Question about Panasonic Televison & Video
CT-2013SA TV/Video I lost my remote to this tv. Is there any way I can switch it to the video without the remote? If not will a universal remote work with this tv?
  • 44 Answers
SOURCE: Sanyo MTS TV
Hello
Most universal remotes should have a TV/Video button. Look carefully on the remote. Or get another brand remote.
Also depending on your Sanyo model there may be a TV/Video switch on the front of the set. Look for a possible small cover along the bottom.
Posted on Feb 29, 2008
SOURCE: sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Posted on Mar 01, 2008
SOURCE: Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Posted on May 25, 2008
SOURCE: programming rca universal remote for my toshiba tv
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
Posted on Sep 12, 2008
SOURCE: My TV has stopped responding to the remote control (and the universal remote) and the front panel buttons don't work
waynejman, I have the same exact problem, can you tell me what your outcome was?
Posted on Nov 16, 2008
I have a panosoinic tv model CT-2013SA and my son typed in a parental code and forgot it
Hello
There is a way to unlock Panasonic TVs. It will work on most of the Panasonic sets. Just try it.
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, that is, switch on the set by its front panel power switch, and put it off by remote hanset, [standby position], then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
OK.
Feb 12, 2011 | Panasonic CT-20G6 20" TV
Can you switch from tv to video input on sanyo ds31520 tv without a remote
no you require the remote or a universal remote or sometimes a cable remote that has been programmed to work the volume on the tv set will have an input button .
Sep 29, 2009 | Sanyo DS31520 31" TV
Lost remote control for an emerson tv. how do you change input from channel to video without the remote?
I just purchased one of these televisions and it didn't come with a remote. However, a Philips Universal Remote (SRU2103/27)
with a code 0520 works fine. I haven't explored all the codes but I can easily change from tv stations to Video 1 and Video 2 merely by pressing the "Input" button on the remote.
Jun 17, 2009 | Emerson EWF2006 TV
Lost remote
with a code 0520 works fine. I haven't explored all the codes but I can easily change from tv stations to Video 1 and Video 2 merely by pressing the "Input" button on the remote. Another reply mentioned using a duraband model instead of Emerson and it worked for him.
Apr 20, 2009 | Emerson EWF2006 TV
Lost the controller for Pioneer rear projection TV
Try pressing the "Input" button the front of the set. That should allow you to change between the different inputs. The return button usually returns you to the previous channel you were watching - don't think it works for the input though. Also, depending on the model of the set you have, try downloading the PDF user or owners manual - it will tell you how to use the remote.
Jul 25, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Akai CT-2868AT
I had the same problem with a broken remote for the Akai CT-2868AT which meant I could not access the AV channel. I bought the one-for-all (model URC-7711) universal remote which worked with this model TV.
May 12, 2008 | Televison & Video
Sanyo MTS TV
Hello
Feb 26, 2008 | Televison & Video
Durabrand Tv.
If the TV has a tv/video button on the front
panel you can switch to video and just
operate the DVD with the DVD remote
If there is no TV/VIDEO switch then you
will need a universal remote with TV/VIDEO
menu,PIP etcIf you dont have a remote for
the dvd player the solution is basically the
same a universal remote howerver you can
operate the dvd player from the front panel
Nov 20, 2007 | Durabrand DWT1905 TV
Help with getting to video
TRY THE SAMSUNG CODES for any universal remote
Oct 15, 2007 | ESA EF402E 20" TV
Televison & Video Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
