Question about LG Flatron L1951S 19" LCD Flat Panel Monitor
Disassemble lg monitor W2043TE - LG Flatron L1951S 19" LCD Flat Panel Monitor
Disassembly lg e2250v
To disassemble your TV you need a screw driver to unscrew the cover and other parts that you need to take off..
For proper instruction go and download manual on www.retrevo.com
Jan 16, 2012 | LG E2250V-PN 21"LCD Monitor
How can disassembly LG monitor Flatron L1717S?
MONITOR CAN BE DISAMBLY BY USING SPECIAL TYPE OF SCREW DRIVERS
Jan 12, 2011 | LG L1717S-BN 17" LCD Monitor
How do i dismantle L192WS LG monitor ? please help
We have a full disassembly and repair guide for this model monitor posted on our site at:
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
I hope this helps, if so please rate our solution.
BuddyMc
Jan 01, 2011 | LG L196WTQ-BF 19" Monitor
I have lg lcd monitor.the power indication is turn on red..there is no disply..what should i do?
royrocky1989, The first thing you should do is write down on paper, the brand of lcd monitor, model number, date of manufacture" . Second thing to do is visit YOUTUBE and watch 5 to 15 useful video clips of owners/technicians who do their own troubleshooting and repair to their lcd monitor's switch mode power supply/inverter ballast circuits. Then come back to fixya and tell us if you feel confident enough to undertake the restoration of your unit. Search terms at YOUTUBE are "lcd monitor disassembly" and "lcd monitor repair" Good luck with the repair 12fixlouie
Oct 29, 2010 | LG Computers & Internet
Hi I have problem with my monitor LG it is black
s mosaad, if you prove pc is ok, then you should first watch some of the longer and more useful video clips at YOUTUBE!!! Your search is "lcd monitor disassembly" and "lcd monitor repair" .. How old is unit? Did you learn to do "flashlight test" to possibly evaluate unit's "switch-mode-power-supply" status?? Do you know how to use soldering iron? Are you certain the pc or software is not causing the problem?? 12fixlouie
Sep 24, 2010 | LG W2053TQ Monitor
How to remove the back panel on lg 1718s-bn
scaillos, Try YOUTUBE for video clips of "lcd monitor disassembly" and or "lcd monitor repair". Don't use any sharp edged cutting tools like kitchen knives or you will incur additional monitor repair costs that will be paid to local hospital "ER" !!! Might find interesting stuff at www.ccl-la.com/badcaps.htm and www.badcaps.net , www.lcdparts.net , www.ccfldirect.com Start at lower edge of monitor and look for small slot to inset something to pry with. Good luck. Be careful. 12fixlouie
Mar 28, 2010 | LG Flatron L1718S LCD Monitor
Our LG Plasma is about 5 years old and now it has started strobe flashes really quickly and the colour and picture goes destorted its getting more regular can u please help???
georgiaheasm, I you prove pc not problem, then you or qualified electronics technician will need to troubleshoot units internat power supply for common problems associated with LCD plasma and CCFL back-lit monitors. Look for some DIY videos on YOUTUBE that deal with lcd repair, plasma lcd repair, lcd monitor disassembly, lcd tv disassembly. Look at them even though you will not DIY repair your unit. Good luck with repair. 12fixlouie
Mar 19, 2010 | LG Computers & Internet
Disassemble anlg lcd 19''
The following link will show you the 'pdf file' for the assembly of your monitor.
You should be able to reverse this procedure in order to disassemble it in order to put it back into the box.
http://us.lge.com/download/product/file/1000000449/L1951S-BN.PDF
Go to page 4 and look for "Removing the stand base" to see how to disassemble. Binary Bob
Nov 29, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
How to disassemble a LG LCD monitor
Hi...there,
There are 2 ways to opened it... 1: from the back, removed 4 screws and get a good grip on both open edges and pulled. Need to give it some force to it. 2: The other, it from the front bezel. First laid it face up and placed a piece of cloth or micro-fiber cloth over the screen to prevent smudges or damaged from the 4 knuckles . Then use both 8 fingers to grasp onto to edges of a bezel and lift it up with some force to it. Do the same on other side Good luck!
Nov 06, 2008 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1951S 19" LCD Flat Panel Monitor Logo
50 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
