Question about Toshiba 62HM195 62" HDTV
62" Toshiba DLP 62HM195 - the TV picture has developed horizontal red tinted lines which move around and sometimes appear as a shadow on whatever is being shown on the picture. No noises are associat
Picture has developed a red horizontal tint which moves around the picture. the red tint sometimes appears as a "shadow" on the picture. No noises are associated with this development on the picture.
  • Craig Harrington
    Craig Harrington Mar 19, 2014
    No one has any ideas about what the problem may be with this red tint showing up on the picture?
techman
  • 3130 Answers
SOURCE: 32" Toshiba television Mod. 3357DB
If im not mistaking I remember the toshiba 32" to have an on screen alighnment in the sevice menu.. and I would not recomend that anyone without the proper manual and tools to fool with these adj as I've seen in the past that a set had to be completely redone even the tuner alighnments after someone went in and tryed to adj the set., Now the green tinge you speak of is the CRT getting weak The best way to ajust this would be to see if on the picture tube pc board on the end of the Picture tube if it has any little control on it ? if it does look for the green drive and put on a b&w Picture. slowlty turn down the green drive control untill the pic look almost B&W and you probably wont be able to get perfact grey scale as the crt is weak . If theres no controls on the crt pcb then your gonna need a service alighnment manual and adj the green drive that way. Good Luck
Posted on Apr 24, 2006
techman
  • 3130 Answers
SOURCE: Thin horizontal line across picture
I really dont understand the problem Could we see a picture of this please?
Posted on Jun 14, 2006
  • 14 Answers
SOURCE: magenta tint to the projected image
The Lens assembly requires service. The dust is inside the panels.remove the dust and that will work fine
Posted on Jun 04, 2007
premtech
  • 934 Answers
SOURCE: Red?Green picture
You may have inadvertantly loosened a cable connection to the DMD or logic board... You might be able to shut it down, unplug the unit and remove the lamp.. With the lamp out take a good flashlight and shine it into the lamp housing area inside the Tv and see if you have any wire obstructions that you could have contacted with the edge of the housing as you were removing or inserting the lamp...
Bill
Posted on Feb 03, 2008
ginko
  • 19396 Answers
SOURCE: Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Posted on Sep 02, 2008
My Toshiba 62hm195 DLP HDTV's HDMI ports have been losing sound intermittently. Both HDMI ports while connected to multiple devices (HDTV cable box, Panasonic Streaming Player) lose sound intermittently...
Your problem is in the streaming player. It is not keeping up and when an HDMI loses connection it will not auto find it again. To verify this take the Panasonic out of the loop and see if this fixes it. I love HDMI but it is touchy
Feb 18, 2015 | Toshiba 62HM195 62 in. HDTV DLP TV
My toshiba tv turns off by its self everyday at 4:30 am how do i stop this
Check your settings, you may have time set to turn off at this specific time. Uncheck this setting or set to value 0.
Hope this helps
Apr 19, 2014 | Toshiba 62HM195 62 in. HDTV DLP TV
There is a black box in front of the screen
Look under closed captions---black box is TEXT and it can come from either the set or a box if used---set or box is likely set to Text 1.
Jul 17, 2012 | Toshiba 62HM195 62 in. HDTV DLP TV
Toshiba 62HM195 DLP right hand screen black but left hand screen works
You are describing a damaged optical light engine or the display chip which is part of it (chip is about 200 plus a lot of labor)
Apr 01, 2012 | Toshiba 62HM195 62 in. HDTV DLP TV
Toshiba 62 inch dlp tv keeps flashing green and will not turn on
green flashing for .3 sec with solid red indicates lamp problem. and do you have the manual? If so, look in the appendix for a section 'LED indications'. that gives you the code for the indications.
Good luck..
Aug 29, 2011 | Toshiba 62HM195 62" HDTV
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Toshiba 62hm195 repair issues
This may sound obvious but did you check to make sure that your lamp access door is properly secured? The set will not power up if the door does not contact the micro switch. Also double check all of your internal wire connections. You may have inadvertently forgot to reconnect a cable or not fully seated one. I know I was guilty of both errors at one time or another while I was working on mine.
Jul 07, 2008 | Toshiba 62HM195 62" HDTV
62hm195
It sounds similar to my Toshiba 62HM195 that I posted about except my screen is spit down the middle and my bottom half is messed up but the upper half is Ok.  I have been told it is a bad Light Engine Part # 23405481.
Oct 07, 2007 | Toshiba 62HM195 62" HDTV
Toshiba 62HM195 62" HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
