Question about Craig Electronics Recertified - Craig CLP281 Black 7" Netbook
Clp 281a will not charge
It says plug in charger but nothing happens?
  • 1,087 Answers
Quite a few guys seem to have problems with this netbook.
Check the mains socket is ok first by putting a desk light (say)
If that is ok, check the output from the charger with a voltmeter (or take it to an electrics shop)
If the charger is faulty-change it. If it is ok, then you probably have a fault on your netbook
Posted on Feb 11, 2014
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Nothing happened when i charged it up
Hi, What you will need to do when mp3 player does not charge. First use another charger to test if it's the charger is working properly.
And secondly After testing for charger, and still it does not charge, that means the charging port on the mp3 player where the charger is been plugged in is not working properly. You will need to replace the charging port.
Hope it helps.....
Nov 29, 2010 | Audio Players & Recorders
Just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
May 21, 2010 | Pride Mobility Products GoGo Ultra X...
Problem charging my Nokia 7610 cellphone
1. try to check if your charger is working or not
2. if charger is good.then try to replace the charging socket of your phone.you have to open it,but if you dont know how to do it.you need to go to a technician to fix it for you rather than taking the risk.
Apr 11, 2010 | Nokia 7610
Phone was working fine then battery went out of charge,when I got home I PLUGED IN MY CHARGER AS NORMAL BUT NOTHING I HAVE TRIED SEVERAL TIMES TO GET TO GHARGE BUT NOTHING.
Try these and tell me the result.
1. Try to charge from a different charger.
2. Use another battery and try to on the phone.
3. After plug on the charger press power on/off button for a while. If nothing happened on your mobile after use these 3 tips then visit Nokia service center for installing the operating system on your phone. If the OS is corrupt then the mobile going under dark. No movement, no signaling of charging nothing. Even you can't update it from internet right now. Because the phone memory is fully dead. Its happened with all mobiles if the OS corrupt. Its was happened also in my Nokia N73.
Thanks &waiting for your reply.
Feb 04, 2010 | Nokia N95 Cellular Phone
Nothing happens
The charger connection is sensitive on the Reflex Pro. It isn't uncommon to plug in the charger, see the light flashing, then when setting it down a slight movement of the cable stops the charging (light will stop flashing). Try connecting the charger again (if you haven't already) and let it charge for about an hour. While getting a good charge can be frustrating, it is worth it for the 4 minutes of fun to follow :-\
Aug 16, 2009 | Spinmaster Air Hogs RC Reflex Micro...
We cannot get our psp to charge. When we plug it in to the charger, nothing happens
I assume that your battery is good. I would try borrowing someone elses charger to see if that is the problem. Also you could plug your charger into their PSP. This will determine if the charger is the problem. If you still can not charge your PSP, it could be a bad charging jack.
Jul 31, 2008 | Sony PlayStation Portable (PSP) Console
Rokr e6
did that, both chargers work, fully charged both batteries. But when i plug the chargers into e6 it does not say charging battery and the battery symbol does not blink
Feb 16, 2008 | Motorola Mobility ROKR E6 Smartphone
Craig Electronics Recertified - Craig CLP281 Black 7" Netbook Logo
60 people viewed this question
Top Craig Electronics Computers & Internet Experts
Tony
Barry37
Level 1 Expert
sharky633
sharky633
Are you a Craig Electronics Computer and Internet Expert? Answer questions, earn points and help others
