Question about DANIEL WOODHEAD 1083-3 Fluorescent Hand Lamp 4v363
How to replace bulb on lamp
Tear apart for replacement
How to replace a bulb on a 2002 Olds Intrigue
take the bulb apart from the housing
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Mar 03, 2014 | ASK Proxima SP-LAMP-016 LP850,...
Replacing Light bulb w/housing
Lamp is replaced by customer in most cases---look to owner manual---in general if lamp up front (I think yours is by the model number indicated) the front plate beneath the screen gets removed (have set unplugged) and a lamp door is marked---it opens when screw/s securing it are removed.
Inside are two more screws---with them removed grasp the handle for the cartridge with the lamp and pull it out.
Be sure to get a Mitsubishi lamp and not a generic "bulb" which would require you to take the housing apart---generic bulbs have a much shorter life.
carefully slide the replacement in so the two pins on the rear connect correctly into the socket in the set where they go.
there are video instructions for many sets on You Tube.
Jun 01, 2012 | Mitsubishi WD-57732 Projection Television
Replace GE 50W Halogen bulb in ceiling fixture
if fixture is as shown, remove the nut in the middle of the fixture, remove the lamp, and replace it, note donot touch the lamp with your fingers, this causes lamp to fail, use a cloth to install then replace in reverse as you took it apart
Sep 27, 2011 | Universal Lighting and Decor White 11"...
Camera left in the drizzling rain, flash bulb burnt out, how do I replace, where do I get new bulb?
Hi, Unfortunately in those camera's there's no good way to replace the bulb without tearing the entire camera apart which is why almost no places sell bulbs. As well since it was left in rain it could have possibly fried the circuit which isn't fixable. If you need more help let me know =)
Jul 18, 2011 | HP R837 Digital Camera
I have an amana convection/microwave model acm1580as that needs a lamp replaces. I bought replacement lamp and after practically tearing appliance apart I located burnt out lamp. Now I don,t know how to...
Hi, since you have located the burnt lamp, all you need to do is to unscrew the burnt lamp and replace the new one by screwing it in.....
You only need to unscrew to remove the lamp and if you cannot remove by unscrewing because it is stuck in, then you need the assistance of an electrical tech to help remove with his pliers....
Mar 26, 2011 | Amana ACM1580 Convection Microwave Oven
Hello
To replace bulb in RCA rear projection TVs follow this.
Turn the lamp assembly so that the front of the bulb faces downward
Locate two clips approximately three inches apart along the back edge of the rear lamp cover. Depress the clips with your thumbs and pull upward on the rear lamp cover to disengage it. Move the rear lamp cover so that you can see the head of the bulb. Note that the rear lamp cover still connects to the base of the bulb by a cable.
Locate the three hex screws around the head of the bulb that, in a triangle formation, secure the bulb to the assembly. Remove the screws with a hex screwdriver.
Pull the bulb and rear lamp cover upward to remove them.
Remove the nut that connects the cable from the rear lamp cover to the base of the bulb with a wrench. Disconnect the cable from the old bulb and discard the old bulb.
Reattach the cable from the rear lamp cover to the base of a new bulb and install the nut. Tighten the nut with a wrench
Install the bulb face down into the lamp assembly. Install the three hex screws into the tabs along the edge of the bulb and tighten with a hex screwdriver.
Reinstall the rear lamp cover onto the lamp assembly and line up the tabs with the holes along the side of the assembly. Press downward until the cover snaps into place.
Reinstall the lamp assembly into the back of the television, facing the bulb towards the center of the TV set. Tighten the screws securing the assembly and reinstall the lamp access door. Tighten the screw on the lamp access door.
Mar 22, 2011 | RCA D61W20 61" Rear Projection Television
My Panasonic PT-61LCZ70 keeps shuting off
Most likely problem is bulb failure. Replacing the bulb is first step in any LCD rear Projection troubleshooting.
PT-61LCZ70 has a special "Super Dooper" long life lamp that costs a ton to replace. US users have 5 year warranty on the lamp assembly. Canada users can whistle for help from Panasonic Canada. There is no replacement bulb available, only expensive lamp assembly.
TV has to be completely taken apart to change the lamp. Panasonic service information is 12+ pages for lamp change instruction.
Check Panasonic Lamp Gallery for an image of this lamp assembly.
easyab
Apr 22, 2010 | Panasonic PT-61LCZ70 Television
When I was unscrewing a burnt out hood lamp on
I would not use the lamps. Sounds like there is a shortage in the wiring for the lamps. They lamps should run together, and if one of the sockets have a short or burned wire it will not let it complete the circuit. This could be a fire hazard, so I would replace the whole microwave. It would be more trouble to tear it apart and find the exact problem than it's worth.
Jan 04, 2010 | Maytag MMV4205 Microwave Oven
I have a OK Lighting touch lamp and three of the glass planels are broken do you kow whenere I can get replacements
Hello there:
here is several links that will definatly help you in your quest to find touch lamp glass ok? look below mainly # 3
best regards michael
  1. Lamp Shades - Glass Lampshades - Silk Replacement Lamp Shades - 2000 item catalog of glass lampshades, silk replacement. ... Finishing Touch - Finials. Tulip - Lilly - Large -Small. Oil Lamps & Fonts ...www.specialtylampshades.com
  2. Speciality Lamp Shades Add a finishing touch to your shades. Reverse Painted & Dome Glass Shades ... Replacement Glass Lamp Shades- Reproduction & Custom ...www.specialtylampshades.com/lampshades.html - Cached
  3. Touch & Glow Replacement Kit | LampsPlus.com 3-way touch lamp. Saves energy. Extend bulb life. ... Glass Shades. Light Bulbs. Night Lights. Under Cabinet. View All Categories. Bathroom Lighting ...lampsplus.com/.../Touch-and-Glow-Replacement-Kit__35098.html - 110k - Cached
  4. Elegant Touch: Brown's Lampshades ... a special accent for your special lamp and replacement lamp shades. ... Glass Small Tear Drop Lamp Finial. c3-finial $12.95. Crystal Gothic Cross Lamp Finial ...brownslampshades.com/store/ctgy/elegant-touch.html - Cached
  5. Nec Display Solutions 50016683 Replacement Lamp - Yahoo! Shopping Yahoo! Shopping has Nec Display Solutions 50016683 Replacement Lamp. Quick Links: Specifications - Description - Compare Prices shopping.yahoo.com/p:Nec Display Solutions 50016683 Replacement Lamp... - 126k
  6. Replacement Shade for 2198 Floor Lamp - Shop.com Shop for Replacement Shade for 2198 Floor Lamp and Floor Lamps at Shop.com. the 2198TA lamp was designed by fontana arte in 1954. a very dignified modern touch to an...shop.com/replacement_shade_for_2198_floor_lamp-59830151-7...
lamp
Sep 24, 2009 | Electrical Supplies
Panssonic PT50DL54 DLP Lamp Replacement
Webman,
I own the same television, however, I am not a technician. The lamp housing unit is in the front of the television. Pop off the plastic grill and remove the screw on left side. Access to the bulb is there. Replacing the bulb is quite simple.
David
Jan 05, 2008 | Panasonic PT-50DL54 50" Rear Projection...
DANIEL WOODHEAD 1083-3 Fluorescent Hand Lamp 4v363 Logo
75 people viewed this question
Top DANIEL WOODHEAD Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Are you a DANIEL WOODHEAD Fish Expert? Answer questions, earn points and help others
