Question about Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW
The machine won't change to scan mode - Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW
  • Konica Minolta Master
  • 6,161 Answers
Have you set up scan to email or scan to pc
Posted on Jan 22, 2016
Auto transmission won`t change out of first gear
posted now 3 times this post is longest so will answer here.
not 3 times. ever.
so like all cars like this, with electrically shifted box.
you check fuses first.
then scan it.
if the TCM sees errors (scan it) then it tell you it has errors.
and will either not up shift, or will go to limphome mode.
no matter, the reason you dont know is you didnt scan it first.
the tool is cheap as $10. too.
all modern OBD2 tools work, buy one rent one, barrow one, etc.
Oct 16, 2015 | 2002 Jeep Grand Cherokee
Google com
If you are looking to reset your home page, see this... http://windows.microsoft.com/en-US/internet-explorer/change-home-page#ie=ie-11-win-7
Also, if something changed your Homepage without your permission, you may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs).
A. If your computer will boot and you can operate it ok...
Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
B. If your computer won\'t boot, or can\'t operate properly after boot...
Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.
Good luck
Jun 24, 2014 | Computers & Internet
Will not feed 11x17
You probably need to set the user settings to "long doc" mode.
1) When the machine is in the standby state,
press the NEW FILE key and Count Only key
simultaneously. During the user mode, the
LEDs of the NEW FILE key and Count Only
key illuminate and the address (U01-U10)
and data (the last digit) appear on the
counter display.
2) When changing the address, use the NEW
FILE key. Each time NEW FILE is pressed,
the address changes, cycling from U01 to
U10.
3) When changing the data, use the Count Only
key. Each time Count Only is pressed, the
data changes.
4) Pressing the Stop key exits the user mode.
Long document mode =U10; 0=normal and 1=long document mode.
Happy Scanning!
Scan-R-Store
Scan Store provides service and maintenance contracts on all Canon Fujitsu...
Apr 02, 2014 | Canon DR-9080C Path-Through Scanner
Bobbin won't wind and display shows me in bobbin wind mode and won't turn off, so i can't use the machine at all
it sounds like it's a problem with the computer motherboard and the
machine needs to be checked
Dec 04, 2012 | Sewing Machines
Washer stays in wash cycle will not spin out i changed control board no help
Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
Aug 01, 2012 | Electrolux Washing Machines
Im unable to open any downloaded exe. files and i cant access my system restore. my operating is windows xp pro
If possible, try to run your computer in safe mode. Use Malware Bytes to scan and remove virus. If it won't open as an .exe, try changing it's extension.
Oct 24, 2010 | Microsoft Windows XP Professional SP3 Full...
I cant change the play mode... when i did it automatically restarts,,,,,,, why is that?
let the norton2010antivirus scan the player or the memory card provided, some of the msi of the system might be hidden.after scanning, restore factory defaults..
May 17, 2010 | Hyun Won mobiBLU DAH-1500 MP3 Player
Possible to change default scan setting to PDF?
go into scan mode and select pdf, then go back to printer mode and select utility. user settings. store and current settings, then press store and it should use pdf as default
Jul 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Changing Mode?
There is no way to change your machine into printer mode only. machine works in dual mode copier/printer.whenever you send a print from the computer, machine automatically receive the document and print it at the same time without changing the mode.like SCAN MODE AND HARD DISK MODE. So if you are facing a problem regarding printing then please check the paper size of the machine, and also check the paper size from the "PRINTING PREFERENCES" by taking the properties of printer icon in printer and faxes menu.(where installed printers shows) right click on the bizhub 200 printer icon and clickj on "properties". now click on "printing preferences" tab and then click on "size" tab, now from here check the paper size.its A4 or not if its not A4 then please change it to A4 then again give a print command.machine will start printing.
Jun 23, 2008 | Minolta bizhub 200 All-In-One Printer
My brother mfc 210c won,t scan or copy
I just called Brothers product support and found out that these machines WILL NOT scan or copy or do anything until the ink cartridges have been replaced. So there is no other solution.
Nov 26, 2007 | Brother MFC-5840CN All-In-One InkJet...
Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW Logo
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
