Question about Kitchen Ranges
Rcd tripping problems
How can a neautral fault on my economy 7 circuits be tripping the RCCB on the main consumer unit when the feed from the econ 7 immersion heater is eith from that or the day time consumer unit isolated by a double ple switch which throws both neautral and earth from one circuit or the other? I have disconected the economy 7 immersion heater neutral and the day time consumer unit RCCb no longer trips. How can it be connected to the day time consumer unit at any time when the double pole change over switch makes either one or the other?
3 Suggested Answers
  • 49 Answers
SOURCE: suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Posted on Feb 19, 2008
barkencoa
  • 3463 Answers
SOURCE: Cooker keeps tripping the electricity supply.
If the main oven is electric, disconnect the heater element and try, if no trip operqates. then replace element.
Posted on Dec 15, 2008
My VAX dual power when i turn it on..the circuit breaker tripping off...pls help me
A breaker trips if there is a fault. There are two sorts of breaker - the RCD or the Micro Circuit Breaker.
When the RCD trips it suggests a fault that is allowing current to leak to ground.
When an MCB trips it indicates the appliance is trying to consume too much current.
Either way the only way to find the fault is by dismantling the appliance and checking the circuitry with a multimeter.
Apr 06, 2018 | Electrical Supplies
I use my soup maker at least twice a week today it just kept tripping the electric. My husband. Hanged the fuse but still tripping and won’t work.
If the main RCD tripped the appliance has a fault causing the current to leak to ground. If the MCB tripped the appliance is consuming too much current or has a short circuit.
Only dismantling for inspection and testing will reveal the fault.
Mar 04, 2018 | Cars & Trucks
As soon as i plug it in the circuit breaker trips.
You have a short. It is either short to ground or short circuiting. Check the cord very carefully for breaks. Make sure the ground plug is in tacked. Also try a different outlet to make sure the problem is the tool.
Mar 13, 2016 | Dewalt Dw303m Reciprocating Saws
My house fuse box is fitted with a master RCD. A feed off a lounge socket goes threw the wall and feeds an external weather proof RCD box which when switched supplies my garden lights. If a garden light...
Appears the main box RCD is just as fast as the secondary RCD and it sensed the same fault that triggered the outside unit and it didn't wait around to see if that outside unit did the job.
Sep 07, 2013 | Kitchen Ranges
Neff double oven trips rcd when either oven is turned on
your heater elerment has gone in the main oven i had the same problem if you need help takeing it out and see if its the problem get back to me ok
Nov 03, 2012 | Neff U1421 Double circotherm Electric Oven
My kettle keeps blowing the circuit
If the fuse in the mains plug or MCB at the consumer unit / fuse box keeps tripping then there probably is a fault in the kettle element or switch. If the RCD is tripping (the safety device with the test button on it) then there is an electrical leak either due to a crack in the element or water has got into the wiring, switch or power cord of the kettle.
Allow the kettle to dry out in a warm place for a day. Also check it at another power outlet to eliminate any problem with the outlet you are using.
May 28, 2011 | Dualit 72300 Stainless Steel Cordless...
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
Suk92mfx5 main oven problem?
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Nov 22, 2007 | Belling CookCenter 151 Dual Fuel (Electric...
Hot point washing machine WMA 32
It's unusual for a household RCD to go out on excess current from an appliance - the fuse in the plug top and circuit fuse/MCB in the consumer unit should provide closer protection. This leaves you with an earth fault. Earth faults aren't usually related to motor load. Watch carefully what phase of the cycle the trip happens. Does it correlate with the start of water heating? A very frequent cause of low current earth faults is water ingress into the heating element. If you can trip the RCD reliably on every cycle, running the same cycle with the element disconnected would confirm whether or not this is the cause. A.
Feb 28, 2007 | Hotpoint WMA32 Front Load Washer
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
