Question about Pride Rally 3 Wheel Scooter
Will not go
Batteries are charged horn works but will not go
Victory pride 2002 won't work?
hi Wendy it sounds like the batteries are so low that they can't even power the horn ?
check the batteries connection and the reset fuse situated at the rear .
regards
Rob
www.gewizrepairs.co.uk
Feb 18, 2017 | Pride Health & Beauty
I have a splendor plus bike (2006). Some times not horn is not working. I was replaced from original horn to Roots horn. Battery, coil and plug also changed. but still some times horn not working.
On a wholly battery fed system the horn is generally more efficient and suffers fewer problems. Lots of older lightweight motorcycles and scooters and probably some of the more modern types either do not have a battery or do not have an effective charging system for the typically small battery with sufficient surplus capacity to provide current for accessories should the battery become discharged.
It is not unusual as these sort of bikes pass the first flush of youth to find the horn does not work very well particularly when the lights are switched on.
If there is a battery it should be fully charged and tested. The wiring connections from the generator, the connections to the battery, to the horn, to the horn push and the horn push contacts should all be thoroughly cleaned and in particular all the ground connections.
If the horn is in good condition and the generator is working efficiently the above maintenance should put things right. Many horns are adjustable and minor adjustments are likely to be needed throughout it's service life.
Oct 19, 2015 | 2006 Hero Honda Splendor+
Just brought put on charge battery gauge says no charge after a day charging but must be charge as horn works also status light flashing green
I'm sorry but what do you mean when you say the horn works? And there are other ways to test functionality. If the laptop doesn't charge it could be a dead battery in which chase it would need to be replaced. in order to test this you need to remove the internal battery and try turning it on while it is plugged into a power source.
Jul 05, 2015 | Computers & Internet
Can you help me try to figure out why my scooter will not move forward or backward? It is fully charged and the horn works.
I would get the batteries checked for power. Just because your charger shows fully charged quite often the batteries are low but enough power for lights or horn which does not take much power. i suspect bad batteries.
Apr 13, 2014 | Ctm Health & Beauty
Horn will not stop honking
try this. discconect battery neg cable, unplug horn relay under hood, lock front door with key, reconnect battery, unlock front door with key, start car, reinstall horn relay,,, good luck. this works for acura so no promisies on yours.
Feb 01, 2018 | Nissan Maxima Cars & Trucks
Indicators and horn stopped working
have you checked the switchs?..all wires are on them..& 1st check the fuse as not blown...the regultor charges the battery....so if the battery is fully charged the indicators & horn should still work..i would look for a wireing fault 1st...hope this helps
Jan 26, 2010 | 2005 Gilera Runner VX 125
Cant get it to work!! When it is on charge the horn works very well.As soon as i take it off charge and plug the battery in, the horn stops working & the motor doesnt work at all (injusa hotwheels...
Check the condition and voltage of the battery as this is most likely defective. This is not uncommon in battery powered vehicles. If this is new then return it to the retailer / dealer for replacement.
Dec 28, 2009 | Injusa Quad Mantis 12v Powered Ride On Car
Pride Rally 3 Wheel Scooter  Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
