Question about Midwest Snips Aluminum Rail Clipper Heads - MW-ALREC-IB - Elite - Residential
Do not wont to start
Battery signla go on and off whit triangel and !
Everytime start I HAVE TO START THE CAR WHIT JUMPER TO THE BATERRY AND I TURN IT OF IT DEAD AND AGAING TO START IT IA HAVE TO GIVE JUMPER AND THE DASH LIGHT SAY ABS
Some dead batteries wont hold charge after completly dieing, before jumping again clean your batter connections, if this doesnt work you will have to replace battery
Dec 08, 2013 | Televison & Video
My 2008 dodge nitro won't start, the key wont turn
see you can find the starter.tap whit small hammer ontop of the starter tree times see if it start then.if it does .change starter
May 26, 2013 | Cars & Trucks
The car wont start the lights comes on but the starter wont turn over dint have any problem whit it before it just wont do anything
check all of your posts at the battery sometimes their are two power lines stacked together and while one circuit works another may not also the ign. circuit is fused as well as haveing relays in the system check you circuits
Jul 07, 2012 | 2005 Mazda 3
04 Volvo S60 auto yellow triangle anit skid service required
what does the yellow triangle means for volvo s60?
Jun 27, 2010 | 2004 Volvo S60
After replacing battery how long will system display the red triangel alarm
This would depend on the capacity of your battery, and rate at which it is charged, but I would say about 14-15hrs.
Apr 22, 2010 | Liebert Computers & Internet
My dell inspiron 8500 wont start up whit the battery
if it is the original battery, it most likely needs replacement. Portable batteries have a expected life of 300 to 500 recharge cycles (18 to 24 mos) If a new battery does not charge, then a motherboard replacement is warranted.
Oct 01, 2009 | Dell Inspiron 8500 Notebook
1995 quest wont start
Either the switch or the nutural safety switch is bad or the wiring from the switch to the nutural switch or the to the starter solenoid is open or disconnected. Either trace wiring or test or replace switch(s).
Jun 19, 2009 | 1995 Nissan Quest
A/c blower not working
Check fuses and relays (refer to the owners manual for location). If everything checks OK, take a test light and check your wires leading to the blower motor to verify you're gatting power. If so, replace the blower motor. If no power to motor, your problem will be in your switch.
Jun 10, 2009 | 2000 Nissan Maxima
New starter getting schliiiiing noise
sounds like the starter is not engaging the flywheel if the starter make noise like a power saw and the engine is not cranking may be the starter solenoid is not working I have seen this happen whit brand new starters now before you change your starter again ask some one to turn the key for you and see if the crankshaft or any otter pulley is rotating. if noting turn then replace the starter again and ask them to tested for you at the store and see if the gear comes out like it shut. If you see the crankshaft and pulleys rotating but the engine wont start you have otter problem if the engine hardly turn whit a fully charge battery or jump start from another car take all spark plugs off and tray again whit out the spark plugs if coolant comes out of the engine you have a floated cylinder and a blown head gasket. Note may be a good idea to change your battery clamps wile you are at it or at leas clean then using a wire brush bad contact on battery clamps causes to lose power doing start. hope can help you good luck. :)
Jun 09, 2009 | 2000 Nissan Maxima
Midwest Snips Aluminum Rail Clipper Heads - MW-ALREC-IB - Elite - Residential Logo
468 people viewed this question
Top Midwest Snips Sport & Outdoor - Others Experts
Are you a Midwest Snips Sport and Outdoor - Other Expert? Answer questions, earn points and help others
