Question about GE Microwave Ovens
Need to replace RY2 on control board for GE PVM1790R1
Does anyone know where I can get these or The Manufacturers Part number for this Relay. Seems like a common problem with these Microwaves. Rather not order the whole control board!
5 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: PCB repair
Yes we can.
Feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
Before you power it back up after the repair, you should double-check the wiring of the switches against the "mini-manual".
It's located behind the grille or below the circuit board.
If you don't find yours, you can download it here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 08, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: Have MMV4205BAW18 with a main control relay
W10181450 is the part number of the whole circuit board, not just the relay.
That board runs $130.74 and you can order it from the Pros here.
The attached photo shows where the two cook relays (RY01 high power and RY02 low power) are on your circuit board.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can contact us via our site with the numbers on your relay, and we may have one or more available.
Whirlpool / Maytag does not make relays available, one has to get them from third-party suppliers by the relay manufacturer's number.
Or we can repair your control panel assembly for you for $39.95. Details are here.
Let us know if we can help further.
Posted on Jan 02, 2011
ricsindy
  • 53 Answers
SOURCE: Control Board wiring
How old is the unit. normally there is a tech mini manual of one or more pages inside the control panel or you might look in the upper vent area. this wiring / schematic would list the wiring positions of the relays you mentioned.
Posted on Mar 29, 2012
kevin_getz
  • 1031 Answers
SOURCE: no power to my microwave GE JVM1750DPBB
You're looking $130.49 for the board.
Posted on May 04, 2012
What does E 13 mean on a Kenmore microwave oven?
Kenmore microwaves are made by several manufacturers. The E-13 error may indicate a humidity sensor issue or a problem with the control board. It could also be an issue with the wiring between the sensor and the control board. Try unplugging (or turning off the circuit breaker to) the microwave for at least 30 seconds. This may reset the error. If the problem recurs, the sensor or the control board may need to be replaced. Microwaves can store an enormous amount of power in the capacitor and may be dangerous. Repairs are best done by a professional.
I hope this helps.
(The E-13 code diagnostics above apply to Samsung-made microwaves.)
Mar 12, 2016 | Kenmore Microwave Ovens
Kenmore over--range microwave - the fuses are good. But it's dead...
Check the door switches, this is a common problem in many brands of microwave ovens.
Jun 14, 2012 | Kenmore Microwave Ovens
Microwave oven does not heat up
This seems to be a common problem with microwaves, the problem is likely the magnetron "heats food" and the heart of the system. If the oven is five years or more I would suggest a new one.
Mar 05, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave goes but dosnt cook all seems to be in working order
Most likely, the magnetron (the gadget that produces the microwaves) has burned out. In this case, replace the microwave.
However, it may have a burned out thermal fuse. If you are skilled in this area, you can take the appliance apart, and replace the fuse. However, DO NOT TRY THIS unless you know how to put the radiation seals back together, and, have a leakage meter to be sure nothing is coming out. Microwaves are dangerous.
Best solution: get a new appliance.
Microwaves are only good for three to fie years.
Oct 20, 2011 | Microwave Ovens
The microwave has power and seems to respond to keypad, but does not heat. I tried many auto and manuel settings. It also makes sort of ticking or scratching sound when turned on.
HI:
The most common reason for no heating is the High voltage diode fails causing the no heating problem, if you are hearing so sort to ticking sound the diode may of come loose from the high voltage capacitor inside the unit and is sparking. I would have the unit checked for loose connections inside the unit, I don't unless you have experience working on microwaves, recommened you try repairing it yourself, as there is alot of voltage on the capacitor circuit of microwaves, at least 10,000 volts at its terminals, and need to be discharged before any service is atempted.
May 15, 2011 | Kenmore Microwave Ovens
Have MMV4205BAW18 with a main control relay problem. I am told that I can replace this relay myself provided I can find the part. The part number is w10181450. This is a manufacturers part number. Can...
Dec 31, 2010 | Maytag MMV4205 Microwave Oven
I can't open the door. I press the button but nothing happens. What can I do? Is there a spare available?
the door latch seems to be faulty or broken yes you can get spare parts just supply model number and your local supplier will get it for you be aware when dealing with microwaves there are very high voltages involved be very careful hope this helps you let me know how you went
Oct 06, 2010 | Microwave Ovens
Morphy Richards AC925EYG Convection has stopped heating items
Same thing has happened to me. My brother in law seems to think it cant be fixed. Bought it Dec 2008 so no warranty.
Were you able to get anythihng out of morphy richards?
Jan 09, 2010 | Zanussi ZMB30CST Convection Microwave Oven
Loud vibrating noise in Microwave
i would not operate the microwave any longer ....bring in for service ....microwaves can send out very dagerous radiation....
Jul 26, 2009 | Microwave Ovens
Microwave stopped working all of a sudden. NO power supply. I tried placing at different places.But no use..I ddidn't see any problem before it stopped working..
the most common problem with microwaves is the door protection circuit blows a fuse. the door catches operate switch that if they do not operate correctly( normally after the door has been slammed). the good part is they place the fuse inside the casing. so remove the power open the casing( several screws) and check all the fuses in side.
Feb 19, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
16 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
