Question about Hand Tools
Where can I get a rapitest et 111 manual?
How do I find the fuse on a Rapitest et 111 electrical test meter manual fuse. It has blown and I need to replace it.
2 Suggested Answers
  • 57 Answers
SOURCE: online manual for Rapitest Wps 115 Wire/Pipe & Stud Detector
go to the support center for the maunfacture site
Posted on Oct 13, 2009
How to use rapitest pt112 power tester?
Go on the net and get the manual on a download from axminster.com
Jun 15, 2014 | Cars & Trucks
Rapitest digital plus moisture meter manual
www.lusterleaf.com/img/instruction/1825_instruction.pdf
May 23, 2014 | Measuring Tools & Sensors
Rapitest Pipe stud and wire tetecor instruction
no idea never used one to be honest but i would imagine that passing it over a cable it would emit a noise ??
Feb 02, 2012 | Cars & Trucks
I want to change a plug socket, and know that I need to turn of the elictricity at the mains, and check the wires with a volt checker to check for live current. I bought a Rapitest digital mini electrical...
Yes you can use this instrument to measure. It needs to be put on the AC voltage and to be on the highest value. Voltage is measured with a fuse included (be careful). It is better to use a screwdriver tester to find a phase (hot wire). Wires are measured ohmic and should not be turned voltage on(or it may burn the instrument). If you measure current it can short circuit if the installation is under voltage (because of this reason the current is measured in series connection).
Sep 01, 2011 | Measuring Tools & Sensors
What is the sonin rapitest power sensor? I have one but do not know what it is for. Thanks. tk
Sonin Rapitest power sensor will identify live electric wires within your walls. Mine quite working this weekend. lwf5990@frontier.com
Feb 02, 2011 | Garden
I have a Rapitest pipe/wire and stud finder but have lost instructions.Can you please help. What is the significance of the circle and the triangle settings?
If its like my one (Different brand) you simply switch on and adjust fine control till the lamp just comes on then turn opposite way till lamp just extinguishes, Make suer the unit in pressed onto the wall.
Jan 26, 2010 | Hand Tools
Online manual for Rapitest Wps 115 Wire/Pipe & Stud Detector
Oct 13, 2009 | Hand Tools
Electrical cables are all black & I need to find which is live &
ac, aka, alternating current, is the type found in your house. dc, aka, direct current, is the type found found in your car...or any other type of battery. If you have a total of three wires, one green, (ground) and the other two are black, then the two black wires are your alternating current wires. If this is the case, hook up your black wire from the fan and light to one of the black wires, and the whites, or commons, to the other black wire. In alternating current it does not matter which wire goes to where.
If there are 3 black wires, and a ground wire, then you will have to use your volt meter, and check the voltage from the wires, you should take three readings (wire a-b, wire b-c, and wire a-c) two readings will give you 120 volts and the third will give you 240 volts (approx) The two wires that give you 240 are your hot leads, and are probably controlled seperatly by wall switches. Hope this helps.
Jun 22, 2009 | Dryers
Pressure washer karcher
Sounds as simple a fix as " The Fuse Has Blown "
Check the fuse in the plug, and it,s Rating.
I,d assume this should be rated at 13 AMPs.
If the fuse is 3-5 amps it,s under-rated.
You should get it tested out if your not electrical minded, you may have a short circuit. live/earth et.c.
hope this helps.
Mike @ Compurepair.
Mar 26, 2008 | Karcher 2500 PSI Pressure Washer
Hand Tools Logo
65 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
