Home | Maytag | Neptune Front Loading Washer w/Built in wat... | Neptune MAH6500aww won...
Maytag Neptune Front Loading Washer w/Built in water heater, MAH6500
Problem for Maytag Neptune Front Loading Washer w/Built in water...
Neptune MAH6500aww won't spin
By atticstud on Jun 08, 2009
it fills, agitates and pumps water out just fine. Originally told by appliance tech to replace the pump. Bought new pump ran load and again when it came time to spin. It thought about it but did not spin. Just kicked itself off after trying to spin. The tub does turn during wash cycle just won't spin. Should I look at replacing the board.
Solution #1
posted on Jun 08, 2009
Not Rated)
justaskjoe
Rank: Guru  Maytag Expert
Rating: 85%, 1874 votes
there are several reasons why your machine won't spin. review this list and discover the specific reason you are seeing
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune Front Loading
Questions and Unsolved Problems for Maytag Neptune Front Loading
Do you recommend Maytag Neptune Front Loading Washer w/Built in water heater, MAH6500?
Answer
Answer
I have the maytag neptune stackable washer, dryer, it does not spin, I have had 3 people look at it.... (More)
Answer
Maytag model MAH3000 won't shut off after final rinse. Trouble shooting document in washer control... (More)
Answer
The unit keeps filling until water leaks from the door. Unless we hit the stop button the machine... (More)
Answer
We have a Maytag front loading washer purchased in 2005. We have a problem with black flakes about... (More)
Answer
Is it normal for a "Quick" cycle on the Maytag Neptune to take 53 minutes? "Normal... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag Neptune Front Loading...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14173
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
