Question about LG Computers & Internet
LG Flatron Monitor will not come on
When I push the power button, the bar under the power button flashes blue but the monitor will not come.
4 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: LG Flatron W2234S monitor seems to be in sleep mode.
the backlight fluorescent bulb is burned out
Posted on Dec 26, 2008
SOURCE: LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Posted on Jun 03, 2009
  • 460 Answers
SOURCE: i want to know ls flatron monitor shape settings
there is usually a default setting in the os menu.
Posted on Nov 12, 2009
I can not turn off the sleep mode on my LG Flatron monitor W2361VG-PF
This monitor has a manufacturer's defect in two of the wiring harnesses: the harness going from the controller board to the power button (4 grey, 1 blue wire) and from the power button to the side controls (3 grey, 1 blue wire). Open the monitor (snaps apart, no screws) and gently tug on each wire individually. One of them is causing the problem. You can replace the harnesses, try to fix them, or solder new wires directly to the pins.
Feb 16, 2013 | LG FLATRON W2361V 23 inch LCD Monitor
Hello my flatron l206wtq-bf doesnt work the light of power flash blue and the monitor doesnt open do you have a solution for me thanks
Your unit has a power supply that has failed. When the power board starts failing you may get a wavy display, it may be slow to show a picture or you may just get the flashing power button light that you have. The problems are caused by parts called capacitors that have bulged and failed. Here is a link to a repair guide for the LG L226 that uses the same power supply board as your unit.
http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/
The dis-assembly information is almost the same to.
I hope this helps, if so please rate my solution.
BuddyMc
Aug 01, 2011 | LG FLATRON L206WTQ-BF Monitor
Power button flashes blue every couple of seconds, never comes on.
This usually happens due to a bad connection between the PC and the monitor. Make sure your video cable is tightly lugged in, if this is not the problem the drivers are probably faulty, revert to your old monitor and reinstall the drivers and try again. If the problem still persists then call LG technical support.
Mar 04, 2011 | LG 22" FLATRON LCD Monitor
Lg Flatron L226wTQ, power button failing
This problem is usually caused by a failure in the power supply board which in turn is caused by a failure of the filter capacitors. We have a repair guide article posted on our web site at: http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/ Check out the article and then open your monitor up and look for the failed capacitors, replace them if found and you should be back going again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 16, 2010 | LG 22" FLATRON LCD Monitor
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Lg 22' monitor was widescreen now has black bars!! Cant remove ?
the grpahics from wowc burnd the sides of your monitor. your pretty much screwed if you keep playing that game
Aug 16, 2009 | LG Flatron L1710S 17" LCD Monitor
Won't come on after power outage
Sometimes you have to unplug the monitor from the power supply and wait at least 30 seconds before plugging back in, and make sure you don't need to press the reset button on the power strip.
May 07, 2009 | Computers & Internet
Apr 20, 2009 | Computers & Internet
Lg flatron l1510s
Try hooking the monitor up to another computer to see if the symptom remains the same if it does you might be needing a new monitor
Nov 01, 2007 | LG Flatron 775FT 17" CRT Monitor
Computers & Internet Logo
32 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
