Question about Panasonic Microwave Ovens
NN-SF460m door Broken plastic door catch
MicrowaveSvc
  • 9047 Answers
SOURCE: broken door catch, possible spring,
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Posted on Nov 27, 2008
  • 4090 Answers
SOURCE: Panasonic NN-A554/NN door catch assembly broken.
This is not an easy fix as a DIY because of the way the interal screws are positioned. The inner glass plate and frame have to be removed then using a stick mirror locate the screws and work in reverse of the mirror image. It is easier to have the skilled guys do it I assure you
Please rate our help to keep the service online
Posted on Aug 17, 2009
blueextc3221
  • 15935 Answers
SOURCE: Door Catch
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 14, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: owners manual for NN-SF460M
You can order that here.
Posted on Dec 20, 2011
First turn the micro door upside down and shake it this may dis lodge it make sure its unplugged and rotating table is removed.If you can see the piece try tweezers or needle nose pliers but again make sure it is unplugged during any handling period!
Second UN plug the device remove its cover with phillips driver or what is needed after it is removed go to the safety switch where the piece is located remove it and shake the piece it may come out if not just replace the complete safety switch
Posted on Apr 06, 2012
Door release buton does not open the door
You can disassemble the microwave oven and check out the release mechanism. You'll find several hooks that hold the door closed and a linkage mechanism to the door opening button. There may be a broken piece of plastic or maybe just a loose or missing screw that holds linkage together. In the case of a broken plastic part, you can fix it with a 2-part epoxy adhesive, but you'll need to permanently splint across the break with a piece of metal or strong plastic that you've scavenged from somewhere. Before epoxying the splint in place, rough up all plastic surfaces where you want the epoxy to stick well.
Good luck.
Mar 16, 2015 | Panasonic Microwave Ovens
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
Oct 25, 2012 | Panasonic NN-T774SF Microwave Oven
Owners manual for NN-SF460M
Dec 19, 2011 | Panasonic Microwave Ovens
We have a Panasonic Genius Prestige 1200 W microwave. The door won't open. Tried unplugging and plugging in; that worked once, but now doesn't help.
Sounds like the door catch is stuck. Perhaps this will help;
Door catches.
One of the latches has broken off and is not lifting the dother latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Jan 01, 2011 | Panasonic NN-SD797S Microwave Oven
Panasonic microwave model NN-2959: can't open door.
Hi! if the parts is to much expensive i think it is not worth it. considering the years it has serve you.
Sep 11, 2009 | Microwave Ovens
Panasonic NN-A554/NN door catch assembly broken. How do I replace this please?
Aug 17, 2009 | Microwave Ovens
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
Panosonic NN-S525BF Latch Spring Broken
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In most cases, the spring mount on the inner door panel breaks off, and while the ideal way to fix it is to replace that whole panel, the time, cost and labor are considerable.
It's usually easier and cheaper and just as effective to use epoxy and some kind of hardware to fashion a new spring mount.
Or if there is enough material to drill a hole for the spring, do that, install the spring, then add a dab of epoxy to cover the bottom loop of the spring where it goes through the hole you drilled.
Let the epoxy dry overnight before you close the door or use the oven.
Jan 24, 2009 | Panasonic NN-S254BF Microwave Oven
Broken Door Catch Now oven won't work
You can order parts online by entering your full model number (without dashes) here: http://www.pasc.panasonic.com/epartr Chances are the panels separate as shown in the photo I have attached below. Panel replacement can usually be done without removing the door from the microwave. In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges. I generally do not advise removing the hinges from the microwave. Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in. Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption nearby electronic devices. If you still have questions, please feel free to follow up. I appreciate your thoughtful ratings to my reply.
Aug 29, 2007 | Panasonic NN-V671S Convection Microwave...
Microwave Ovens Logo
15 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
