Question about ASUS Computers & Internet
Asus beeps 6 - ASUS Computers & Internet
    Brigadier General:
  • ASUS Master
  • 3,400 Answers
Posted on Feb 10, 2014
1 long beep, 2 short beeps
This page
http://support.asus.com/pcassistant/pdf/BeepTable_en-us.pdf
suggests hat for Asus systems, 1 long beep, two short beeps is characteristic of a RAM fault. The video card does not determine the beeps, it is the system BIOS of your computer which determines the beep codes (and what the fault is of course)
If your computer is not an ASUS, but some other brand but with an ASUS video card the beep code may mean something different.
May 19, 2014 | ASUS Computers & Internet
ASUS P4V800D-X AMI BIOS AMERICAN MEGATRENDS BEEP CODES
Hello here is some beep codes:
Beep CodeDescriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
My guess is you have a ram/memory module failure.
Try to renew the ram module.
The asus homepage is here:
http://support.asus.com/Download.aspx?SLanguage=en&m=p4v800d-x&p=1&os=
Here you can download a manual.
Please unzip the file when downloaded.
Your mainboard is using following type of ram:
Dual Channel Memory Architecture
4 x 184-pin DIMM Sockets support max. 4GB
PC3200/PC2700/PC2100 non-ECC DDR SDRAM memory
These module does not exist bigger than 1GB.
Oct 15, 2012 | ASUS Computers & Internet
I have a ASUS P8P67 LE motherboard, intel i5 - 2310 processor, kingston DDR3 RAM and ASUS ENGTX560 DC/2DI/1GD5 graphic card. When I turn on the PC i get one long and then three short beeps, and the...
> one long and three short BEEP
Something is wrong with some of your hardware.
Turn the computer off.
Disconnect the AC power.
Remove the graphic card.
Connect the AC power.
Turn the computer on, to see if the pattern of BEEP has changed.
Remove the RAM -- all of it.
Reinsert one stick of RAM.
Reinsert the graphic card.
Jul 16, 2011 | ASUS P8P67 LE LGA 1155 P67 SATA 6 Gbps and...
Asus 1366 X58 - Lights up on power. No diagnostic
The symptoms are problem at the CPU. Extract i7, check it vissually and try again. Try with one stick of memory too.
Stelios.
Feb 22, 2010 | ASUS P6TD DELUXE Motherboard LGA 1366...
2 SHORT BEEP AND 6 BEEPS ON BOOT Asus NCLV-D motherboard
2 short = Parity circuit failure 6 beeps = Keyboard controller Gate A20 error
make sure all hardware is installed properly
retrace your connections to insure all parts
were installed correctly. you may have to disconnect and start from the
beginnig to correct this problem. disconnect all unneccesary prephrial
leave only the mouse /keyboard and monitor hooked up and try booting again . eliminate as you go to narrow down to the problem.
Nov 12, 2009 | ASUS NCLV-D Motherboard
2 short 6 long beeps, whats the problem? nothing on screen, no other signs.
Check your VGA Card it's properly connect and your memory module, maybe one of that is not functioning.
If still have that beeps then change temporarily your VGA Card with another. As long as you see some appears on the screen then it's good luck.
Please rate us!
Oct 05, 2009 | ASUS p4p8x-uay Motherboard
Asus p4p800-vm 2 beeps then 6 beeps
This is RAM problem, your RAM is not working well. please replace RAMs then check it will work fine..
Please dont forget to rank my answer
Sep 05, 2009 | ASUS P4P800-VM Motherboard
3 beep at the start
Thats a standard mother board warning...back when i built a few computers i got this all the time it meant "no Memory" or no ram chips were installed or that the memory was not compatible it should just beep three times with about a second delay in between each beep...then thats your problem...your ram might be dead! if it has 3 short beeps and boots up fine it could just be a start up beep i know of older computers beeping quickly 3 times before booting....though ive never delt with asus boards only Intel. but i doubt it would be much different
hope this helps,ben
Aug 13, 2009 | ASUS P5S800-VM Motherboard
4 seconds long beep
I think that either you have a bad power supply or it is not connected properly. I suppose it could also not be supplying enough power.
Try disconnecting all of the connections to the Motherboard and reconnecting them. Make sure they seat properly. Try a new power supply. You can get a good one from Newegg.com
Jan 26, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
