Question about Canon IR 1730 Copier NEW
Clear print queue on canon IR 1730 - Canon IR 1730 Copier NEW
4 Suggested Answers
SOURCE: IR 1023 iF goed on - doen not print
re-installed the driver after deleting as administrator - power user does not seem to allow certian vista installations.deletions - geez
Posted on Jan 27, 2009
myjosh007
  • 530 Answers
SOURCE: I have a canon Pixma MP170 and I cannot clear the
hi im josh in cebu phils. friend try to go printer settings then click cancel all documents printing then reboot your pc.if still occurs try to reinstall the driver software.thats all for now good luck friend.
Posted on Mar 06, 2009
  • 153 Answers
SOURCE: Canon IR 3200
ok you have a hard drive error problem that is what the code refers to need to replace the hard drive, try to scout around for one out of another machine somewhere and put it in otherwise if you get a new HDD you need to reload all the machine firmware and you will need special tools for that and only canon technicians have access to that stuff,
as i am a canon tech myself
Posted on Apr 01, 2009
My canon ir 3300 machine showing continues printing but not coming any copies out
***Manually clear the print queue***
1) Open the "Services" panel. The easiest way to do this is click "Start" and type "Services.msc" (no quotes) in the search box.
2) Scroll down the list of services to find and select "Print Spooler". Click "Stop" in the left panel.
3) Open Windows Explorer ("Computer" in the Start menu). Navigate to the spooler directory (typically "C:\Windows\System32\spool\PRINTERS") .
4) Delete the files in the directory.
5) Go back to the Services panel and click "Start".
Dec 04, 2015 | Canon Office Equipment & Supplies
Ir 8070 copier. How do I correct a print suspended error?
please perform a main controller clear from service mode
May 23, 2015 | Canon IR 8070
Canon ir3170 photocopier how do operate all setting in default setting?
The iR C3170 has two printer board options. The first is the built-in Canon board and the other is the EFI (Fiery). The Canon board is configured via the touch panel via Additional Functions > System Settings > Network Settings. If the Fiery is attached (there will be a rectangular box on the back of the printer that the Cat5 connects to) it is configured via the touch panel but you access it differently. In the top right hand corner of the display will be an arrow. Press it and the next screen will show printer setup/status.
Now for both the Canon and the Fiery, AppleTalk is not enabled by default and therefore has to be if you are going to connect this way. However, if you have the Canon board, it uses the Canon Mac PS Driver v1.40 (or later) that connects via LPR. After you run the installer and then restart (a must) you will have a new option under More Printers called Canon IP (PS). Open this dialog and enter the IP address of the iR C3170 and the queue name of LP. The utility will query the device and choose the appropriate ppd.
But if you want to connect via AppleTalk you cannot use this driver. You need to use the ppd only, which will be on the PS driver cd or you can download from the web.
Now there are a couple of reasons the print job can disappear when using lpd. If the Fiery is attached, the queue name has to be set, such as print. Note that the queue has to be typed as lower case. If the queue name is not set print jobs simply vanish once they leave the Mac.
If you have the Canon board then the queue name is not a factor but there is a setting in the copier called Dept ID and if this is on, it can stop jobs from printing that don't have an appropriate ID. To print with Dept ID enabled you have to use the Canon Mac driver mentioned above. You cannot use the ppd!The driver has the facility to set a user ID (which is generally used for tracking or controlling usage - especially colour) in the driver, located under Special Features. Note that if the Mac only has one user, you can set the ID in the driver and then save the config as a preset, which saves the user having to input the ID every time they print.
Hope there is enough in here to help. Get back to me if you still have issues.
Jul 29, 2012 | Canon imageRUNNER C3170I Color Copier
Why would my Canon IP4000 Printer stop printing documents; however, it will print perfectly if I use the PRINTER PREFERENCES test printing (Windows7)?
Try going to control panel, printers, and check if it says your printer is ready to print..... also right-click on your printer and click cancel all documents.... It should clear the queue, often printers won't print because there are too many documents in queue and I guess it just freezes up.... Hope this helps :)
Jan 11, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
I have a canon Pixma MP170 and I cannot clear the print queue form the software windows - It says it is cleared but it still prints the old queue. How do I really clear the print queue. I am in Mac OSX
Mar 06, 2009 | Canon MX700 Office All-In-One InkJet...
Jan 26, 2009 | Canon imageRUNNER 1023iF Black and White...
Hanging print queue on Canon iR2200-3300
my ir2200-3300 canon printer m/c ip adders change automatically in 2-3 days pl. solution my problem?my email ID sudesh_trivedi@yahoo.co.in
Nov 20, 2008 | Office Equipment & Supplies
Unable to clear printer queue
I had a related problem. Couldn't delete a job from the queue nohow. I wound up deleting various processes (CTRL ALT DEL PROCESSES tab) and it cleared it.
Mar 01, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon IR 1730 Copier NEW Logo
43 people viewed this question
old marine
old marine
