Question about Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW
Mode won't switch to scan - Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW
  • Konica Minolta Master
  • 6,168 Answers
Codes 1826, 1825 and 1819. Car wont start. Do we need to remove trans to reset? Trans was used.
DTC P1819
Internal Mode Switch-No Start/Wrong Range
DTC P1825
Internal Mode Switch - Invalid Range
DTC P1826
Internal Mode Switch C Circuit High Voltage
The transmission internal mode switch (IMS) is a sliding contact switch attached to the selector detent inside the transmission side cover. The four inputs to the PCM indicate the position of the transmission range selector. The input voltage level at the PCM is high (B+) when the IMS is open and low when the switch is closed to ground. The four input parameters represented are Signals A, B, C and P (Parity). Refer to Transmission Internal Mode Switch Logic
Install a Scan Tool . A professional scan tool !
Turn ON the ignition, with the engine OFF.
Important: Before clearing the DTC, use the Scan Tool in order to record the Freeze Frame and Failure Records. Using the Clear Info function erases the Freeze Frame and Failure Records from the PCM.
Record the DTC Freeze Frame and Failure Records.
Clear the DTC.
Select IMS on the Scan Tool .
Place the gear select lever in PARK range, then move to NEUTRAL range.
Does each range selected match the Scan Tool IMS display?
.Replace the lever assembly-manual shaft detent with internal mode switch.
Refer to Transmission Overhaul in the 4T65-E Section of the Transmission Unit Repair Manual.
Mar 15, 2016 | 2001 Buick LeSabre Limited
Turn off the progressive scan mode?
is this question about the progressive scan when going to dvd mode more than likely the switch to control your p scan is on the back of your vcr/dvd player near the center look on the back and flick the switch to off usually the switches are just black moving left and right if not go into your menu and look for progressive scan mode if its not directly on the menu it is more than likely in the settings folder.Also if your remote is like the one i posted just click the p.scan button
Feb 02, 2015 | GoVideo Go Video DVD/VCR Combo
Murano won't shift to manual mode
The system is computer controlled and you need to run the diagnostics with a scan tool to see what shows up.
Dec 13, 2012 | 2006 Nissan Murano
On my PS3 my PC Chat Headset won't be found on the scan. How do I set it up?
Read the instructions for your headset on how to put it into pairing mode.
May 12, 2012 | Plantronics Audio 50 Headset Gaming Chat...
My HP Officejet 5610 All-in-One give me an error of no scan options refer to device for troubleshooting, why?
>Original CD supporting your OS? If supports uninstall the drivers & reinstall it in auto play mode.
>Down loaded drivers won't supports scan option.
Dec 15, 2011 | HP Officejet 5610 All-In-One InkJet...
2004 chevy malibu ignition switch
How would you like it if you replaced the switch an that wasn't the problem ? That is very possible without knowing for sure if that is the problem . Testing the electrical supply to the switch an out of the switch is the proper way to diagnose this problem. Plus the ignition switch is just a input to the BCM - body control module . The BCM is really in charge of what mode to put the vehicle in . Your best bet , take it to a qualified repair shop .
The body control module (BCM) has a bussed electrical center integrated into the housing. Body control relays and fuses are installed directly on the BCM, which simplifies wiring and junction blocks on the vehicle. The body control system consists of the BCM and its associated controls. Battery positive voltage is provided to the BCM from IBCM BATT 1 fuse and the IBCM BATT 2 fuse in the underhood fuse block. The module grounds are wired to ground G201, G203 and G305. The BCM is wired to the GMLAN High speed serial data buss, and the GMLAN Low speed serial data buss, as well as discrete input and output terminals to control the functions of the vehicle's body .
Serial Data Gateway
The body control module (BCM) in this vehicle functions as a translator between the High and Low speed GMLAN busses. The 2 communication protocols use the BCM to translate communicated serial data messages between the control modules over the 2 serial data busses.
Normal vehicle serial data communications and the control modules operations will not begin until the system power mode has been identified. Discrete wires from the ignition switch contacts are monitored by a module which acts as the power mode master (PMM) in order to determine the correct power mode. The module which is the PMM communicates the system power mode to all modules on the serial data lines. Refer to Body Control System Description and Operation to identify which module is the PMM and the applicable power mode look up table.
The one that said you may need an ignition switch has no clue as to what's up !
Install a scan tool.
Turn OFF the ignition.
With a scan tool, under Vehicle Control Systems, Computer/Integrating Systems, BCM Data menu observe the Power Mode parameter.
Does the displayed power mode parameter match the actual ignition switch position?
Go to Step 2
Go to Step 6
Turn the ignition switch to the UNLOCK position.
May 30, 2017 | Cars & Trucks
How to put printer in print mode
Actually, it does not matter what mode your printer is on when printing from your computer. Whenever your printer detects a print job sent to it, the printer will automatically acknowledge the signal and print the file - no matter if it's on Copy, Scan or Fax Mode.
Aug 26, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
My anti virus won't work... my security system says my computer is at risk... how can i remove these viruses?
Download malware bytes and run a scan. Remove the dangerous things. If it won't let you, you will have to run this in Safe mode of your computer.
Jun 16, 2011 | Microsoft Windows XP Professional SP3 Full...
I cant change the play mode... when i did it automatically restarts,,,,,,, why is that?
let the norton2010antivirus scan the player or the memory card provided, some of the msi of the system might be hidden.after scanning, restore factory defaults..
May 17, 2010 | Hyun Won mobiBLU DAH-1500 MP3 Player
How to set channels to scan on motorola ht 1000
On the HT1000, there is an A, B, C toggle switch just under the On/OFF/Volume control knob.
When set to A, the radio is IN the scan mode.
When set to B it is NOT in the scan mode.
When switched to C, it is in the scan program mode. There is a green button on the left side above the PTT switch. When you set it to C, you switch the CHANNEL SELECT knob to the desired freq you want to add to the scan list. When there, you push the green button. ONE push gives you a red indicator light on the top of the radio. A 2nd push gives you a GREEN light displayed. A 3rd push gives you NOTHING lit up.
The 1st push (RED light) means you have selected THIS freq as your PRIORITY channel of your scan list when scanning.
The 2nd push (GREEN light) means it is just IN the list, not as a priority channel.
NO light means it is NOT entered into the scan list.
Once you have your list set up, simply flip the A,B,C switch back up to A and you're scanning what you selected.
HOWEVER All of the above is dependent on whether or not the ORIGINAL setup programming from the factory set the radio up for these features to work. If it WASN'T set up that way, you'll have to have it reprogrammed to activate the buttons and the toggle switch for those features to work.
Jan 27, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
