Question about Tascam Dp-02cf Digital 8-track Recorder
My dpo2will not bur a cd, it keeps reading noaudio cd in tray but there is
Trays locked
Look for a small pin hole on the front of the CD tray area. Take a straightened paper clip or a pin, push it into the hole until you feel resistance. Then press the eject button at the same time as you press firmly on the pin or paper clip. The tray should open. May take a few tries as you have to get the timing right. Good luck with it and I hope this helps.
Dec 23, 2013 | Philips Audio Players & Recorders
Noaudio device found is coming with d945gcl m'board in win7 os
You will need to re-install the audio drivers for your motherboard. Read my tip on how do do so here: http://www.fixya.com/support/r6775481-download_intel_motherboard_drivers
Apr 03, 2011 | Intel D945GCL Motherboard
Cannot Read Disc?
I would say get a cleaning CD with the bristles on the Cd to clean the lens of the Wii. When you get it all it does is spin in the CD tray and clean the lens inside the CD tray. That should fix your problem the lens is probably dirty. If it doesn't leave a comment and ill try to help again.
Jan 09, 2010 | Nintendo Wii Console
System will not read disk. Keep getting open tray, Have use the dust spray still not working.
An 'Open Tray' error with an XBox 360 is typically a sign that the CD/DVD drive itself is faulty. This will require it to be replaced, which is not as easy as just swapping them out.
The new drive must be of the same make and model of the old drive. If I recall, there are Samsung and Toshiba drives in 360's. Once you have the exact replacement drive, the CD Drive's firmware must be flashed on a PC in order to be compatible and detected by your XBox.
Dec 02, 2009 | Microsoft Xbox 360 Console
MY CD TRAY KEEPS MOVING IN AND OUT WITHOUT MY PROMPTING.IT DOES NOT READ ANY CD I WISH TO VIEW.I HAVE TRIED SCANING FOR VIRUSES BUT IT DOES NOT HELP. THE TRAY MULFUNCTIONS RIGHT FROM SWITCHING ON THE...
The drive is malfunctioning -- when it cannot read the CD-disk, it opens the tray. For less than $40, you can buy a brand-new CD/DVD-writer, and responsibly recycle the malfunctioning device.
Nov 13, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
May 19, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Cd tray on my 360 wont stay shut
either you will need it repaired or u can do it the cheap way and after the disc tray is shut put some tape over it and see if it will read it still. If not it will need to be repaired. It will only cost about $35 or free if you are still under warranty.
Feb 14, 2008 | Microsoft Xbox 360 Console
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
Won´t read any Disc
I have the same problem since the early beginning after purchase. I'm very upset with NAD for the zero-value technical service in Italy. After 2 months they gave me back my C541 with new defects (the tray now doesn't work properly). They have tried - they said - different optics without fixing the problem. Does anybody know if a compatible optic / tray exists?
Thank you
Marcello
mcl.vlb@tiscali.it
Tascam Dp-02cf Digital 8-track Recorder Logo
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
