GEHC/CTT Linux 6.2.11 root password
GE X-ray workstation computer ....HP 6400 Workstation
  • Nejib Jedidi
    Nejib Jedidi Dec 05, 2016
  • 561 Answers
Wow! I'd suggest re-install.
Posted on Feb 12, 2014
  • 293 Answers
SOURCE: installation
you may need a third party driver for this.
Posted on Sep 14, 2007
  • 271 Answers
SOURCE: installing oracle 8i
That is the problem with XP...Those softwares which were workin is not supported by XP...(different platform)...or else go for the software developer and get the XP version
PLEASE VOTE ME AS FIXYA (blue boxes) for my help.........
Posted on May 28, 2008
  • 4 Answers
give ur add i want to check it out.
Posted on Sep 02, 2008
  • 90 Answers
SOURCE: HP Workstation xw6400
Check for any virus. Check disk manager for any hard disk manager. if disk is ok  replace your memory with a new one
Posted on Apr 09, 2009
  • 153 Answers
SOURCE: lost linux password
The easiest thing to do is:
Boot into rescue mode, use a fedora cd or dvd if neccessary to accomplish this.
cd to where your filesystem is mounted, which I think is /mnt/sysconfig
cd /mnt/sysconfig
Then type:
vi etc/shadow
This brings up a file with lots of lines with usernames as the first field in each line. Root should be on the first line. Each line uses a colon (:) as a delimiter between fields. The second field in the root line is the md5 hash of the root password. Get your cursor to it and remove it by pressing x until it is gone. The second field is then empty with 2 colons in a row after root.
Press esc, then colon, then wq and you will save it and quit. Now reboot and login as root, with no password.
Change the root password immediately with the command:
passwd root
and for future incidents, install sudo, set yourself up as a user of sudo with full privileges and when it happens again, just type
sudo passwd root
and set the root password to whatever you want.
Posted on Apr 20, 2009
My hp xw4600 workstation beeps red light blinks on off
read the code the blink codes tell the story,
red lights where,
1: power button LED green? (can be red) and beeps
2: Monitor LED lamps?
3: caps lock on keyboard blink.
4: is the COIN cell dead? 2.9v to 3.3vdc good, lower volts is bad , as most are this old !!!
the service manual covers all this! ever heard of HP and there REAL pages,,???
why not read that?
(do the fans all spin, if not PSU is dead.
PSU fan is first. does it.
CPU fan , huge fan on heatsink must spin.
the stock GPU card has no fan (ASUSc card but mine does. at ATI fan right on the express 16 card.
does the DVD drive eject work.
if any of the above fail the PSU is bad.
but we strip off all loads from the MOBO
to prove its not some part shorted. first.
the front LED on this PC has flash codes
mine flashes in sleep mode, or w10 power off.
w10 never turns power fully off, it uses hibernate to turn off, (unless i cure that, ask)
the factory manual starting on page 111 cover this.
i own this beast so .....
code 2 red is overheated.clean the PC and all fans.
code 3 red, processor errors CPU.
code 4 PSU dead or shorts on load buses of same.
we call them power rails, we bench test the PSU
or read page 111 , how.
code 5 = GPU RAM failure, this PC has on board, GPU chip only X16 slot card, replace it. or the DDR2 rams are bad.
code 6 = GPU card bad.
code 7= BIOS ROM, put in a new coin cell first.!!!
Code 8= BIOS, always do nee COIN cell first.
code 9 = cant boot hdd, hdd bad or software gone, or corrputed, PC can now boot to a linux live CD or USB stick proving now PC is ok,
only hdd and OS suspected now. code 9
page 111 is here, 24/7 !
Sep 01, 2017 | HP Computers & Internet
Try Below step.
To disable the power-on or setup password features, or clear the power-on or setup passwords, do the following:
  1. Shut down the operating system and then turn off the workstation and any external devices. Disconnect the power cord of the workstation and any external devices from the power outlets.
  2. Disconnect the keyboard, monitor, and any other external devices that are connected to the workstation.
  3. Remove the hood cover.
  4. Locate the header and jumper. The password jumper is green.
  5. Remove the jumper from pins 1 and 2. Place the jumper on either pin 1 or 2, but not both, so it does not get lost.
  6. Replace the hood cover.
  7. Reconnect the external equipment.
  8. Plug in the workstation and turn on the power. Allow the operating system to start. This clears the current passwords and disables the password features.
  9. To establish new passwords, repeat steps 1 through 4, replace the password jumper on pins 1 and 2, then repeat steps 6 through 8. Establish the new passwords in Computer Setup.
May 10, 2014 | HP xw6200 PC Desktop
Desktop wont show on start up of this used hp 8710 i bought and i dont know admin password
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :-
Oct 26, 2012 | HP 8710w Mobile Workstation - Intel...
Have a hp xw9300 , trying to load software from ge ( anaconda) and getting kickstart errors and ioerror errno 2 ) no such file or directory: '/tmp/part-include. system was setup just exactly like
are you running Linux or a windows operating system? if running windows you will need a software named Linux Reader, a free Windows application that emulates the look and feel of the Windows XP Explorer and allows read-only access to ext2 and ext3-formatted drives
Oct 15, 2012 | HP xw9300 Workstation PC Desktop
I have a HP workstation xw4100 2.8GHz. i cant find a network adaptor, under device manager it says ethernet controller and says no driver found
You can download the driver from the link below. The driver is for windows XP operating system. Incase you are using Linux or other operating system ,select the operating system first before downloading.
Link to Download
Thanks for using Fixya
Oct 13, 2010 | HP Workstation Xw4100 PC Desktop
How remove BIOS password on my HPxw8200 Please
>Open the CPU
>take out the jumper (looks like this)
>turn computer ON without that jumper
>shutdown computer
>put it back in
>turn computer back ON
>comments suggestions ratings and violent reactions will greatly be appreciated thank you...
Sep 26, 2010 | HP xw8200 PC Desktop
Can i install my hp deskjet f2200 on linux?
Hp Linux driver for the 22xx series can be had at this link...
Additional info and drivers can be had on most printers under Linux at...
May 16, 2009 | HP xw4600 Workstation Linux Installer...
Hi, I have a Cyclades TS-1000 and I do not have the root password. Is there a way to reset it to the factory defaults.
Well, you don't even have to go to that extreme to recover your root password. Connect to the console port of the TS to your laptop or workstation. Type reboot (as root) and hit Enter. As you watch the boot sequence, pay close attention as you'll need to input characters. Specifically, when you see "Linux PPC Load", press the space bar a couple of times and type out the word single and hit Enter. If you did it in time, you should see a hash (#) prompt without requesting a password. From here, type the command passwd and hit Enter. Choose your password and confirm it. Don't forget to perform a signal_ras hup followed by saveconf to ensure your changes are activated immediately and are saved to flash memory (non-volatile state). From here type reboot again and you should be back in business.
Dec 05, 2008 | Cyclades TS 1000 Terminal Server
Computers & Internet Logo
684 people viewed this question
David Payne
David Payne
