If your car has an OEM amplified system, make sure the blue (or blue/white if your radio has both) is connected to the blue or blue/white in the after market harness adapter.
Also make sure none of the speaker lines are touching metal (grounding out) or touching each other
Dec 12, 2011 | Pioneer DEH-1300 CD Player
How to integrate the pioneer deh-1300mp into a 96 Dodge 2500 Centurion diesel truck to replace a radio/cassette player.
The simplest way to swap the stock radio out for the cassette player would be to go to a radioshack or bestbuy, normally they will carry a double-din to single-din adapter so that the smaller after market radio fits into the existing location snugly. They usually also carry a wiring harness adapter that will plug right into your dodges existing harness and you can just wire nut or solder & shrink wrap the adapter to the pioneers harness, saves a lot of time and insures everything is where it needs to be.
Normally you can get both adapters for under $15, hope this is helps.
Mar 08, 2011 | Pioneer DEH-1300 CD Player
I have a pioneer dehp6800mp and i want to install a ipod adapter cable, will the pioneer cd i 200 work? and will it also charge my ipod while its plugged in?
You would need the Pioneer CDIB100 iPod adapter instead.
It might charge your iPod, but it does not charge some iPod devices such as the Nano, iPod Touch, and iPhone.
Mar 03, 2011 | Pioneer DEH-P6800MP CD Player
Calibrating touch screen
calibrating touch screenProblem with Pioneer AVH-P5750DVD Car DVD Player
May 20, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Kicker Amplifier v. Pioneer Head Unit
GET RED POS+ LONG WIRE 2 BATTERY 2 WERE UR AMP IS GANA GO CONECT IT TO THE AMP POS+ (2)GET NEG- WIRE CONECT 2 WERE THE NEG- IS ON THE AMP THEN THE OTHER END OF SAME NEG- WIRE FIND PLACE NEXT 2 AMP WERE U COULD SCREW NEG- TO CAR METL CLOSE 2 AMP (3)GET LONG REMOTE ANT. WIRE CONECT IT TO WERE THE REMOTE ANT CONECTION IS ON AMP THEN SEND IT TO UR PIONEER IS AND FIND REMOTE ANT . ON UR PIONEER HEAD AND CONECT IT SO IT SHOULD BE CONECTED TO UR AMP LAST PART GET THE LONG RC PLUUGS AND CONECT TO UR AMP THEN RUN THEM TO UR PIONEER HEAD WERE THE RC PLLUGS INPUT IS THEN IT SHUD BE DONE!!!
Mar 13, 2010 | Kicker KX500.2 Car Audio Amplifier
No sound with iPod Adapter CD-IB100II in the DEH-P2900MP
on the radio and the adapter their is a spot for the cord that connects the two the ends have different colors on them it should be purple and black just make sure the colors are matched up if they are off it will still read all the info and say its playing but no sound will come out
Oct 15, 2008 | Pioneer DEH-P2900MP CD Receiver...
After market car stereo
Those adapters are readily available through car audio shops, or places like Best Buy.
Jul 31, 2008 | 2000 Pontiac Montana
Problems conecting to pioneer reciever
You will need a 1-to-2 AV Y-adapter. One end will plug into the headphone jack of your mp3 player, and the other end will plug into the red and white audio input of an open slot on your Pioneer receiver. Then change the mode on your Pioneer receiver to correspond to the input jack that you are using. If you plug the Mp3 player into AUX, change the pioneer mode to AUX, etc.
Jun 20, 2008 | GPX MW3837 MP3 Player
Pioneer AVIC-D3 Car DVD Player Logo
15 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
