Question about Gateway Computers & Internet
What does the 4-pin connector power on a gateway gt5668e
  • 47 Answers
It supplies the power needed for VGA . if you don't connect it you lose the display.
Posted on Feb 11, 2014
I need a new graphics card - are they still available for this make & model and what is the name & type of card I need to buy?
https://support.gateway.com/s/PC/R/5022/5022sp3.shtml
gateway support shows you have a pci-e x16 slot for a video card
you can choose a non-powered pci-e video card for your system, which might be better for you if you still have the stock power supply in your tower.
or, you can choose a powered pci-e card if your power supply is powerful enough to run your system AND a pci-e video card too. a powered card will have a spot for a 6 pin (or 2x 6 pin or sometimes a 6 pin and/or an 8 pin) power connector that comes from your power supply to the video card ... you may have to replace your power supply to use a powered card, or get a pci-e power adapter (not the preferred method, but sometimes works).
here is an example of a non powered pci-e card
and here is an example of a powered pci-e card, see that black connector near the back of the card, that's the power connection
and the 6 pin connector from the power supply looks like this (and power supply adapter shown also)
does this help?
Aug 27, 2013 | Gateway 835GM (835GH) PC Desktop
Need a power supply model number for Gateway model GM4019E
Gateway GM4019E Cool Power Gamer Pro 875W 20+4-pin ATX Power Supply w/SATA PCIe & Dual 12V Rails (Titanium)
The Power Supply features one 20+4-pin ATX power connector, six SATA connectors, six large Molex... More Details
SKU: 50563-425048
Jan 30, 2013 | Computers & Internet
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
Need diagram for connection on motherboard 4006272r
Gateway 4006272R motherboard;
Foxconn (Bengal) RS780 motherboard.
[ In otherwords the motherboard chipset is an AMD RS780 series,
http://en.wikipedia.org/wiki/AMD_700_chipset_series#780G.2F780V
http://en.wikipedia.org/wiki/Comparison_of_AMD_graphics_processing_units#Radeon_R600_series
Scroll down to the bold black subheading - IGP (HD 3xxx, HD 4xxx ]
This motherboard,
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
In the list click on -> Product Views
Now click on -> S - Front Panel Connector
Motherboard installed in the computer case, the Front panel header is at the Bottom/Right corner.
It has -> F_PANEL <- silkscreened in white underneath it.
Two rows of pins.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side, coming across to the Right;
Top row;
Pins 2, 4, 6, 8, No pin, 12, and 14.
Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
Pins 11, 12, 13, and 14 are NOT USED.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
These pins are in the Orange blocks.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
These pins are in the Blue blocks.
C) Pin 9 is N/C. Not Connected. Reserved for factory use.
Black block.
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
These pins are in the Green block.
E) Pins 6 and 8 are for the Power On switch.
These pins are in the Red block.
F) There is NO Pin 10.
Black block.
Again, Pins 11, 12, 13, and 14 are Not Used.
B- CPU Power Connector is at the upper left corner of the motherboard. This power cable is power for the Processor.
MUST be plugged in.
A general example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
Note the Lock on the side of the power cable's connector, and matching Lock Tab on the motherboard connector.
F- Main Power Connector also has a Lock, and Lock Tab.
General example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
D - CPU Fan Connector is above the processor socket, and near the top outside edge of the motherboard. ONLY plugs in one way.
Regards,
joecoolvette
Aug 10, 2012 | Gateway Computers & Internet
Gateway dx4822-01 power supply
Gateway DX4822 Desktop PC,
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2291
Just a regular Ol' ATX power supply. Rated at a maximum wattage rating of 300 to 525 Watts. Two different power supply options offered.
Power Supply case size is;
6 Inches Wide, by 5-1/2 Inches Long, by 3-1/4 Inches Tall. (152.4mm Wide, by 139.7mm Long, by 82.55mm Tall )
Has the following power cables;
A) 1 -> 24-pin ATX main power cable,
[ NOTE* Color of connector on power cable, OR motherboard, does NOT matter.
Proper connector, proper power cable, DOES matter; connector color does not matter ]
B) 1 -> 4-pin ATX +12 Volt power cable,
{ Power to the motherboard, and all components connected to it }
C) 2 or more -> SATA power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
{ Power to a SATA harddrive, and/or power to SATA optical drive/s.
(CD/DVD drive) Or power for an upgrade in the future, for a SATA optical drive }
D) 3 or more -> Standard 4-pin Peripheral power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
{ Power for an IDE (PATA) harddrive, or drives. Also power for IDE (PATA) optical drive/s. Plus power in some instances, for computer case fans }
E) Two or more Small 4-pin Peripheral power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
{ Listed as a Floppy Drive power cable. Back in the day when the article was written, such was true.
It can still be used for a Floppy Drive, but is more used now as a power cable for a;
1) Card Reader.
2) Computer case fans (IF needed }
It's name is Small 4-pin Peripheral power cable. It is smaller than it's larger cousin, the Standard 4-pin Peripheral power cable.
Also has smaller gauge of wiring. This means it cannot carry the same amperage, as the standard 4-pin Peripheral power cable.
I would recommend this,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=899124&CatId=1483
A) 1 -> 20 + 4-pin ATX main power cable.
Can be used as a 20-pin ATX main power cable, or a 24-pin ATX main power cable, which is what you need.
B) 1 -> 4-pin ATX +12 Volt power cable.
C) 6 -> SATA power cables
D) 4 -> Standard 4-pin Peripheral power cables
E) 1 -> Small 4-pin Peripheral power cables
F) 1 -> 6-pin PCI Express power cable
G) 1 -> 6/8-pin PCI Express power cable.
In the future, (Or now if you have one), you can upgrade to a better graphics card, that needs an additional power cable, IF you wish.
The 6-pin PCI Express power cable.
You also have a 6-pin or 8-pin PCI Express power cable.
(6/8-pin PCI Express power cable)
All the pins can be used together, and make an 8-pin PCI Express power cable, for a very powerful graphics card that requires this cable.
Just added bonuses with today's modern power supply's.
Regards,
joecoolvette
Jul 04, 2012 | Gateway DX4822-01 Power Supply 575 Watt...
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
Gateway Intel 850 Socket 478 ATX Motherboard Power Supply
Please use the following as a reference: ATX12V Power Supply Design Guide, http://www.formfactors.org/developer/specs/ATX12V_PSDG_2_2_public_br2.pdf
Sections 4.5.2 and 4.5.3 (Page 38) list the signal and wire colors for the +12V2DC (2x2 pin) and Peripheral (Molex) Connectors. Figure 11 (page 36) shows diagrams of the connectors and pin-outs for reference.
Most likely, you are looking for the 2x2 pin connector; pins 1&2 are common (black wire), pins 3&4 are +12V2DC (yellow wire w/black stripe)
Dec 14, 2008 | Gateway (4000782) Motherboard
ATX Power Supply Question
Most new power supplies have a twenty pin Molex connector and a 4 pin Molex connector. If you look closely at the connectors you will see that they go together a certain way. It can be very hard to tell. Take a close look at the shapes of each terminal. Match them up exactly.
Nov 28, 2008 | Gateway Computers & Internet
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
