Question about Kodak Carousel 4400 Slide Projector
How to adjust cycle solenoid fro Kodak autofocus 850 projector
    President:
  • Kodak Master
  • 412 Answers
The cycle solenoid adjust is a pretty straight-forward adjustment. Check out the attached image.
how to adjust cycle solenoid fro Kodak autofocus 8 - 23444947-3mxfg03gdrcqpaxov0f13tzp-1-0.jpg
Posted on Jan 13, 2015
Kodak 750h won't reverse
If the projector cycles in FORWARD and holds SELECT when the SELECT button is pushed and held, then the projector simply needs a cycle solenoid adjustment. This can be accomplished by following the adjustment procedure in the Kodak Service Manual posted at: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-locale=en_US&pq-path=6499
Good Luck !! Jim
Apr 17, 2014 | Kodak Office Equipment & Supplies
The select bar on the projector is not working.
The Carousel 600 Projector is at least 45 years old!! Great to hear it still turns on!!
Because the 600 has no forward or reverse buttons, forward is accomplished by "tickling" (very lightly push) the Select bar. If you can cycle it forward and no Select, then you need to adjust the cycle solenoid to find the balance between forward and select. If you have NO forward, then chances are either the cycle solenoid is WAY out of adjustment, or the LINK between the CYCLE SOLENOID PLUNGER and the CYCLE LEVER is broken. You should still be able to order the LINK from: www.micro-tools.com
Good Luck !! Jim
May 19, 2013 | Kodak Carousel 600 Slide Projector
Kodak 850 Carousel Projector tray won't advance
The Carousel 850 is 40-45 years old. The symptoms you describe indicate the timing is off. Timing is an "adjust & test"..... try a SMALL adjustment and then test it.... adjust again & test again. Repeat until you get smooth tray action. See the attached illustration:
May 16, 2013 | Kodak CAROUSEL 850 KODAK
Kodak 850 carousel advance link replacement procedure
Sure!! I'm assuming you have already purchased the LINK.....
1> Remove the bottom cover (power unplugged and lamp & optics removed)
2> Locate the adjustment plate for the cycle solenoid. Remove the 3 hex screws that secure the solenoid coil to the plate. Remove the solenoid coil.
3> Remove remainder of broken Link from the end of the solenoid plunger. Rivet the new link in its place. Insert the link into the rectangular slot on the cycle lever.
4> Reassemble the solenoid coil onto the plunger and replace the 3 screws in their correct holes. Tighten the 2 screws that go through the rubber grommets. Leave the 3rd screw snug but not tightened yet.
5> Plug the projector in....
>DANGER: SHOCK HAZARD!!, exposed electrical contacts<
Turn the projector on and cycle the projector in "Forward" mode. Adjust the Solenoid mounting plate up or down to get a quality forward cycle without excessive buzzing. Check reverse the same way. Adjustment will have to be a compromise between forward and reverse cycling. Tighten the adjustment screw.
Refer to the attached diagrams for additional detail:
13091426-jyy1mzyyt3mznhqcebmddagh-3-1.jpg Good Luck !!! jim
Jun 06, 2012 | Kodak Office Equipment & Supplies
Kodak Slide Projector not moving carousel
Chances are that the LINK that connects the cycle solenoid plunger to the cycle lever is broken. This happens a lot on this generation of projectors. You can purchase the parts from: www.micro-tools.com, as Kodak no longer stocks parts. micro-tools should be able to provide installation instructions! Good Luck!
Feb 21, 2012 | Kodak Office Equipment & Supplies
I have a Kodak 650H Carousel projector that I am repairing for a customer. This is my first Kodak projector repair, and so far I have succeeded in replacing the solenoid link (what a pain). After...
You are almost there!! the toughest part is done (the link!!). You need to loosen the screw on the solenoid plate that DOES NOT go through the black rubber grommets slightly and then put a flat-blade screwdriver in the adjustment slot & twist a little bit. Tighten, turn the projector right-side up, turn on (FAN position!) & try a couple of cycles. Repeat as necessary. It's a trial & error adjustment. I hope this helps !! Good luck !!
Jul 07, 2011 | Kodak Office Equipment & Supplies
Kodak 760H will not advance slides
If the projector neither advances or reverses, then most likely the problem is caused by the cycle solenoid "link". The "link" connects the cycle solenoid to the slide change mechanism. The "link" is plastic, and over time gets brittle & cracks, rendering the slide change mechanism non-functional.
If the projector cycles in Reverse and functions in Select, then chances are the projector just needs an adjustment of the cycle solenoid.
Either problem can be addressed by a factory-trained service dealer.
Jan 18, 2010 | Kodak Office Equipment & Supplies
My slide projector carousel does not advance
Does the projector run in reverse?? If so, then what you are facing is a timing adjustment.
If it does not cycle in either direction, then there is a high probability that the solenoid "link" is broken. The "link" connects the cycle solenoid plunger to the slide change mechanism.
The good news: There are still parts available (www.micro-tools.com). The less-than-good-news: both fixes are difficult and best handled by a factory-trained repair dealer.
Nov 20, 2009 | Kodak Office Equipment & Supplies
Cannot reverse the carousel
The problem you are describing is most likely a cycle solenoid adjustment. There are several versions of Kodak Slide Projectors, and each version has a different method to adjust the cycle solenoid so you get a complete forward and reverse cycle. It is not an adjustment (in any version) you can make without some disassembly, therefore I recommend you take the projector to a factory-trained repair dealer, and let them make the adjustment. Good Luck!
Aug 22, 2009 | Kodak Office Equipment & Supplies
Bought a 760H to show some old sllides, but the tray does not advance. Is this something that can be fixed? Everything else works fine.
In a word - yes. Most anything on a Kodak Slide Projector can be fixed.
If your Carousel 760H will cycle in Reverse but not Forward, then it's an adjustment of the cycle solenoid. If the projector will not cycle slide forward ort reverse, then it is probably the cycle solenoid "Link". The "Link" connects the plunger of the cycle solenoid to the slide change mechanism. The good news: parts are available (www.micro-tools.com). You will need to seek out a factory-trained dealer to make either one of these repairs for you.
Aug 15, 2009 | Kodak Office Equipment & Supplies
Kodak Carousel 4400 Slide Projector Logo
141 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
